problem w/ dart iron eagle platinum heads - Team Camaro Tech
Performance Our High Performance area
post #1 of 10 (permalink) Old Dec 7th, 06, 03:53 AM Thread Starter
charlie
anyone here used dart iron eagle platinum heads on a small block?? i am having pushrod interference issues on every cylinder(8 pushrods)- pushrod rubs on head w/ roller rocker aligned to valve tip properly-i hate to take the die grinder to the heads so i am in the process of talking to dart
actmobmar is offline
post #2 of 10 (permalink) Old Dec 7th, 06, 03:57 AM
Re: problem w/ dart iron eagle platinum heads
I will bet someone else will chime in here but I have heard guys talk about using a Lois tool to open this area up. Be careful with shavings. Also check for correct push rod length when completed.
TC # 349
zdld17 is offline
post #3 of 10 (permalink) Old Dec 7th, 06, 05:26 AM
Pop the head off the motor and grind the head, .020" is plenty.
67 camaro
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
67RS502 is offline
post #4 of 10 (permalink) Old Dec 7th, 06, 07:17 AM
Gary
Same Problem With ALL Brands
Title says it all! This is as common a problem as you're going to find. If you follow some simple rules it can be avoided.
1. Pre-assemble
2. Pre-assemble
3. Pre-assemble.
4. etc.
You get the message? The time to deal with this AND many other issues is BEFORE you do the final assembly. Thanks, Gary in N.Y.
P.S. Take this photo below and use it a guide, both now and for other's in the future, the rockers and a set of adjustable guide plates will almost always totally eliminate any pushrod/runner issues with respect to the SB's!
GOSFAST is offline
post #5 of 10 (permalink) Old Dec 7th, 06, 08:55 AM
SY1
What ratio rocker did you select, or more importantly did they send you? If it is larger than the 1.5 standard SBC this is a common problem in factory heads. I'd assume Dart would have already opened up the pushrod holes for larger ratios, but it's possible they didn't. Problem is solved by opening up the pushrod hole. I know they make a tool to slot them longer, but I've always solved it with a standard 7/16 drill. This works fine on factory heads. I don't know how large you can open them up on a set of Darts.
SY1 is offline
post #6 of 10 (permalink) Old Dec 7th, 06, 03:27 PM
Joe
We've used 4 sets and every one needed grinding. If that is not an option you could probably use an adjustible guide plate.
Racing 68 is offline
post #7 of 10 (permalink) Old Dec 7th, 06, 04:33 PM
Doug
I bought a early set of iron eagle bbc heads and had the same problem I took them off and they gave me a brand new set that worked perfect! My pushrods would not even line up with the rockers! The new set worked perfect. Almost looked like core shift!
Dougs72Nova is offline
post #8 of 10 (permalink) Old Dec 8th, 06, 04:15 AM Thread Starter
charlie
i talked to them yesterday and got the goahead to clearance them, the pushrods hit the side of the head, not fore and aft, pushrod length has nothing to do w/ this prob, w/ the 215 head they made the ports larger and actually altered the valvetrain angles, the rockers will be in a v-shape when done(each cylinder), hoping to get 700+ hp out of this motor!!!
post #9 of 10 (permalink) Old Dec 8th, 06, 05:11 AM
Banned
We have always used the Crower Shaft rockers with offset and no problems and no grinding.
CNC BLOCKS N/E is offline
post #10 of 10 (permalink) Old Dec 8th, 06, 05:16 AM
Harry
dawg's Avatar
i got same heads and yes louis tool is a must.
434 stroker
US Navy retired
dawg is offline
Human Verification
Dart heads what headers River Performance 8 Nov 24th, 05 02:50 PM
Dart heads bbc BAR396 Performance 0 Dec 18th, 04 01:30 PM
heads, compression, etc. I am going insane (long) travis Performance 18 Feb 5th, 03 12:29 PM
400 SBC COMPRESSION RATIO DTL504 Performance 37 Dec 10th, 02 07:39 PM
fuel problem HELP jokerdwarf Tech 2000 3 Dec 7th, 99 06:41 AM
