SBC Aluminum cylinder head recommendation! - Page 2 - Team Camaro Tech
Performance Our High Performance area
post #16 of 26 (permalink) Old Jan 27th, 13, 07:28 PM
.gearhead.'s Avatar
Re: SBC Aluminum cylinder head recommendation!
Originally Posted by Erik Beckett View Post
.gearhead.
Your car is looking amazing! I almost bought that car a few years ago before you bought it. I think it was from Indiana or Illinois when it was for sale, maybe western Ohio. Anyways, your doing a great job with it. Do you have any SBC parts for sale at all?
Thanks, Erik
Thanks Erik. Yes, I bought it from a guy in Sandusky, Ohio about 7 years ago. 5 different combos in 7 years... I got rid of most of the parts I had, but still have some odds 'n ends. Some things like cams, pushrods, crossmember, master, and other miscellaneous performance stuff. Let me know if there's something specific.
Have fun.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #17 of 26 (permalink) Old Jan 28th, 13, 06:22 AM Thread Starter
gearhead,
I am just trying to put together a top end and cam package for my 355. I need heads, intake and cam and lifters. I want to go with a hydraulic roller, have any for sale? I am leaning toward the 195cc profiler heads from Chad Speier. And maybe a 240/250 cam with about .550/560 lift. I want to be able to use these parts when I build a new short block next winner and bump up to a 400+ ci motor.
Thoughts on this combo?
Thanks, Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Erik Beckett is offline
post #18 of 26 (permalink) Old Jan 28th, 13, 08:49 AM
James
I would call Crower and speak to Dave Crower about my cam.
He will want to know every other variable, head flow numbers from .100-.700 are the most critical piece of information according to him.
Please note that any information with regards to gear ratios, tire height, weight, etc will help him design the optimum cam for your application.
James
"Collectin' Camaro's since only Rednecks Drove them"
firstgenaddict is offline
post #19 of 26 (permalink) Old Jan 28th, 13, 09:30 AM
gearhead,
Thanks, Erik
if you plan on 400 cubes get bigger heads
duration for 400 cubes is ok, but need more lift
67 camaro
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline
post #20 of 26 (permalink) Old Jan 28th, 13, 10:00 AM
.gearhead.'s Avatar
gearhead,
Thanks, Erik
Hey Erik,
If you're looking for a nice street/strip car, the basic cam spec's you mention seem within range for that. My 11:1 Venolia piston, iron Crane Fireball headed 400 had a Comp 294S cam (.525 lift if I recall), GM rods, was driven all over and went 11.20's all day. That was a mild setup but alot of fun and very easy to do.
As stated above, I'd suggest a bit larger head, to be able to accomodate future plans. I've seen the worked 195's run great and it can be fine for now, but you may want a slightly larger volume eventually. An out of the box 220, Track 1 or Pro 1 would be good for future use.
Have fun.
Now: Boost...
post #21 of 26 (permalink) Old Jan 28th, 13, 10:22 AM
Rob
satz28's Avatar
Originally Posted by .gearhead. View Post
Hey Erik,
Have fun.
I don't recall. Do you build your own motors or did you have someone build them with your input?
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #22 of 26 (permalink) Old Jan 28th, 13, 11:31 AM
.gearhead.'s Avatar
I assembled a few, including the tossed together 11:1 junker mentioned above. But I am no engine builder. I rely on a professional for the nice builds and learn whatever I can. I've just had alot of 400 based combos.
Now: Boost...
post #23 of 26 (permalink) Old Jan 29th, 13, 08:53 PM
darrell
the AFR or brodix track1 and use the bullet cam they recommend and i dont think you can go wrong
97Z4C is offline
post #24 of 26 (permalink) Old Feb 8th, 13, 10:00 PM
Banned
Chet
Exactly! Go with the cam profile your head mfg'er suggests or go with the head your cam grinder recommends.
154567 is offline
post #25 of 26 (permalink) Old Feb 15th, 13, 06:38 PM
Find an as cast head as smooth and flash free as a ported head. Canfields were that way.
The best street and bracket race head. Unbeatable flow up to .600" flow.
Who cares what .800" flow is when your cam lifts to .550 max!!
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #26 of 26 (permalink) Old Feb 17th, 13, 02:41 PM
ME! That is a myth and really needs put to bed. A running engine sees up to 150" of pressure drop. If your cylinder head is done at .600 at 28", what do you think it's doing on a live engine?
Chad Speier is offline
Human Verification
