Do I really need a PCV valve in my SBC? - Team Camaro Tech
Performance Our High Performance area
post #1 of 5 (permalink) Old Jun 27th, 06, 03:23 PM Thread Starter
Cool Do I really need a PCV valve in my SBC?
I am trying to plumb and fire up my freshly rebuilt 406.My valve covers only have 1 hole per side that has a breather installed unlike my zz4 that had two one for PCV the other for a screw in cap.If i have to have a PCV can i remove one breather and try to find a rubber gromlet the right size to accept my PCV valve.I am having trouble finding a barb fitting to screw in my intake behind carb. going to brake booster to clear my hard line to nitrous plate.Where else on motor can i get a vacummn for my brakes?
shockers69 is offline
post #2 of 5 (permalink) Old Jun 28th, 06, 02:17 AM Thread Starter
Talking Re: Do I really need a PCV valve in my SBC?
oops!!
Last edited by shockers69; Jun 28th, 06 at 02:27 AM. Reason: post same thing twice
post #3 of 5 (permalink) Old Jun 28th, 06, 02:18 AM Thread Starter
Please!I really need some fast response on this one.You can imagine if you had a new motor you could not wait to hear it thump!!!
post #4 of 5 (permalink) Old Jun 28th, 06, 03:53 AM
do you need a pcv? no, as long as you have breathers. but, without pcv you will get build up of gunk and crap in your crank case over time. so it would be better to have a pcv to suck some air thru there and get the crap out
and you can get vacuum for the brakes from any larger fitting on the intake or carb, if you want specific answers you would need to post what type of intake and carb you are using
400bird is offline
post #5 of 5 (permalink) Old Jun 28th, 06, 07:24 AM
nick
i would not run a pcv valve on a nos motor. youre basically pulling in a fine mist of oil with a pcv ,right into the intake, and putting it into the combustion chamber .if you even have any blow by and get even a drop of oil in the chamber, it will effectively reduce octane to where you could easily detonate, especially on the bottle .theres no need to run one on any type of performance motor in my opinion .maybe if you werent running nitrous but def not if you are
84 Mustang Hertz Rent-a-Car
400" LSX 9.44@146 (w only 1.44 60 ft) All Motor
In Denver on Pro 275's
Powered by my 7 yr olds Engine program
NER perf is offline
Human Verification
Lifter adjustment, warm or cold? gotsnappy Engine 32 Apr 20th, 06 07:41 PM
Valve cover : grommets and PCV? Marc Engine 6 Feb 21st, 06 01:08 AM
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
PCV VALVE NEEDED OR CAN I use a breather instead? mark67ss Camaro Tech 4 Jun 3rd, 05 09:41 AM
roller rockers Lil Greg Performance 9 Feb 12th, 01 04:26 AM
