Camshaft Markings - Team Camaro Tech
Performance Our High Performance area
post #1 of 7 (permalink) Old Aug 23rd, 09, 08:43 AM Thread Starter
Eric
Camshaft Markings
I am beginning to wonder if my cam is a Crane cams not a comp Cam.
Markings:
"C
C"
On the Front (offset like that)
And a 292h on the rear. Unfortunately I cant find any info on the CRANE 292H due to their situation. I was under the assumption I had a Comp cam, but now my memory is failing me!
'68 Coupe 383 Small Block
4 speed Muncie (M 21)
12 bolt rear end (4.10)
Old school slappers
Old School L-60 Mickey Thompson's
EC's 327 is offline
post #2 of 7 (permalink) Old Aug 23rd, 09, 09:28 AM Thread Starter
Eric
Re: Camshaft Markings
Photo to help:
Old school slappers
EC's 327 is offline
post #3 of 7 (permalink) Old Aug 23rd, 09, 11:15 AM
Ken
From Comp Cams, 292H grind number. Do these cam specs ring a bell?
Just trying to help.
http://www.compcams.com/Cam_Specs/Ca...x?csid=81&sb=2
1969 Camaro
KMG69 is offline
post #4 of 7 (permalink) Old Aug 23rd, 09, 11:47 AM
I've got one of these, in a block but never run. If anybody wants to trade for it please PM me. I'd rather have a 274H06 or solid Duntov for my setup.
Melrose RS is offline
post #5 of 7 (permalink) Old Aug 23rd, 09, 12:25 PM Thread Starter
Eric
Does it have the same markings? Is a comp? or a crane? Comp Cam= C C? or Crane Cams= C C?
Old school slappers
EC's 327 is offline
post #6 of 7 (permalink) Old Aug 23rd, 09, 02:02 PM
Sorry, I can't tell you anything about the markings. It's in a block right now in a buddy's basement. But it's a comp cams 292H that I bought a long time ago.
post #7 of 7 (permalink) Old Aug 23rd, 09, 03:10 PM Thread Starter
Eric
Ok, I bought a set of calipers (digital-never owned digital before) and measured the base and then the lobe....It took several trys due to the new calipers and gettng used to them)
Base= 1.185" (measured several lobes, does this sound right for the base circle?)
Lobe= 1.519" (this was tuff becuse of the taper but I think its right)
My math thats a .334 lobe....
292H cam has a .334 lobe x 1.5 Rocker = .501
Now my measurements could be off.....
Does the base circle size seem to be right? if so I trust my lobe lift number....
Old school slappers
EC's 327 is offline
Human Verification
