383 sbc VS. 496 bbc 650 HP - Team Camaro Tech
Performance Our High Performance area
post #1 of 24 (permalink) Old Apr 13th, 10, 10:40 AM Thread Starter
What engine will be easier to build $$ wise, and which one will have better street manners?
The camaro is set up for a sbc, so that needs to be taken into considerstion. I really like the rev of a solid sbc, but to be fair, I have never been in a well built bbc car. The curosity of the bb torque is stirring inside of me.
I'm not trying to open a big can of worms, I am just at the point that I am ready to start making some decisions, and looking for personal and profesional experiences.
WAYRAD 67 is offline
post #2 of 24 (permalink) Old Apr 13th, 10, 10:55 AM
Milt
Milt's 68 SS/RS 396's Avatar
Re: 383 sbc VS. 496 bbc 650 HP
Words to live by:
go BIG (block) or stay home.
Milt's 68 SS/RS 396 is offline
post #3 of 24 (permalink) Old Apr 13th, 10, 10:57 AM
.gearhead.'s Avatar
Your goal of 650 hp will be easier to attain with the bbc. You'll probably have a much more "tame" engine with the bbc too. I've only had sbc's in my life because I love unexpected things, but I'm starting to think about doing a bbc to get a bit more hp with a bit less effort.
Good luck.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #4 of 24 (permalink) Old Apr 13th, 10, 11:08 AM
Eric
Ive only ever had bigblocks so im a little biased,but my best street mannered one was an iron ovalport headed 427 with a comp cams 288 street roller dual plane intake and 10:1 comp. Ran 11.50s at 121.00 in my 3600lb 4spd car driven to the track. idled great,never got hot and had 11-13 inces of vacuum at idle.And i built it cheap!Did it make 650hp?absolutely not,but it was unbeatable on the street.A cheap 496 will get you where you want easy!
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
post #5 of 24 (permalink) Old Apr 13th, 10, 11:31 AM
Greg
If you want 650 HP from a "streetable" 383 you are gonna need to boost it or spray it.
69 Camaro, 3450lbs., 400, Cal Tracs, Coan 10", TH400, 3.50 gear, no trailer
D1SC blow thru, pump gas, 9:1, ~10 PSI,
1.325 60', 5.988 @ 115.4
Greg O is offline
post #6 of 24 (permalink) Old Apr 13th, 10, 11:38 AM
650 with 500 cubes is easy
600+ with a 383, well youre gonna have to buzz it to make the power,
meaning it will take more gear and stall (not as streetable)
67 camaro
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline
post #7 of 24 (permalink) Old Apr 13th, 10, 11:38 AM
Eric, just curious - how cheap is "cheap"?
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
RSSSfanatic is offline
post #8 of 24 (permalink) Old Apr 13th, 10, 12:30 PM
Smile Re: 383 sbc VS. 496 bbc 650 HP
Just a few thoughts :
Every part you buy is more for a big block.
To convert a sb car to a bb will cost you about $2000, NOT counting the cost of a Big Block.
You can build a 427 or larger small block if you want.
You can get more HP from a Big Block, but why ? Unless you are racing. A 500 HP SBC is more than most people will ever need.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #9 of 24 (permalink) Old Apr 13th, 10, 12:44 PM
Gary
TraxUnderground's Avatar
"Theres no substitution for cubic inches"
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
73 Camaro project in a million pieces
TraxUnderground is offline
post #10 of 24 (permalink) Old Apr 13th, 10, 12:52 PM
500hp is for starters
67 camaro
62 Nova
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline
post #11 of 24 (permalink) Old Apr 13th, 10, 12:58 PM
Eric
It was many years ago but i can tell you i had a 454 block,got a 427 steel crank for $100,ported my own heads that i had and spent the money for new bigger valves and springs,block machine work and valve seat job was 1200,pistons were off the shelf trw forged,intake was used,thats the best i can do,but by todays standards it was cheap.My 525 puts at least 680 to the tires and cost me about $9000 and that was with a lot of beg,borrow and bartering with a machinist that i was doing a 57 chevy for at the time.But your never really done,Its that new carb,or electric water pump or vac pump set up you want to add that starts to add up after you think you had enough to keep you happy.
post #12 of 24 (permalink) Old Apr 13th, 10, 01:53 PM Thread Starter
TJS69 could you give me a little more insight as to what it takes to swap from sb to bb. I have never done it. $2000 seams a little high to me, but I am learning.
500 hp is for starters! That was funny!
Ok maybe 600 to 650 hp is a little over the top for a streeter. But maybe not. I read so many posts about guys building a motor, then wishing they had gone bigger. The way I see it, a 600 to 650 hp street car is as big as I would ever want to go, (you would never use it all anyway, but it's there), so why start with a 500 hp motor and then in a couple years, months or weeks, wish that I had gone bigger. Like one of my friends always says, "Why do it once when you could do it twice"!
Don't get me wrong, I'd love to have a 500 hp sb, and maybe I would be totally satisfied, for years to come, But since I am in the planning stage, I thought I would start B I G! Jim
post #13 of 24 (permalink) Old Apr 13th, 10, 02:42 PM
.gearhead.'s Avatar
Just buy my fresh sbc and call it a day.....
Now: Boost...
post #14 of 24 (permalink) Old Apr 13th, 10, 02:54 PM
done sbc, moved up bbc, moved back to big sbc, still not happy, want to go back to bbc. like candy , once you taste the tq and hp, its never the same, even a cheap 468.
TC # 349
zdld17 is offline
post #15 of 24 (permalink) Old Apr 13th, 10, 03:58 PM
What are you goals?
650hp will get you in the 9s if the car is set up right, heck an honest 500hp will get you in the high 10s.
But I agree do it once, go with big cubes wether big or small block.
67 camaro
62 Nova
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline
Human Verification
