Is it possible to paint just the lower rocker panels? - Page 2 - Team Camaro Tech
Body Shop Paint & Body Forum
post #16 of 32 (permalink) Old Oct 24th, 12, 12:01 PM
Re: Is it possible to paint just the lower rocker panels?
Originally Posted by DjD View Post
Ron - It sounds like the body line you are referring to is off the top of the wheel wells and in the middle of the door. If so, you are taking on a lot of panel spliting. On the fenders and quarters there is a defined line but not on the doors...
His '67 has a lower sharp line on the doors, 69's do not. Breaking on that bodyline or not depends how much money one wants to throw at a repair. Painting from that line down is no big deal. 3M protective film can be applied if it's going to get peppered. I apply it often on trike body fenders.
Some of those new cars with zero miles on the lots have had their bumpers repaired and the whole cover was not cleared. Doubtful their owners will ever know.
Sauron67MM is offline
post #17 of 32 (permalink) Old Oct 25th, 12, 07:55 PM Thread Starter
Dr.Ron
Sorry for the delay in posting....
http://img.photobucket.com/albums/v2...-50-07_106.jpg
http://img.photobucket.com/albums/v2...-49-45_408.jpg
It doesn't look as bad as the picture makes it out. That was a bright flash in a dimly lit room. It normal lighting it doe NOT look so bad.
So in the pictures you can see (as mentioned above) there IS in fact a lower body line that I was inquiring about....
Ron
Dr.Ron is offline
post #18 of 32 (permalink) Old Oct 30th, 12, 08:02 PM Thread Starter
Dr.Ron
Links to Pics posted and no replies since??
Dr.Ron is offline
post #19 of 32 (permalink) Old Nov 6th, 12, 11:38 AM Thread Starter
Dr.Ron
What happened to all my knowledgeable responders? Anybody??
Dr.Ron is offline
post #20 of 32 (permalink) Old Nov 6th, 12, 12:24 PM
Russ
I saw the pics, not sure what your question was though. Did you want advice on if they looked good enough not to paint ? If so, I'm 50/50 on it but it's really your call since it's your ride.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #21 of 32 (permalink) Old Nov 6th, 12, 12:56 PM Thread Starter
Dr.Ron
The original question was can just from that low body line down be painted. It seems there was a little confusion in earlier responses but this car is a 67, not a 69, so the body lines are difference. My 67 has a lower body line that the 69 doesn't. Not too sure even if the 68 has it.
Ron
Dr.Ron is offline
post #22 of 32 (permalink) Old Nov 6th, 12, 01:01 PM
Yes you can but you will have an edge from tape.
JR67RS is offline
post #23 of 32 (permalink) Old Nov 6th, 12, 06:28 PM
Steiner
If you're not opposed to it, the lower molding kit is about $160 and would cover most of that up.
'69 Camaro
500hp/538lbft
Steiner is offline
post #24 of 32 (permalink) Old Nov 6th, 12, 07:17 PM Thread Starter
Dr.Ron
Can you show me what you are talking about?
Dr.Ron is offline
post #25 of 32 (permalink) Old Nov 6th, 12, 07:28 PM
Bryon
bcm66's Avatar
This is it at this link.
http://www.ss396.com/mm5/merchant.mv...t_Code=KMX-452
And it will look something like this when done...
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #26 of 32 (permalink) Old Nov 7th, 12, 01:36 PM
Russ
I think it would look fine. If you wanted to get rid of the tape line then you would need to do is color wet sand and re-polish to hide the dividing line. That's how most body shops hide the lines when repairs are done.
Russ (RJ)
rj68RS is offline
post #27 of 32 (permalink) Old Nov 7th, 12, 02:52 PM
Kevin
Kevs67RSSS's Avatar
I'd say go for it for 2 reasons. 1---its not SEMA car and 2 there is seam between and gap between the rockers and the doors. Painting anything in the "middle" without at least seam is a no-go. Go for it, it will make the car look better.
Kevs67RSSS is offline
post #28 of 32 (permalink) Old Nov 7th, 12, 03:47 PM
No you won't if you know how to backmask at a style line. I did this often in collision and recently did it on trike body. Refinish Netork provides tech info you don't get as much on hobby sites. Jimmo does not say it but the blending agent will make the clear take off if sprayed heavily.http://www.refinishnetwork.com/
post #29 of 32 (permalink) Old Nov 7th, 12, 04:13 PM
prostreet69camaro's Avatar
Originally Posted by Sauron67MM View Post
No you won't if you know how to backmask at a style line. I did this often in collision and recently did it on trike body. Refinish Netork provides tech info you don't get as much on hobby sites. Jimmo does not say it but the blending agent will make the clear take off if sprayed heavily.http://www.refinishnetwork.com/ Car Painting Techniques - Waterborne Base / Clear Coat - YouTube
Cool video,, I never knew they had a blending agent in a spray can.
prostreet69camaro is offline
post #30 of 32 (permalink) Old Nov 7th, 12, 04:16 PM
Thanks for sharing. Good info
JR67RS is offline
Human Verification
