Engine Quest heads- any good? - Team Camaro Tech
Performance Our High Performance area
post #1 of 48 (permalink) Old Oct 15th, 10, 10:48 AM Thread Starter
Looking for some 170cc/1.94/64cc heads for a street 327.
These appear to have vortec chambers and are ridiculously inexpensive (bare). I have the screw in studs, guideplates, good springs and valves already so I'd swap them over.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Anybody using these?
Melrose RS is offline
post #2 of 48 (permalink) Old Oct 15th, 10, 11:48 AM
Smile Re: Engine Quest heads- any good?
Those are at a good price. Maybe you get what you pay for ? I compared flow numbers and even the double hump heads had about the same numbers. The vortec heads really outflow the double humps ! The RHS outflow the vortec's. I haven't checked the Dart s/s yet.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #3 of 48 (permalink) Old Oct 15th, 10, 11:57 AM Thread Starter
Yeah, as you know I am looking at these and the RHS. Do you know the numbers for each at say .400" and .500"?
post #4 of 48 (permalink) Old Oct 15th, 10, 12:11 PM
Brandon
They are pretty nice heads for the $. They make all the IMCA heads as well. Much better than I can say for some other brands out there.
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
post #5 of 48 (permalink) Old Oct 15th, 10, 01:13 PM
AJ
They look good, but so does any other good, clean bare head.
A part of me says no, just because of the "Vortex" in the Ad, either they don't know much about heads, or they got their secretary to do the ad....
Either way, you can't find a set of used bare double humps for $150 unless they are free.
I'd say get em, if they are horribly wrong like Patriots heads (vlaves in the wrong place) send them back, if not, use the money you save to get them worked, or go with a roller cam.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 48 (permalink) Old Oct 15th, 10, 02:58 PM
TJS69 is offline
post #7 of 48 (permalink) Old Oct 15th, 10, 03:20 PM Thread Starter
Yikes, those RHS heads STOMP the others across the board!!
post #8 of 48 (permalink) Old Oct 15th, 10, 05:54 PM
Banned
Bethanne
Nashville Beth's Avatar
Originally Posted by TJS69 View Post
Those figures are a little hard to believe.
The RHS head outflows a small port vortec by over 10%. Somehow I doubt this is an apples-to-apples comparison.
It took Chevrolet 40 years to get to the vortec design- the best gen 1 port ever.
I'll stick with the vortec port on any mild to medium hot smallblock. And the best deal going in an aluminum head ($900):
http://www.jegs.com/p/Edelbrock/Edel...50168/10002/-1
Nashville Beth is offline
post #9 of 48 (permalink) Old Oct 15th, 10, 09:26 PM
Yes, those numbers may or may not be that accurate. They are the numbers that the manufactures have listed.
As far as Chevrolet Vortecs, they were primarily designed to be used in 350 V-8 pick-ups at low RPM's. Why wouldn't the aftermarket easily outflow them ?
TJS69 is offline
post #10 of 48 (permalink) Old Oct 15th, 10, 09:38 PM Thread Starter
Here's an excellent site for head flow info
http://www.purplesagetradingpost.com...%20Eliminators
post #11 of 48 (permalink) Old Oct 16th, 10, 11:35 AM
Chad
67 Plum's Avatar
What I find interesting is that the 882s that everyone says are junk flow as good as the 462 hump heads.
67 Plum is offline
post #12 of 48 (permalink) Old Oct 16th, 10, 01:42 PM
right, but the thing is that on a stock motor, the 76cc 882's are dogs, and apparently are crack prone. That is not to say that people with the right combo aren't making power on them... plus they are almost free. Def. not for me and my stock 327... my lightly ported 186's work great compared to them, but the compression change is quite a bit of it I think.
All things considered, if I could get a set of heads complete like the profilers etc for 1000 bucks or so I wouldn't hesitate.... but, even if they aren't that cheap, the increase of a couple hundred to get the afrs (1500) or equivalent would have been money well spent in my opinion. They are just such a better head for the money, and easily justified in my opinion. Hell, my 186's cost me 150, already had ss valves in them, but cost me 500 for machining, new springs, new seals etc, a couple valves were burned, and I needed new pushrods for about 100 more... add it up, and that is kind of expensive for some old heads. I really like the increase from the 882's, but if I knew it was going to be that expensive I would have held out for at least some way better iron heads, but probably would have saved a little longer for the aluminum afr's, brodix or w/e.
From those flow #'s I would stay away from the eq heads. From time to time you can get a set of camel humps freshly machined around here for 400 bucks.... that is the cheapest way I would go, otherwise I think I would keep saving!
brownnote is offline
post #13 of 48 (permalink) Old Oct 16th, 10, 03:27 PM
Banned
Bethanne
The vortec port was a direct copy of the 95 LT1 port (I think that's right).
It flowed so well that it was put on the gen 1 engine.
It's quite a bit taller, hence the matching intake is required.
That's why it outflows the older type port.
The LS ports are very tall and narrow. Seems that tall is good (I'm over 6')
post #14 of 48 (permalink) Old Oct 16th, 10, 10:01 PM
i used to think that the vortec port was a copy of the iron LT1 head. but last summer when i had the intake off the Caprice LT1 i've got on an engine stand in the garage i laid an old used stock vortec intake gasket on it. . i remember that the vortec ports lined up perfectly with the top and bottoms of the gasket, but the LT1 ports are about 1/4" shorter- the same height as a standard small block port. i'd like to get an LT4 intake gasket and see how that matches up with the vortec gasket..
i can say that the iron LT1 chamber looks almost identical to the vortec head, tho.
if i was a betting man, i'd say that the vortec ports are more like the LT4 ports than they are like the iron LT1 ports.. which brings up the question of which came first within GM Powertrain- the aluminum LT4 heads used on 96 Vettes and a few 97 Camaros or the iron vortec heads used on 96-99 trucks.. ..
you don't plan sincerity.
novaderrik is offline
post #15 of 48 (permalink) Old Oct 20th, 10, 09:15 AM
Barry
Send a message via AIM to barryfrise Send a message via Yahoo to barryfrise
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170546363032&ssPageNam e=STRK:MEWAX:IT
I just noticed eBay auction 170554850847 this morning and jumped on it. I bought a pair, and with shipping it was $255. These are Vortec-style heads that allow you to keep your Gen 1 intake manifold (you have to go with center-bolt valve covers tho). To keep my costs down further I'm planning on using the valve train out of my current Chevy casting 3973487 heads in these EngineQuest heads. I found another post that indicated that that was possible, but I'd be interested in any confirmation or comments from anybody, thanks!
barryfrise is offline
Human Verification
