How do you set the miles back on the speedometer? - Team Camaro Tech
Bench Racing Stories, cruising and more.
post #1 of 18 (permalink) Old Jul 28th, 04, 11:50 PM Thread Starter
I didn't quite know where to put this, so I placed it here. (Admin) If this is inappropriate, please move it to the correct forum [img]smile.gif[/img]
After waiting for almost an entire year, this weekend I should finally have my car back. With a fresh engine installed, I would really like to roll the miles on the speedometer back to zero so in the future I'll know exactly how many miles I've place on it. If my mechanic forgot to do it, I will try and do it myself (provided that its legal). If so, how do I go about doing this?
[ 07-29-2004, 05:20 AM: Message edited by: garfield ]
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #2 of 18 (permalink) Old Jul 29th, 04, 01:27 AM
69
I'm sure mileage tampering is illegal in all state. What about buying a new one?
69 is offline
post #3 of 18 (permalink) Old Jul 29th, 04, 02:00 AM
Instead of rolling back, why not go forward to 100,000 (basically 0 again), that doesn't sound as illegal. lol Hook up a cordless drill to the speedo cable and go to town.
69ProTouring is offline
post #4 of 18 (permalink) Old Jul 29th, 04, 02:08 AM
Guess
HwyStarJoe's Avatar
It can be done, but you have to remove the speedo from the dash and get to the number wheels themselves. Rolling it back with a drill would take days and days.
It's not easy.... I know! They have to be moved in a certain order in the right directions.
In NY, there's no title for a car older than '75 so there's really nowhere that mileage is shown on registration docs. Once the car get's over a certain numbers of miles, a title will only show "...in excess of XXXXXX miles...." anyway.
Since I won't have a title, and the car is being rebuilt 100% from scratch like the factory, I put mine back to zero. Like it or not.
HwyStarJoe is offline
post #5 of 18 (permalink) Old Jul 29th, 04, 02:17 AM Thread Starter
This is one that I'm considering. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2485725268 I just shot the seller an e-mail asking if he/she had the ability to set the milage back to zero prior to selling. If they respond I'll post back and let you all know what they said.
garfield is offline
post #6 of 18 (permalink) Old Jul 29th, 04, 02:25 AM
Chad
67 Plum's Avatar
Must not be to hard used car lots did it alot in the 70s and 80s.It is against the law to tamper with the miles.But I think this is aimed at car lots and people trying to sell late model cars as low milage.I have seen a few restorations with NOS speedos with 0 miles. Same thing as far I can see.
67 Plum is offline
post #7 of 18 (permalink) Old Jul 29th, 04, 02:36 AM
Doug
On the title....at least in Michigan...are 3 check boxes for 1-actual mileage 2-not actual mileage 3-exceeds mechanical limit of odometer....just make sure you check the right box if you sell it and shouldn't be accused of trying to defraud anyone
show is offline
post #8 of 18 (permalink) Old Jul 29th, 04, 02:56 AM
You pull the speedo out, remove clip holding number wheels to assembly. Note the "tangs" are lined up on a strip of metal. You hold the wheel that shows each mile (way to the right)and turn the wheel to the left of it till it shows what you want. Then hold that wheel and rotate the next wheel to the left till you get your desired reading. Move though the whole cylinder and then load it back into the speedo assembly with the tangs locked into the metal strip as before and put the clip back on. Newer cars (I forget the year) have the whole asembly incased in plastic to prevent tampering. Oh yeah, wash your hands before you grab the number wheels. Nothing like greasy finger prints on your "low milage car" 8^).
68RSZEE is offline
post #9 of 18 (permalink) Old Jul 29th, 04, 07:17 AM
The drill trick is how guys do snowmobile odometers, I've never messed with an automotive odometer.
post #10 of 18 (permalink) Old Jul 29th, 04, 07:21 AM
Guess
HwyStarJoe's Avatar
I tried it and wore a cordless drill battery down to nothing..... the numbers barely moved. It just doesn't spin fast enough. I'm sure it'd work eventually but doing it manually only takes 15 minutes.
Now, if you could hook a vacuum cleaner motor up to the speedo cable....
post #11 of 18 (permalink) Old Jul 29th, 04, 07:40 AM
choptop's Avatar
Down here (Texas) vehicles over a certain age are mileage exempt (meaning the vehicle likely has mileage in excess of mechanical limits) and is clearly marked as such on the title. My assumption is that if the title is exempt from mileage then it legally makes no difference what the odometer says- so long as you do not misrepresent the odometer reading when sold.
I had to replace the spedo on my Harley years back- the new one had all zeros. When I sold the bike I gave the new owner the old spedo to prove how many miles the bike had before it broke.
choptop is offline
post #12 of 18 (permalink) Old Jul 29th, 04, 07:46 AM
Chris
Its easy to do once you take the speedo apart. I bought a nice used cluster to replace my broken up original and i spun the mileage around to match my original odometer reading.Cant see how thats illegal.
shoddy_F-body is offline
post #13 of 18 (permalink) Old Jul 29th, 04, 09:01 AM Thread Starter
I'm gonna keep this in mind....Thanks!
garfield is offline
post #14 of 18 (permalink) Old Jul 29th, 04, 01:55 PM
Eric
Hey Show -- noticed you are here in GR. Ever go to C's, Gemmens, Dairy Ranch, etc?
Eric68 is offline
post #15 of 18 (permalink) Old Jul 30th, 04, 03:52 AM
Once you have the speedometer out and on the bench, itís about a 5 minute job to move the numbers. But while you have it out you might as well spent a little more time and clean and lube it. Donít try to clean the number roll! Iíve wiped the paint off the numbers with dish soap and water on a soft toothbrush, and WD40 will dissolve the paint instantly and the same applies to the face.
Ron
The ď
Ē
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
Human Verification
