What is Cowl Induction? - Team Camaro Tech
Performance Our High Performance area
post #1 of 32 (permalink) Old Aug 1st, 01, 08:06 AM Thread Starter
I was reading that I can add HP by adding Cowl Induction to my car. But how does Cowl Induction work, and what do I need to do?
Alfonso Perez is offline
post #2 of 32 (permalink) Old Aug 1st, 01, 02:57 PM
Banned
Cowl induction is when the back of the hood next to the windshield is open so that the engine can get access to the cool high pressure air that builds up there while driving.
Stock cowl induction hoods were options on first gen cars. They are the ones w/ the "low wide" hood scoop facing rearward down the middle of them. Real ones had matching air breathers that fit up tight under them to take advantage of the cool air. And, yes your car will make slightly more power w/ the cooler air the engine can suck in using a cowl hood thats open. Hope this helps. pdq67
post #3 of 32 (permalink) Old Aug 2nd, 01, 08:47 PM
A cheaper option would be to fabricate a cold air induction sytem. There was an article in Super Chevy magazine a while ago about this. Get an old air cleaner base and lid, two aluminum gutter downspouts, some flexible ducting, some thin sheet metal, and some rivets. Attach the two downspouts to the inside edge of the front of the air cleaner base with the rivets and then wrap the sheet metal around the remaining area of the cleaner base and attach with rivets. When you put the cleaner lid on, the edges of the sheet metal and downspouts should be inside the lid. Then run the flexible ducting down from the downspouts to your front bumper area where there are holes allowing fresh air in. This should force the air cleaner to take in only fresh, cold air from the outside.
Garrett M.
68 Camaro
Cam35068 is offline
post #4 of 32 (permalink) Old Aug 3rd, 01, 06:44 AM
Talking
Another type
Sean James
67 camaro convertible
69 Firebird - ls1 t-56 behind pontiac 350 motor
12 bolt 4:10
mo67cam is offline
post #5 of 32 (permalink) Old Aug 3rd, 01, 12:39 PM
Carl
There's a homemade version on my website.
The Red Beast http://www.geocities.com/casanoc
CarlC is offline
post #6 of 32 (permalink) Old Nov 24th, 10, 05:44 PM
Andrew
Andrew69's Avatar
Re: What is Cowl Induction?
Wow! This was resurrected from 9+ years ago.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #7 of 32 (permalink) Old Nov 24th, 10, 05:51 PM
Hopefully Alfonso has seen the replies in the 9+ years since the last replies!!!
David F.
www.firstgens.com
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #8 of 32 (permalink) Old Nov 24th, 10, 05:55 PM
Andrew
Andrew69's Avatar
Alfonso's last post was August 1, 2001. Maybe he will pop up again.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 32 (permalink) Old Nov 24th, 10, 07:07 PM
If your looking for more HP there are countless ways to get more power for your money.
To add cowl induction to a first gen correctly your going to spend $600 or more and maybe pick up a whopping 2Hp.
1967 Camaro in the works-406 AFR 210E Chassisworks subframe, 13" wilwood.
69 Camaro SS/RS, Orange/white, Ivory houndstooth/VE3.. sold
Jeremiah is offline
post #10 of 32 (permalink) Old Nov 25th, 10, 05:03 AM
yeah, but $600 saved up in the 9 years since this thread was started comes down to $66.66 a year, or $5.55 a month, which certainly seems doable...
you don't plan sincerity.
novaderrik is offline
post #11 of 32 (permalink) Old Nov 25th, 10, 06:34 AM
Fred
77thor's Avatar
Lol
77thor is offline
post #12 of 32 (permalink) Old Nov 25th, 10, 07:03 AM
Smile Re: What is Cowl Induction?
I think it's the "cool" factor that is raised about 100 shp, (smiles per Horsepower) because those hoods look so darn cool !
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #13 of 32 (permalink) Old Nov 25th, 10, 08:28 AM
They do look great.
I thought of adding it to my SS but everyone has the ZL2 hood and I like to be different.
Jeremiah is offline
post #14 of 32 (permalink) Old Nov 27th, 10, 06:49 AM
Bryan
How about a cowl hood AND...... The amazing Tornado!!! Or you could just use the tornado and no one will know your packing that 2 extra HP. Ultimate sleeper! Seriously, the cowl hoods look so cool, do you really need an excuse? I think we'd run them if they stole 5 hp.
CPT Chevy is offline
post #15 of 32 (permalink) Old Nov 27th, 10, 11:05 AM
.gearhead.'s Avatar
I'll sell you this cold air kit cheap. It is a USM Inductions kit and it was the bees knees back in the day. The photo is from 4-5 years ago. It's still in good condition. Paid $350 new. It's yours for $75 plus shipping.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
Human Verification
