After sandblasting...etching primer or epoxy primer - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 12 (permalink) Old May 22nd, 07, 06:31 PM Thread Starter
bri-rock's Avatar
Question After sandblasting...etching primer or epoxy primer
The shop that is going to sandblast my coupe only has etching primer to shoot the car with after the sandblasting. Is this okay or does it need to be the epoxy primer? If it does need to be epoxy primer, what brand and part# is recommended?
bri-rock is offline
post #2 of 12 (permalink) Old May 22nd, 07, 07:14 PM
Jason
Gambitt's Avatar
Send a message via MSN to Gambitt
Re: After sandblasting...etching primer or epoxy primer
I'd personally want epoxy...just go with a good brand like PPG or Dupont.
Gambit
69 RS/Z28
Pics:
Gambitt is offline
post #3 of 12 (permalink) Old May 22nd, 07, 07:45 PM
BA.
Allan
etching primer is ok. It is just much less resistant to moisture, and not the better choice if you won't be painting the car for several months.
I vote for the epoxy if you can somehow swing it. I used DP90 by PPG. (it's black). They also make it in grey and I think another color or two.
I used black and sprayed it in my driveway. I've never even sprayed before!
BA. is offline
post #4 of 12 (permalink) Old May 22nd, 07, 07:55 PM
Robin
This is what I used, good price, quick shipment and great results.
http://www.autobodysupply.net/store/...CategoryID=428
rbanks40 is offline
post #5 of 12 (permalink) Old May 22nd, 07, 09:16 PM
Send a message via AIM to Miikeremains
Doesn't need to be epoxy. Etching prime will do just fine.
68 SS 357, AFR, Hotchkis, 4spd, 3:73
Miikeremains is offline
post #6 of 12 (permalink) Old May 23rd, 07, 03:22 PM
Epoxy primer hands down!
At one time in the PPG tech sheets PPG clearly stated DO NOT use etch primer over sand blasted metal. Reasoning is because the etch primer can pool up in the pits and not evaporate out. Now you paint over that etch sealing over it. That non dry etch loose adhesion and starts to rust because the solvents are trapped.
Epoxy has far better corrosion protection and adhesion the etch. Plus sandblasted metal is the perfect tooth for epoxy.
Etch primer can be wiped clean off metal with lacquer thinner and urethane reducer, not so with a good epoxy...Eric
Working on How to Videos and custom sheetmetal
70 chevelle
70 chevelle SS455 not a typo its a
BUICK BABY
49 and 72 chevy trucks
Project pictures
sevt_chevelle is offline
post #7 of 12 (permalink) Old May 23rd, 07, 03:28 PM
Joe
GMJoe's Avatar
epoxy here too, much better base to work off of especially if its a keeper....
'67' RS
GMJoe is offline
post #8 of 12 (permalink) Old May 23rd, 07, 06:03 PM
Sidney
Here's a good discussion & explanation of why to use Epoxy instead of acid etch http://spi.forumup.org/about53-spi.html
As for the recommended brand, I use this and have had great results.
http://www.southernpolyurethanes.com...ct%20lines.htm
The only drawback is you will probably have to order it........but a big plus is the price is right!!
'69 RS/Z28 Tribute or Recreation or whatever it's called ~ In Progress!
'69 Z28 X77/D80 ~ Appreciating
'69 Camaro ~ In Waiting.......
Sid69Z's is offline
post #9 of 12 (permalink) Old May 23rd, 07, 09:51 PM
CDJr
Phooey on etch primer! Use epoxy
Good info, Buna-man Sid
CDJr is offline
post #10 of 12 (permalink) Old May 25th, 07, 09:04 PM
shawn
I have been in the restoration/collision business for 20 yrs and used PPG almost exclusively, The first thing you want to do is to make sure the metal is clean been for you spray anything on it. All the paint mfg will have cleaners to accomplish this PPG 330 is a good one for getting the oils from your hands and whatever has touched it prior to spraying, this is only good if done right away before surface rust has come in, if rust can been seen at all you will need to use some metal conditioner. Make sure you tack it off pretty good if you are not using lint free rags(paper) that lint will look pretty bad if you don't get it off. Etch primers are good for adhesion to clean bare metals because there is an acid in them, you definetely can't just spray etch on and leave it, rust will form! You definetely can not use an etch DPX171/172 under the DP line of sealers, However you can use PPG's wash primer which will go under the epoxy very nicely, but you don't really have to do this step with the wash primer (called that because of the viscosity very thin) just if you want to go the extra mile. DP is a very good product, but I would still put paint over it, DP is not chemical resistant, it is called a thermal plastic, (straight reducers will wipe it off, no matter how long it is allowed to dry) you want to put a paint or product that is called thermal set, (something that will dry and not be affected by any type of solvent) use a single stage black with a flattening agent to get a 20-30 degree gloss, Autocolor has a product that you can spray over etch and get the semi-gloss look that is durable looks great and is chem. resistant and it is very tough , it's called engine bay, I use paint code WA 8555 which is GM black, only draw back is that it is pricey, but you can get same results with a single stage paint with a flattening agent, Talk to your paint supplier they should be able to help you, hope this helps you, Shawn
1yrat69 is offline
post #11 of 12 (permalink) Old May 26th, 07, 06:13 AM Thread Starter
bri-rock's Avatar
Thanks everyone for the helpful information.
bri-rock is offline
post #12 of 12 (permalink) Old May 27th, 07, 06:28 AM
I prefer to use a conversion coating first, then rinse, then epoxy prime over that once thoroughly dry. Never had rust come back. I still have some of the cars I use this system on and 15 years later they are rust free with no sign of rust coming through or back.
bdzee is offline
Human Verification
etching primer of regular primer, with it be ok? stevea Body Shop 3 Apr 20th, 06 07:04 PM
Base Coat Advise (DP Epoxy and Primer) CurtiSS 69 Body Shop 5 Nov 11th, 05 08:07 PM
Need help with Primer! Camaro_Kyle Body Shop 3 Aug 11th, 02 06:26 AM
chemical stripping vs d/a sanding gerico Body Shop 10 Jun 19th, 02 03:10 PM
Epoxy primer or SElf Etching MikeDF80 Body Shop 11 Apr 15th, 00 08:06 PM
