Best 383 Cam for Torque ? - Team Camaro Tech
Performance Our High Performance area
post #1 of 83 (permalink) Old Dec 15th, 07, 09:10 AM Thread Starter
Lou
I have a 383 in a 73 camaro. 2000 stall/th350/3.08 gear. I need to change out my cam & lifters because of a lobe gone bad. What is my best choice for torque, not high end HP? (it will never go above 5000rpm.) Thanks
73 stroker is offline
post #2 of 83 (permalink) Old Dec 15th, 07, 09:28 AM
Wes
Re: Best 383 Cam for Torque ?
Comp's 260H
Straight-line-69 is offline
post #3 of 83 (permalink) Old Dec 15th, 07, 09:32 AM
CompCams CamQuest6 software recommends the XE262H with a 1300-5600 rpm range
Hydraulic-Excellent response, good mid-range, noticeable idle
If Hydraulic Roller, the software recommends the XR270HR
The 260H is '18th place' on CamQuest6 for recommendation. Torque curve similiar, but 18 less HP at 4000 rpms.
I used '4 - Auto - Excellent in Daily Driver - Slight-Mild to Choppy Idle' for the Usage selection.
and
Brian Lewis is offline
post #4 of 83 (permalink) Old Dec 15th, 07, 09:42 AM
Harley
wiskeesour's Avatar
Contact UDharold at TeamChevelle....
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #5 of 83 (permalink) Old Dec 15th, 07, 09:45 AM
I've been running a comp 270H in mine. "Torque" is an understatement.
Chassis dyno pull started at 2000 rpm, well over 350 ft-lbs there, peaked at 400, peak HP was 293 @ 5200. cam is coming out, pm me for a "special"
post #6 of 83 (permalink) Old Dec 15th, 07, 10:24 AM
Might be a good deal for him as he already had a burnt lobe on the last one. Maybe this was the noise on #6 cly. If all lifter are in the same place, breakin time is done.
Lou, was this the problem?
TC # 349
zdld17 is offline
post #7 of 83 (permalink) Old Dec 15th, 07, 10:40 AM
Banned
Please see the 396 thread..
pdq67
post #8 of 83 (permalink) Old Dec 15th, 07, 10:49 AM
For a solid lifter, I ran a Comp Xs290 and ran in the 11s. Globs of torque. Hit 501 TQ rear wheel on the dyno.
Highhat2 is offline
post #9 of 83 (permalink) Old Dec 15th, 07, 11:11 AM
I ran the CompCam 280H for years in my 406 and torque was never a problem, traction was
You should state your full combo for the best reply.
It seems the flat tappet XE cam line has the most issues with lobe failures
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #10 of 83 (permalink) Old Dec 15th, 07, 11:41 AM
Harry
dawg's Avatar
I used a sealed power CS-179R in my 383 (350 hp 327 grind)
and it was surely a stump puller.
everyone was always wondering what cam I used because their 383s never had the grunt mine had.
got mine here:
https://www.northernautoparts.com/Pr...ctModelId=4240
434 stroker
US Navy retired
dawg is offline
post #11 of 83 (permalink) Old Dec 15th, 07, 11:45 AM
Eric
What about the GM hot cam? Hydraulic roller so no "burnt lobes".
Eric68 is offline
post #12 of 83 (permalink) Old Dec 15th, 07, 01:12 PM
The 280H and XS290 duration cams are too high for a 3.08 gears rear end
Lets not turn this into another XE bashing thread, we have enough of those BS threads with 95&#37; of the posts coming from people who have never owned an XE cam
and
post #13 of 83 (permalink) Old Dec 15th, 07, 02:13 PM
I only stated what I gathered from posts on wiped lobes and what the majority were (or seemed to be).
I ran the 280H with 2.73's and a 2200 converter which had no traction on the street below 40mph on regular radials when nailed ... yes not an optimum combo but would 2.0 60' all day with a best of 13.5 @ 101 using only 1st and 2nd with a th350 tranny.
The "ricers" never expected 1st gear to go to 80mph @ 6000rpm, grab 2nd and burry the speedo. You know the "muscle cars" aren't any good on the hiway lol
68 Camaro~LSx
<-Pics
post #14 of 83 (permalink) Old Dec 15th, 07, 07:17 PM Thread Starter
Lou
was wondering about the 327/350Hp.(222/222 duration @.050) I've used it in a few 350s & liked it. The XE was too much for the 3.08s.(well actually if I had a higher stall converter it wouldn't have been that bad).(Very noticable Idle). It WAS the problem for #6 !. I'll look some more at the Comp Cams.
post #15 of 83 (permalink) Old Dec 16th, 07, 06:33 AM
Harry
dawg's Avatar
the CS-179R is great with a 3:08 rear
434 stroker
US Navy retired
dawg is offline
Human Verification
