Convertible sag ??? - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 12 (permalink) Old Apr 4th, 05, 04:29 PM Thread Starter
Convertible sag ???
I was wondering what was the best way to fix convertible sag on my 69?I tried to get the doors lined up but there seems to be a larger gap on the bottom of the door next to the quarter panel than by the front fender.I do need to replace the front floor pans and wanted to fix the sag at the same time if possible?
Thanks Doug
Dougs 69 cam is offline
post #2 of 12 (permalink) Old Apr 4th, 05, 05:17 PM
Vintage 68's Avatar
Re: Convertible sag ???
Doug;
Try a search for 'Convertible body' and check out past posts about this like - sagging convertible
This is a major issue with some cars and needs to be corrected with replacement of major structural parts such as the floor you mentioned and the side rockers in some cases.
The "Good News" is that these parts are now available
Hope others that have/are doing this work chime-in also.
Best of luck on your project!
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 12 (permalink) Old Apr 4th, 05, 07:43 PM
Doug -
First, do you know the condition of your rockers, and whether the extra vert braces (one bolt-in "dogbone" under each rear interior panel and the bolt on X-brace underneath) are in place?
I had the same problem on because of rotten rockers on the 68, and actually had the rockers starting to stress crack at the front where they join the cowl. This was 5 plus years ago, before the convertible rockers came out in repro. The only thing I could do was weld in frame connectors. This helped with the overall structural rigidity, and took care of the sag. The 69 has good rockers, so I haven't done anything with that one.
If you're not planning significant horsepower and want things to be "original," the new rockers are the way to go.
Eric
Eric Kammerer is offline
post #4 of 12 (permalink) Old Apr 6th, 05, 06:25 AM Thread Starter
The "dog bones"and the X brace are in place.I did notice that the striker plates in the doors are missing. The pass rocker looks good from the ouside be inside I can see alot of scally rust.
I have the front subframe out of the car and the rear end is still in it. I tried to lift the car from the center like the other post suggested but with the top unlatched and pressure in the middle of the car with the jack the was very little movement.
I am wondering if by not have the conv. door striker plates installed for about 20 years has allowed the car to move . It is between an 1/8 to 1/4 inch off at the bottom of the rear door.Any other suggestion on how to get the car back to where it should be?Should I put the front subframe and motor back in the car for the extra wieght in front?Or should I go ahead and remove the floor pans and see if I can get the car to flex back?
Thanks Doug
post #5 of 12 (permalink) Old Apr 6th, 05, 07:51 AM
geneo
Doug before you start bend the car.... post some pics of the door gaps you are trying to fix. As well as the rusty area of the floor ... That way we can make sure we are not telling you to do the wrong thing. If you need a place to post them e-mail them to me and I will post them for you
gene_sc is offline
post #6 of 12 (permalink) Old Apr 6th, 05, 09:07 PM
geneo
Doug pics posted here...
http://www.islandbrokersrealty.com/gallery/album15
Doug
How do you have the car supported??? that much (thats not alot in your pics really) of sag is not uncommon when car is not setting on the wheels or supported correctly on a dolly
ect
gene_sc is offline
post #7 of 12 (permalink) Old Apr 7th, 05, 06:53 AM Thread Starter
Gene, I have the car supported by the rear end on jack stands and I have a 4x4 going across the front of the car roughly where the front sub frame was. The gap seems to be the same as it was when the car was on all four wheels.It does not seem to move or flex very much at all.I have the doors adjusted to look good at the top of the door. If I adjust the door to the rocker ,the door gap and top gap is off. I would like to make it right before I weld the floors in.
Thanks Doug
post #8 of 12 (permalink) Old Apr 8th, 05, 09:44 AM
geneo
Doug
adjust them so they are parallel to rocker and then use a porta-power to move the cowl (if narrow at the top of door to 1/4 gap) or 2 clamps and a come-a-long (if wide at the top of door to 1/4 gap) to square the door opening
gene_sc is offline
post #9 of 12 (permalink) Old Apr 8th, 05, 06:19 PM Thread Starter
Gene, How would you go about using a porta-power to spread the cowl open?How would you set it up?Once I have it spead I should weld in the door brace and replace the floors right???It should stay after that right???
Thanks Doug
post #10 of 12 (permalink) Old Apr 8th, 05, 09:17 PM
geneo
Doug you use the porta-power(to push on short dimension) or clamps and come-a-long(to pull long dimension) in and "X" in the door jamb. I would adjust the door so it fits the rocker and send me a pic of the gaps and I'll tell which way to push or pull on it...
when it fits then weld in some x braces in the door jamb and do your floors
gene_sc is offline
post #11 of 12 (permalink) Old Apr 9th, 05, 06:55 AM Thread Starter
Gene, the gap would be smaller on the top so I would have to use the porta-power. I was just wondering how you would use the porta-power on the jamb?Maybe use the porta-power and a block of wood in the jamb to spread the top apart?
Thanks Doug
post #12 of 12 (permalink) Old Apr 9th, 05, 07:09 PM
geneo
Thanks Doug
Yep use blocks of wood at the ends of porta power so it doesn't bend the pinchwelds over. IF tight on the top put porta power from the top to the bottom of the "A" pillar. Go slow and check gap as you go. You will have to push it past straight to account for spring back.
gene_sc is offline
Human Verification
67 SS/RS 396 Convertible 67CruiseMasterCamaro Tag Team 13 Apr 15th, 05 04:20 PM
1970 426 HEMI CONVERTIBLE 69huggerZ Bench Racing 9 May 24th, 04 04:32 PM
Wrong Convertible Top Frame? rafab1 Tech 2003 6 Aug 12th, 03 02:21 PM
Wrong Convertible Top Frame? rafab1 Convertibles 6 Aug 12th, 03 02:21 PM
tubbing convertible pwoolford Body Shop 2 Feb 2nd, 03 04:24 AM
