What cam would be best? - Team Camaro Tech
Performance Our High Performance area
post #1 of 23 (permalink) Old Jul 13th, 09, 12:38 PM Thread Starter
I have done some research and now I am confused as to which cam I should install in my basically stock 327. I am running 245 60's on the rear but I am not sure what the gear ratio is. I do know that this was a bone stock column shift automatic with matching #'s when I bought it. It now has a 4 barrell with headers and the PG has been replaced with a Turbo 350. All I want to do is gain a little more low end horse power/torque with that sweet sound. I will not be street racing though. Based on what I have read, I understand that I have to be careful on my selection due to the fact that I have power brakes and the wrong cam will greatly reduce my vacuum or shove the valves down into the pistons. Can anyone tell me if the cam specs below would work best for what I am looking for?
Duration .228/.228 Lift .480/.480 LSA 112
Any advice would be greatly appreciated.
bld22663 is offline
post #2 of 23 (permalink) Old Jul 13th, 09, 01:06 PM
Chad
67 Plum's Avatar
Re: What cam would be best?
That cam is to big for your application.You need one around 218 @ .050 and .450 lift.Like this
http://www.summitracing.com/parts/CCA-K12-206-2/
or
http://www.summitracing.com/parts/CCA-CL12-210-2/
67 Plum is offline
post #3 of 23 (permalink) Old Jul 13th, 09, 01:21 PM
Talking Re: What cam would be best?
I agree with Chad. The 2nd cam he listed is the 268, and that would be the largest, that I would go with. For mostly stock, the 256 or 260 would be good. Even with the 268 you should have 8.5:1 compression and a higher than stock stall converter.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #4 of 23 (permalink) Old Jul 13th, 09, 01:41 PM Thread Starter
Chad,
Would this cam provide a little more power along with decent sound?
Thanks,
bld22663 is offline
post #5 of 23 (permalink) Old Jul 13th, 09, 01:59 PM
Levi
That cam profile sounds like the one in the 290hp 350 gmpp crate engine. It wont sound stock.
1975 Camaro "Black Out"
.Bad75. is offline
post #6 of 23 (permalink) Old Jul 13th, 09, 03:13 PM
Chad
67 Plum's Avatar
Chad,
Thanks,
Booth of those cams will add power and have a noticable idle.The 2nd cam will have more sound at idle than the 1st one.Do you still have the 2 barrel heads on you engine? If so the problem is not enough compression.A larger cam that has a real aggressive idle needs more compression to not kill the low end torque.It would sound great but not have as much power as the stock cam down low.
67 Plum is offline
post #7 of 23 (permalink) Old Jul 13th, 09, 04:14 PM Thread Starter
Chad,
Would the second cam work if I do still have the 2 barrel heads? Also, would there be a noticeable power loss? I don't want to go backwards just to gain that hot rod sound. I don't know much about the engine other than it is an MO code that translates to a 210 HP 327 according to my Motors Manual.
bld22663 is offline
post #8 of 23 (permalink) Old Jul 13th, 09, 05:17 PM
Chad
67 Plum's Avatar
Chad,
Might want to check that code again MO is a 302. http://www.camaros.net/years/68/68codes.html You would gain enough in midrange and top rpms. to make up for anything lost down low.A head swap in the future would really wake it up.
67 Plum is offline
post #9 of 23 (permalink) Old Jul 13th, 09, 05:27 PM
Banned
You sure about the "MO" code? I kinda doubt it??
Post back what it is b/c if you have a 210hp/327, you are just a topend switch away along w/ .020" thick steel shim headgaskets from a 275 and 300hp/327 engine.
Get her up to 9.75 to 1 or so and then install the 268HE hy-cam mentioned earlier.
pdq67
post #10 of 23 (permalink) Old Jul 13th, 09, 07:20 PM Thread Starter
My mistake guys...It is an ME code 327. Will the second cam listed be a good choice?
bld22663 is offline
post #11 of 23 (permalink) Old Jul 13th, 09, 07:32 PM
Chad
67 Plum's Avatar
Did some looking around get this cam its between the two comp. cams and is cheaper.I buy all of my engine parts from them good company to deal with.
Elgin, Hyd. Flat Tappet Cam & Lifter Kit, Chev SB, .454/.454
Chev SB
Lift: .454/.454
Adv. Duration: 272/272
Duration @ .050": 216/216
Lobe Center: 110
1500-5500, Noticeable idle, Stock converter OK
http://www.competitionproducts.com/p...number=E1065PM
67 Plum is offline
post #12 of 23 (permalink) Old Jul 13th, 09, 07:33 PM
Chad
67 Plum's Avatar
To bad a MO coded block would have sold for enough to build you a nice engine.
67 Plum is offline
post #13 of 23 (permalink) Old Jul 13th, 09, 07:38 PM Thread Starter
I know...I guess I was day dreaming when I read the code...or there was just too much paint in the letters.
bld22663 is offline
post #14 of 23 (permalink) Old Jul 13th, 09, 07:43 PM Thread Starter
Would this one work also?
http://www.summitracing.com/parts/SUM-K00052/
bld22663 is offline
post #15 of 23 (permalink) Old Jul 13th, 09, 07:48 PM
That's probably the same cam. It should work good for you.
TJS69 is offline
Human Verification
