68 coupe Rear window gap size? - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 12 (permalink) Old Dec 20th, 12, 06:45 AM Thread Starter
Eddy
Im looking for info on the size of gap that is supposed to be around the rear window? can anyone help?
Saskeddy is offline
post #2 of 12 (permalink) Old Dec 20th, 12, 09:30 AM
Todd
6781camaro's Avatar
Re: 68 coupe Rear window gap size?
I have a 1/4" gap (just about) all the way around the rear glass. (give or take 1/32")
67-69 window openings will all be the same. Here's a few pics of when I measured my original '69 rear window opening before removing the roof and tulip (filler) panel. If it's within a 1/16" you'll be fine. The urethane will do the trick for the difference, and your stainless trim will hide it well.
The numbers in the pic read (just in case they are too small to see):
HEIGHT:
18 3/8" (at first stainless pin in from ends) and 19 3/8" (down the center of the window opening) I measured parallel to the vertical side of the glass opening (quarter panel edge) and spanned the tape from the first stainless trim pin down to the top-most edge of the tulip (filler) panel.
WIDTH:
I didn't take any measurements, but I just got them off of my '68 coupe which still has both quarter (sail panels) sections installed.
At center of opening (from top to bottom): 46 1/4" wide
hope this helps...
Name:	removing the roof over the rear glass (4).jpg
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too)
, '68 Conv. V8 4-spd Builder
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
My build thread:
6781camaro is offline
post #3 of 12 (permalink) Old Dec 24th, 12, 01:55 PM Thread Starter
Eddy
What a nightmare. Thanks, I appreciate you doing that for me.
Saskeddy is offline
post #4 of 12 (permalink) Old Dec 24th, 12, 07:25 PM
Todd
6781camaro's Avatar
You're welcome... Nightmare? I dream of Camaros and anything involving them.
My build thread:
post #5 of 12 (permalink) Old Dec 24th, 12, 07:39 PM
Bob
Me thinks the nightmare he's referring to is his. He's having some quarter fit issues, and it sounds like the window opening may be off.
Mine is too wide as well- the window has very little bearing on the sides, and the overall width is about 1/4" bigger than what you're showing. I'm going to install some 1/8" stock on either side to tighten the opening, and add a 1/4" strip to the horizontal surfaces to get more bearing. It's bizarre, because the quarters are tight up to the trunk filler, and they tucked under the roof great. Nothing's welder can't fix.....
BobKovacs is offline
post #6 of 12 (permalink) Old Dec 25th, 12, 04:18 PM
Todd
6781camaro's Avatar
THanks Bob... that makes sense. Funny how some posts can have double or even triple interpretations possible. It can be a nightmare... but everything is fixable like you said. The possibilities are endless with a welder. My newest favorite tool!
My build thread:
post #7 of 12 (permalink) Old Dec 26th, 12, 10:21 AM Thread Starter
Eddy
Im replacing both quarters, trunk filler, and I have just under1/2 inch on both sides, but vertically i have almost 3/4 both on top and bottom. The trunk filler fits good to the quarters, as well as matching drip rails on trunk.
Saskeddy is offline
post #8 of 12 (permalink) Old Dec 28th, 12, 05:13 AM
Todd
6781camaro's Avatar
That sounds a little large to me (vertical and sides)... Double-check how the new quarters fit along the drip rails along each sail panel. They should be tight and parallel there.
Also check the positioning of the tulip(filler) panel on the package tray. The window opening ledge should pretty much be centered on top of the package tray welding surface where the filler panel gets plugged to. Try to squeeze the opening down more if possible. Something still sounds out of position IMO.
My build thread:
post #9 of 12 (permalink) Old Dec 29th, 12, 08:21 AM
Eddy, Here's a pic with dimensions of my 67. Roof and tulip panel are original
untouched. Are you working with original or replacement glass ? My glass
measures 19-7/8" at the approx. center. I believe it is original.
my 67' build thread:
allanjs is offline
post #10 of 12 (permalink) Old Dec 29th, 12, 09:20 AM
Question Re: 68 coupe Rear window gap size?
Hey guys mind have a gap at the pass rear and also have already been painted. Now what do i do its on the corner where the molding curve?
dill is offline
post #11 of 12 (permalink) Old Dec 31st, 12, 08:47 AM Thread Starter
Eddy
That is awesome, thank you. i have the same measurements now with some treeking. because of the taper, when i centered it all around the sides ended up closer. I now have 1/2 inch even all around.
Saskeddy is offline
post #12 of 12 (permalink) Old Dec 31st, 12, 08:54 AM
You're welcome Eddy. Check your window trim fit also before you call it good.
allanjs is offline
Human Verification
