383 Block Notching - Team Camaro Tech
Performance Our High Performance area
post #1 of 10 (permalink) Old Dec 24th, 06, 04:13 PM Thread Starter
383 Block Notching
Anyone know where a I can find DETAILED documentation on exactly how to properly notch a 350 block for a 383 stroker kit and crankshaft?
Countryside_Cafe is offline
post #2 of 10 (permalink) Old Dec 24th, 06, 04:56 PM
Send a message via MSN to kausboy
Re: 383 Block Notching
I thought to build a 383 you used a 400 crank with the mains turned to fit in a 350 block and used 350 rods with "short" pistons (pistons with shorter skirts). There are "kits" available now that make it a snap!
I don't remember "notching" the block when I built mine -I did however use the wrong rods the first time and the piston skirts hit the counterweights!!! (That's embarassing )
kausboy is offline
post #3 of 10 (permalink) Old Dec 24th, 06, 05:12 PM
Eric
There is no real detailed info on notching a 350 block because all the blocks and stroker kits are a llittle different -- all have to be checked. Maybe there is a book somewhere that tells you how, but the bottom line is you need to make sure there is at least .050" clearance between all your moving parts (bearings are obviously not .050" -- they are more like .0025" rod and .003" main).
1. Crank counterweights to oil pan rails
2. Connecting rod bolts to oil pan rails.
3. Connecting rod bolts to cam lobes (especially cylinders 1,2,5,6).
4. Piston skirts to crank counterweights.
I made a go/no-go gauge from a piece of coat hanger that I flattened to .050" on the end. Then the coat hanger wire can be bent to reach whatever tight spot I need to check.
Eric68 is offline
post #4 of 10 (permalink) Old Dec 24th, 06, 06:08 PM
Royce
Ditto what Eric said.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #5 of 10 (permalink) Old Dec 24th, 06, 06:22 PM
Here's a pic of the notching required when I stroked my 327.
post #6 of 10 (permalink) Old Dec 31st, 06, 02:50 AM
robert
rolling-robert's Avatar
thats a lot of notching! i just had some minor notching to do when converting my 350 to 383
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #7 of 10 (permalink) Old Dec 31st, 06, 08:37 AM
It must be a Mexican block. Bonus Notches, Seņor...
onovakind67 is offline
post #8 of 10 (permalink) Old Dec 31st, 06, 09:43 AM
Banned
Guys,
Fwfw, Jim's pic is an excellent shot at what a "round-bottom" block look's like whenever I start mouthing off about round-bottom 283 blocks..
pdq67
post #9 of 10 (permalink) Old Dec 31st, 06, 09:54 AM
fyi, that is my original EE code 327 block, cast and assembled in 1968, and stamped with my verts vin by the Norwood assembly plant in early march of 1968
post #10 of 10 (permalink) Old Jan 2nd, 07, 12:27 PM
Guillaume
If I can help, here are pictures of my block I am currently building, it's a 327 small journal from 67:
I am building a 383 with a crank from speed-o-motive.
Regards
Guillaume
gui67 is offline
Human Verification
Small Block or Big Block PDW HOTRODS Performance 25 Dec 19th, 05 07:21 PM
383 stroker??? Prostreetcamaro1 Performance 18 Oct 26th, 05 07:31 AM
Home Block Notching luccamaro68 Performance 5 Mar 29th, 05 02:48 PM
May purchase new ZZ4 block for 383 tommyg Performance 13 Nov 29th, 04 10:46 AM
Block Plate, clutch fork pivot adjustment Luke68ss Transmission & Driveline 14 Jan 21st, 04 07:24 AM
