Roll cage/ mini tub - Page 2 - Team Camaro Tech
Performance Our High Performance area
post #16 of 24 (permalink) Old Nov 13th, 12, 08:44 PM
Michael Gekko
Re: Roll cage/ mini tub
The only way to really find out how much is too much in regards to footprint is to do some back-to-back testing with different size tires imo. Such a test would require having 2 or more sets of tires mounted and ready at the track so the conditions will be similar. In such testing eliminating variables (or reducing them as much as possible) is pertinent to having an accurate test.
Eleanor's Nemesis is offline
post #17 of 24 (permalink) Old Nov 14th, 12, 12:03 AM
Fred
Originally Posted by JR67RS View Post
Fred I think a 1/4'' spacer may cause my sidewall to rub quarter lips? As far as times, only going from what I here with the same set up. Mid- low 10's. Total speculation. I'm green and jumping on the track a little late here.
My bad. I forgot that I cut the upper wheel well molding off back in '69.
Those tires fit in there realllllly nice. Back space is 5.5" on these wheels.
These are last season's Hoosier's. Same size. You can see the cutout.
Tight, very tight.
Mid to low 10's huh? Are you going to run a power adder? Please don't, that's cheating.
Now here's a tid bit for you; First gen Camaro's are NHRA LEGAL DOWN TO 10 FLAT WITH A 5 POINT ROLL BAR Any quicker, into the 9's, you'll need a NHRA license plus a whole bunch of other stuff.
Do your roll bar right and it'll work well for cruise night too.
Here's from 2years ago. Notice that the rear bars are installed but nearly invisible. They're called rear-seat-savers from Art Morrison.
Here's the rear shelf. Now THIS was,,,,,, tricky.
All buttoned up. Even the side bar is removable. The passenger side doesn't need one. Our SO's like that.
128.79mph 1.428 60'
Fred Ficarra is offline
post #18 of 24 (permalink) Old Nov 14th, 12, 03:15 AM
Michael Gekko
Fred, that is a really neat set up.
post #19 of 24 (permalink) Old Nov 14th, 12, 06:32 AM Thread Starter
Mid to low 10's. Maybe not this motor. I don't think I'll ever be below that in my life time. I think your 69 may have a little more tire room than my 67. If the rear cross bar is made to be removable the car won't cert correct?
JR67RS is offline
post #20 of 24 (permalink) Old Nov 14th, 12, 11:22 AM
Fred
Michael, Thank you!
John I missed that your car is a 67. I'm not sure how different our cars are in wheel well room. Hopefully guys with both cars will jump in here.
The rear crossbar has to be welded solid to the hoop. Only the occupant door bars can come off. Also a TIG or MIG must be used (depending) and the welds can NOT be ground.
128.79mph 1.428 60'
post #21 of 24 (permalink) Old Nov 14th, 12, 11:34 AM Thread Starter
Thanks Fred. I'm starting to wonder what I would really gain going from a 9" rim to a 10". Geesh guys run in the 10's on 8's with a 275. 10's do look better!
JR67RS is offline
post #22 of 24 (permalink) Old Nov 14th, 12, 12:04 PM
Fred
John, Michael, in post #16 said it best. Wheel size is just one of many factors that affect each other. That's tuning for you. And I use both 8" and 10. Can't tell the difference but that's just me.
128.79mph 1.428 60'
post #23 of 24 (permalink) Old Nov 14th, 12, 12:21 PM Thread Starter
Thanks Fred.
JR67RS is offline
post #24 of 24 (permalink) Old Nov 14th, 12, 01:20 PM
Fred
You're Welcome John.
128.79mph 1.428 60'
Human Verification
