a rat killin mouse - Team Camaro Tech
Bench Racing Stories, cruising and more.
post #1 of 10 (permalink) Old Feb 15th, 17, 04:28 PM Thread Starter
kevin
a rat killin mouse
Shafiroff and SB2.2 Cylinder Heads Power Up Gen I SBC
sound track of my 68 383
flat tire is offline
post #2 of 10 (permalink) Old Feb 15th, 17, 05:13 PM
Re: a rat killin mouse
Anything they make is a killer, if you have the $$.
TC # 349
zdld17 is offline
post #3 of 10 (permalink) Old Feb 15th, 17, 05:50 PM
440" SBC.....lol....I love it (even if it ain't an LSx)
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #4 of 10 (permalink) Old Feb 15th, 17, 06:40 PM
Vega$69's Avatar
Under $20k. budget build? Lol
Vega$69 is offline
post #5 of 10 (permalink) Old Feb 16th, 17, 04:00 AM
Greg
pittpens24's Avatar
Man that thing sounds good! Is that like a 20 quart oil pan on that thing? Maybe it's just me but it looks BIG.
'68 Camaro SS with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #6 of 10 (permalink) Old Feb 16th, 17, 06:15 AM
mpm
Dean
8 years ago when I still had my engine shop. I built the same combo. Used a dart raised cam block, Callies 4 inch stroke crank, Dyers 300 M rods and custom JE pistons. Heads and intake were from Wegner Automotive in Markesan Wisconsin. This was for a mini rod pulling tractor combination. Man when I had that on the dyno it was quite a monster. First couple of pulls were hard to do. After it was tuned it made 900 some horsepower. I still might have the dyno computer files.
That would be a killer street strip engine with the right camshaft installed.
mpm is offline
post #7 of 10 (permalink) Old Feb 16th, 17, 03:26 PM
Street Outlaws had a race with Petey Smallblock....he was running one like that with juice.
Extreme Racing Engine 440-inch small-block, SB2 mill with a cast intake and a single carburetor between the framerails
http://www.dragzine.com/news/petey-s...tlaws-filming/
68 Camaro~LSx
<-Pics
post #8 of 10 (permalink) Old Feb 16th, 17, 03:41 PM
Jake-68's rule
SWEET !!!
With straight sides on pan, I would say a 6 qt pan.
If expanded out the sides, then an 8 qt pan.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas,' '
CUBS - 2016 World Series Champions
post #9 of 10 (permalink) Old Feb 16th, 17, 05:16 PM
Jonathon
Smitty68's Avatar
Awesome!
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #10 of 10 (permalink) Old Feb 16th, 17, 05:45 PM
Steve69SS396's Avatar
Good motor for a street car.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" billet rods, Ross pistons (10:1), Hellfire rings, AFR 245 heads, T&D steel body shaft rockers, Cloyes Timing set, custom ground 4-7 swap solid roller 274/286 @ .050" with .704" lift, Dart single plane, E85 1050 Dominator, Stef's #1705R oil pan, F2 Procharger, Lemons 2" primary 4" collector, ATI 9" blower converter
Steve69SS396 is online now
Human Verification
