427 cam choice - Team Camaro Tech
Performance Our High Performance area
post #1 of 8 (permalink) Old Jan 1st, 13, 07:36 PM Thread Starter
ernie
427 cam choice
first ill start with my combo i currently have, 427 c.i. 396-375 cam, 215 heads with app 100cc chambers, holley h.p. 750 carb with 68 jets up front and 72s in the back, and a 390 hp intake. im going to pull the trigger on a set of race rite heads part#2061006, and a edelbrock perf air gap intake, roller rockers, advice im needing is the choice of cam, im open to all..... solid,hydraulic roller, flat tappett etc, and what do i jet the carb at for a good starting point, if anyone has a similar combo or can steer me in the right direction i would appreciate it. please dont try and talk me out of the 427, i love it . thanks guys
ernies 69 is offline
post #2 of 8 (permalink) Old Jan 1st, 13, 09:19 PM
Michael Gekko
Re: 427 cam choice
I'd call John at Bullet Cams, 662-893-5670. They make cams for Pro Stocks and Pro Streets or for the hobbyist. Bullet will email you an in-depth questionaire and can recommend/grind a cam for your application.
Eleanor's Nemesis is offline
post #3 of 8 (permalink) Old Jan 1st, 13, 09:56 PM
Sean
Re: 427 cam choice
X2 with what Michael said, you won't be disappointed.
I think a cam change alone would help what you currently have, but add heads etc. and that thing will wake right up.
As for the carb, if it runs well right now I would leave it be, it should be close enough to run. If the vacuum etc. falls way off with the new parts it may need more attention, but I'm all for using a known working part and getting it right once it's running.
And I can't imagine why anyone would try to talk you out of a 427... awesome motors.
Sean
1968 rs, with an old school, antiquated "junkyard, never even had the valve covers off" 354" SB2.2 pump gas motor........
"I aint never seen talking win me nothin'" -Marshawn Lynch
68rs406 is offline
post #4 of 8 (permalink) Old Jan 2nd, 13, 02:56 PM Thread Starter
ernie
Re: 427 cam choice
ive used bullitt in the past on a mouse motor, with good success. i was hoping that someone had a build simular to mine to give me a { real world opinion} on what i should try for this combo. also i forgot im running 355 gears and a 4 spd. it will see occasional strip pulls, and but i want it street friendly. thanks for the replys.
post #5 of 8 (permalink) Old Jan 5th, 13, 02:32 PM Thread Starter
ernie
Re: 427 cam choice
moderators, can we move this thread to the engine forum to maybe get more opinions, thanks
post #6 of 8 (permalink) Old Jan 10th, 13, 11:57 AM
Fred
Re: 427 cam choice
Also your cam choice is mostly dependent on compression ratio. You don't mention pistons.
Talk you out of a 427???
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 8 (permalink) Old Jan 10th, 13, 10:33 PM Thread Starter
ernie
Re: 427 cam choice
my compression ratio will be 11-1 with 118 cc heads. im looking at comp cams part#11-432-8.
post #8 of 8 (permalink) Old Jan 11th, 13, 10:53 AM
.gearhead.'s Avatar
Re: 427 cam choice
Suggest using LSM or Bullet. I've had both in 408, 421, 427, 434 and 436. The LSM cam was spec'd to help in ways I was skeptical about but proved true. Both great. I prefer LSM.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
Human Verification
