core support bushings install - Team Camaro Tech
Body Shop Paint & Body Forum
post #1 of 7 (permalink) Old Nov 12th, 06, 06:52 AM Thread Starter
I just received my poly bushings for the my 69 and all is in I just do not know what the order is for the core support. I am sure the large one gets into the hole on the support with large washer and bolt, then small bushing in between core and subframe with nut and washer underneath? it just looks like the one between the core and subframe just doesn't line up well
stmeljes is offline
post #2 of 7 (permalink) Old Nov 12th, 06, 07:35 AM
Kevin
SixtyAte's Avatar
Re: core support bushings install
Try this link of Jims car and see if the bushing photos help. It been years since I replaced my 68 bushings and didn't really care to remember the PITA they were
Kev
http://www.brainerd.net/~knudsen/69RS/Frame%20Bushings/
SixtyAte is offline
post #3 of 7 (permalink) Old Nov 12th, 06, 08:15 AM
Larry
Some of the poly bushing sets come with core support bushings which are too large for the stock support.
I had to discard the ploy bushing on the core support for stock OEM types rather than enlarge the holes in the support.
Larry
Fathom Green 69 DZ x77 Done soon if the Mastercard holds out!
ldrisner is offline
post #4 of 7 (permalink) Old Nov 12th, 06, 03:15 PM Thread Starter
so the bottom poly is too big?? thats what I think too, Has anyone else seen this or idea how to fix??
stmeljes is offline
post #5 of 7 (permalink) Old Nov 13th, 06, 11:30 AM Thread Starter
anyone else had this problem with polys
stmeljes is offline
post #6 of 7 (permalink) Old Nov 14th, 06, 02:25 PM
Yep just tried to install mine on saturday same issue about an 1/8 over all to big for the hole
_PuNiShEr_ is offline
post #7 of 7 (permalink) Old Nov 14th, 06, 05:08 PM
DjD
DjD's Avatar
The prothanes I used fit perfect... Here's a break down of how it all goes together for all 3 positions.
Stacked it goes like this;
Core Support .. Center Mount ..... Rear Mount
bolt ............... body (cage nut) .... body - (cage nut)
washer .......... cushion asm ......... cushion asm
cushion ......... sub-frame ............ sub-frame
core support .. cushion ................ cushion
cushion asm .. washer ................. washer
push nut ....... bolt ...................... bolt
frame
washer
lock washer
nut
There are 3 diff cushion asm sizes used and 2 diff cushion sizes used. Be sure you got the right pieces in the right places.
...Dennis
DjD is offline
Human Verification
Heater core installation Dynawolf Heating & Cooling 7 Mar 1st, 06 06:24 PM
Leaf Spring Bushing Install (HELP) Bigwill11 Brakes, Suspension & Steering 4 Feb 27th, 06 11:29 AM
Install body bushings with tremic! blue ss Transmission & Driveline 2 Feb 21st, 06 09:23 AM
body bushings install blue ss Body Shop 1 Feb 3rd, 06 05:51 AM
Bushings for Core Support Z28 Mark Tech 2000 6 Mar 24th, 01 06:21 PM
