68 quarter window chrome trim - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 7 (permalink) Old Jun 29th, 11, 03:10 AM Thread Starter
Nev
2 questions.
1. How do you remove the chrome trim from a 68 Camaro quarter glass?
See highlighted part in the photo
2. If this part is adhered to the glass, what type of adhesive is used?
I hope someone can help.
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #2 of 7 (permalink) Old Jun 29th, 11, 06:21 AM
69-Pace's Avatar
Re: 68 quarter window chrome trim
Similar thread here: Quarter window chrome strip with respect to getting the chrome to install so maybe a reverse engineering process. Looks like people have used a ton of different methods. Is your factory installed? You might pop over to CRG forums and see what original material was used to affix it .
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 7 (permalink) Old Jun 29th, 11, 07:07 AM
To remove, tape up glass to protect it, if you are going to reuse it. Then use a block of wood and slowly tap the molding off. Originally the moldings were pressed on the glass with a piece of rubber weatherstrip or what I call glass tape.
Mike68RS is offline
post #4 of 7 (permalink) Old Jun 29th, 11, 08:53 AM
Lex
Lexlas's Avatar
Funny, i can't get mines to stay on, lol .. It keeps falling off on it's own - dont' roll down the window, lmao !
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #5 of 7 (permalink) Old Jun 29th, 11, 01:10 PM
Use urethane glass adhesive. It WON"T come off.
Mike68RS is offline
post #6 of 7 (permalink) Old Jun 30th, 11, 05:10 AM Thread Starter
Nev
I only want to replace the scratched glass.
Is it better just to buy the entire assembly with glass and trim?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
nev68 is offline
post #7 of 7 (permalink) Old Jun 30th, 11, 05:53 AM
69-Pace's Avatar
Is the current glass beyond polishing out the scratches?
I think Mothers and a few others have DYI glass repair/polishing kits out there. Saw one on Musclecar a while back but don't remember the vendor - think it was part of project Red Sled - so it should be listed on powerblocktv.com
Or check a few of your local glass shops. They should be able to preserve your numbers glass and might be so much cheaper then replacement glass.
69-Pace is offline
Human Verification
