Best Engine Rebuild kit for 94 z28 camaro LT1 ??? - Team Camaro Tech
Performance Our High Performance area
post #1 of 11 (permalink) Old Dec 21st, 07, 08:29 PM Thread Starter
I just got a 1994 camaro Z28, Im looking to rebuild the engine with forged internals they dont have to be the top of the line but something descent, anybody know of a engine rebuild kit that has forged internals w/o a camshaft ???
94z28camaroTN is offline
post #2 of 11 (permalink) Old Dec 21st, 07, 08:51 PM
Rick
Re: Best Engine Rebuild kit for 94 z28 camaro LT1 ???
Forged internals. do you want just pistons or rods and a crank???
CamaroZZ430 is offline
post #3 of 11 (permalink) Old Dec 21st, 07, 09:11 PM Thread Starter
what would you recommend if i wanted to supercharge it later down the road ?
post #4 of 11 (permalink) Old Dec 21st, 07, 09:24 PM
Rick
If you really want to build the motor I would buy a Eagle rotating assembly for it. Reasonably priced and will handle it. I'll be honest with you for the hassle of building a motor and the money you end up spending it is just easier to buy a crate motor from chevy. It ends up costing about the same and there is alot less hassel. Plus it is BRAND NEW!!!
post #5 of 11 (permalink) Old Dec 21st, 07, 09:28 PM Thread Starter
well im 16 and right now i dont have all that much $ i was thinking of starting off with bolt on mods like intake, headers, and cutouts. what other mods would you recommend starting out ?
post #6 of 11 (permalink) Old Dec 22nd, 07, 01:32 PM
how about a tuneup first and foremost"
plugs, wires, cap and rotor. throw new fuel filter on it, and run some Marvel Mystery oil thru the fuel system to plush things out. the stuff is cheap and it does work.
then, once you get it running as good as it can in stock form, then start with a good cat back exhaust kit- i know the Flowmaster kit goes in easily and really wakes it up- then work up to a high flow cat (or just get rid of it altogether if you don't have smog checks where you live) and headers.
next would come a cold air kit.
now that you've got it all set up to support twice as much power as you are making stock, then you can start doing things inside the motor.if you want to supercharge it, then by all means pull it out and put a forged rotating assembly in it along with a bigger cam and heads.
the main thing, tho, is to do one thing at a time and learn as you go. the easiest way to give up on a car is to try to do too much at once.
you don't plan sincerity.
novaderrik is offline
post #7 of 11 (permalink) Old Dec 22nd, 07, 04:10 PM Thread Starter
For headers and intake what would you recommended ? i heard alot of people using coated pacesetter headers and a K&N intake i can spend about $400-500 dollars on a pair of headers and about $250 on a intake.
post #8 of 11 (permalink) Old Dec 22nd, 07, 09:33 PM
Nick
Well i had a 94 lt1 and i tuned it, then put some edelbrock ceramic coated headers, they came with the Y-pipe you need and the 3" to the back where it split, i did a cold air kit, personally i would get a lt4 intake, then save money and wait till you can go through the entire engine&tranny, opening up the exhaust and letting it breath really made a great improvement.
cdahart3 is offline
post #9 of 11 (permalink) Old Dec 23rd, 07, 11:12 AM
The best bang for the buck on those cars is long tube style headers. Pacesetter happens to make the least expensive set. Get the regular uncoated ones and you will be happy. If you don't have a lot of cash, the coating makes little sense if going fast is the primary concern. You will see upwards of 25rwhp from the headers alone. Second on the list would be a cold air intake. Moroso, K&N, SLP etc. They are all about the same. Third would be to get a tune from someone like pcmforless.com or madz28. With the above items, you should be close to what an LS1 is stock.
67 RS/SS clone - 530rwhp
11.15@125mph
redcamaro is offline
post #10 of 11 (permalink) Old Dec 23rd, 07, 11:15 AM
The LT4 intakes only make sense if you have LT4 heads. The LT4 heads have a taller runner.
11.15@125mph
post #11 of 11 (permalink) Old Dec 23rd, 07, 11:39 AM Thread Starter
also if i wanted to have cut outs before the cat what would i do with the O2 sensors ? i know the fronts determine th A/F ratio im not complete sure how i would do that any ideas ? because i have emissions here and as long as its legal during the testing its fine also is it worth buying the cermatic coated headers vs the non coated ?
Human Verification
