SBC cam difference? - Team Camaro Tech
Performance Our High Performance area
post #1 of 17 (permalink) Old Apr 22nd, 10, 06:00 PM Thread Starter
Anthony
SBC cam difference?
I`ve got a GMPP 290hp 350 in my el camino. for those not familiar, rated at 8.5:1 but closer to 8:1, dished pistons, 993 casting heads if I remember correctly and the L82 cam which is the old 350hp 350 cam. It runs decent enough and I`ll fine tune it before making any changes but how better or worse would it run with the Crane 274HO6? I`m actually doing a deal for a summit version of that cam now so it`s coming. Any idea of how it will change the power band? Right now it has a Weiand Stealth, Holley 670cfm Street Avenger, HEI, headers, flows,and a 4spd. Will probably get 3.73`s pretty soon as well. I`m going to dial it in with the L82 cam and see what I can get from it before I change it but I`m curious what you guys think about the power difference.
sschevellefan is offline
post #2 of 17 (permalink) Old Apr 22nd, 10, 07:19 PM
Steiner
Re: SBC cam difference?
It will make torque lower in the RPM band and it looks like a better fit for that compression. The LSA will also give it a lumpier sounding idle. You will most likely lose nothing up top. Some 1.6 ratio rockers added at the same time will give you a little more lift.
The L82 specs are:
222/222 @0.050"
0.450"/0.450"
114 LCA
Crane 274HO6 specs are:
218/218 @ 0.050"
0.450"/0.450"
106 LCA
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 17 (permalink) Old Apr 22nd, 10, 09:58 PM Thread Starter
Anthony
The L82 specs are:
222/222 @0.050"
0.450"/0.450"
114 LCA
218/218 @ 0.050"
0.450"/0.450"
106 LCA
Yeah I figured the specs fit the engine better, always liked tighter LSA`s though most of my cams have been on a 108. I figure it`s a old school cam but not as lazy as the GM cam. I thought about doing 1.6 rockers but I think it would be pointless with the stock heads. I`m thinking about going to some vortecs or a aftermarket version down the road so maybe do the 1.6`s then. Seems like everyone I`ve read about who used the 274HO6 has had nothing but good to say about it so we`ll see how it does in my set up. Going to be a while before I swap but it`ll happen someday.
post #4 of 17 (permalink) Old Apr 22nd, 10, 11:44 PM
AJ
There isn't much difference in the two cams, the 274HO is actually a tad smaller, but like steiner said it will make torque lower in the band, and for the low compression, that is what you want.
I'd suggest getting the compression up before a cam change, because you won't notice much difference in the two.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 17 (permalink) Old Apr 23rd, 10, 03:22 AM Thread Starter
Anthony
Going by what you posted before editing, the 274 is smaller than what is in there. I never said anything about going bigger. I think the compression is fine for the 274 and it will build better dynamic compression than the 40yr old L82 cam. I think I`ll notice quite a bit of difference between the 2 cams. This isn`t my first cam change, I just usually never use such a mild cam.
post #6 of 17 (permalink) Old Apr 23rd, 10, 11:48 AM
Chad
67 Plum's Avatar
The 274H06 will be a good match.You will notice a difference.The 274 will have a nice lopey idle and rev quicker than the L82 cam.More torque also.
67 Plum is offline
post #7 of 17 (permalink) Old Apr 23rd, 10, 03:16 PM
How about an Isky 264 Mega for a compromise 264/264, 214/214, 108 LSA. Seems like that would maintain a bit more vaccum and run a lot better than the OEM L82 cam. No idea why GMPP put that cam in an 8:1 engine.
For such low compression, I think you need even less duration than the 274H06 to keep IVC early enough to pick up some cylinder pressue. JMO though... I think either one would be a big improvement over what's in there now.
John65nova is offline
post #8 of 17 (permalink) Old Apr 23rd, 10, 03:38 PM
AJ
Yeah that's why I edited it, read the thread too quickly.
I was just saying, if you are really looking for a noticeable performance gain, going to something with more lift and closer to 230* @.050" would be a hot little 350.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #9 of 17 (permalink) Old Apr 23rd, 10, 04:43 PM
Butch
Anthony the 274H06 off the top of my head is 228/228 @.050" .480"/.480" 106 lobe seperation? Is that correct?
Let me know as I have used this cam a few times in 327's and 350's
href="
target="_blank">www.prosystemsracing.com
trmnatr is offline
post #10 of 17 (permalink) Old Apr 23rd, 10, 04:46 PM
Butch
Anthony I looked them up, It will have a lot more throttle response and should pull to 5500rpm no problem. Peak about 5,000rpm
href="
trmnatr is offline
post #11 of 17 (permalink) Old Apr 23rd, 10, 07:17 PM Thread Starter
Anthony
If it had more compression and better heads I`d go with the Isky 280 mega. Best hydraulic cam I ever used.
Butch, it`s 218@.050 and .450 lift 106LSA. I`m thinking down the road to go with some vortecs and 1.6 rockers. Should wake it up good.
post #12 of 17 (permalink) Old Apr 23rd, 10, 07:17 PM Thread Starter
Anthony
By the way, I`m getting the Summit version for free. Doing a trade so I`m not out anything. as far as I know it`s just a reboxed Crane cam.
post #13 of 17 (permalink) Old Apr 23rd, 10, 07:18 PM
Butch
Go for it with the 1.6's
href="
trmnatr is offline
post #14 of 17 (permalink) Old Apr 23rd, 10, 07:20 PM Thread Starter
Anthony
Not with the smogger heads. It would be pointless and not worth the extra money setting everything up.
post #15 of 17 (permalink) Old Apr 23rd, 10, 07:30 PM
Steiner
Yeah, those Vortecs will probably increase your compression at least a point. I think you're right waiting on the rockers....the Vortecs require self aligning ones so you'd wind up buying them twice. Save that cash for the new intake.
'69 Camaro
500hp/538lbft
Steiner is offline
Human Verification
