KK tripoli turquoise - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 15 (permalink) Old Jun 3rd, 13, 05:11 PM Thread Starter
Bob
Does anyone have the correct PPG formula for this color in BC/CC paint? I think I can have a scan done of the orig paint but I am worried about how accurate that is going to be. I am getting close to paint on my 68 SS 350 and am worried I will get the color wrong. Just curious, is there a difference between 69' Azure turquoise and 68' Tripoli turquoise? They look very similar to me.
Thanks, Bob
ctmadbob is offline
post #2 of 15 (permalink) Old Jun 5th, 13, 05:50 PM
Tim
Re: KK tripoli turquoise
I'm sorry, I can't help you. But I am curious because I think Tripoli turquoise is a great color. My car was originally that color before I bought it. (When I bought it, it was in white primer and STILL hasn't seen real paint!!!) Hopefully someone can help you out. Here are two great pictures of Tripoli turquoise or what I HOPE is Tripoli turquoise!
Good luck.
Tim
My 1968 convertible build:
tjgimp is offline
post #3 of 15 (permalink) Old Jun 6th, 13, 03:26 AM
Bob
If those pics are of a Tripoli Turquoise car, it's definitely a different color than Azure Turquoise. My daughter was set on having me paint her car Azure Turquoise, and we looked at tons of pics of cars in that color, and they definitely don't look like the car in the pics above.
BobKovacs is offline
post #4 of 15 (permalink) Old Jun 6th, 13, 03:33 AM
Monty
I have never seen an Azure Turquoise car in person but isnt it real close to Lemans Blue with just a hint of green?
fishface is offline
post #5 of 15 (permalink) Old Jun 6th, 13, 03:56 AM
Tim
This PPG paint chart for 1968 Chevrolet models indicates 13517.
Looks like 69 Azure Turquoise is PPG 2078:
Note that BC/CC paint systems may appear somewhat different from the original lacquer paints, so probably a good idea to mix a small quantity in your chosen color and shoot some test areas....
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
post #6 of 15 (permalink) Old Jun 6th, 13, 04:44 AM
Bob
I'd say it's quite a bit lighter than Lemans Blue- closer to the Glacier Blue with some green in it.
post #7 of 15 (permalink) Old Jun 6th, 13, 05:38 AM Thread Starter
Bob
Nice car Tim....That is exactly the color mine was originally (I think). I have the black stripe that goes down the door also. I am going to see if the computer at the paint store can come close to that color. Unfortuneately, I have only the paint under the door panel to go by. Previous Earl Shibe 70's paint wasn't even close to the original.
Bob
ctmadbob is offline
post #8 of 15 (permalink) Old Jun 6th, 13, 07:54 PM
Tim
Bob
The area under the door panel may not have had full coverage from the factory, so color-matching from that might throw the paint scanner off; you may be OK, but so many cars just have varying amounts of factory overspray on top of primer....
ZLP955 is offline
post #9 of 15 (permalink) Old Jun 7th, 13, 04:26 AM
Bob
A prophet will provide the wrong color if reading the primer showing through. If you want to verify color you need a good sample or find someone with a satisfactory match. Forget about photos or pictures on line, they can't be relied upon for accuracy.
Sauron67MM is offline
post #10 of 15 (permalink) Old Jun 7th, 13, 12:39 PM
Tim
Thanks Scott. The information you share about paint is much appreciated. I'm no where near paint, but I'm constantly looking for certain colors in real life. I want to see a seafrost green and a Tripoli turquoise in person. As I said, I HOPE that car was Tripoli turquoise because it looks great in that light on my computer! Other pics on line (not accurate) are not as nice. Paint is very much a mystery to me! Thanks again.
Tim
tjgimp is offline
post #11 of 15 (permalink) Old Jun 7th, 13, 01:31 PM
Buy a couple half pints and shoot test panels to see which code you prefer.
post #12 of 15 (permalink) Old Jun 12th, 13, 06:54 PM
Chad
Send a message via AIM to AutoRodTechnologies Send a message via Yahoo to AutoRodTechnologies
I could check tomorrow if this color is available in pro-spray if you would like..
They are hit and miss on some of the older colors though.
AutoRodTechnologies is offline
post #13 of 15 (permalink) Old Jun 13th, 13, 05:07 AM Thread Starter
Bob
Well, I went down to the local PPG dealer and he had a formula for that color in I believe Shopline level paint. He mixed up a pint and I asm going to compare to see how close it is. I have my fingers crossed that it will be close!Bob
ctmadbob is offline
post #14 of 15 (permalink) Old Jun 13th, 13, 06:12 PM
Tim
Please post some pics and let us know how it turns out.
Tim
tjgimp is offline
post #15 of 15 (permalink) Old Jun 13th, 13, 06:36 PM
You can call the PPG library and see if they have a formula on file in DBC. Jobbers are not always on top of their game. Or try BASF or Sikkens.
Human Verification
