Time for another 68 Z/28 to be restored
937K views 1K replies 123 participants last post by  68camaroz28
#1 · (Edited by Moderator)
We purchased our 68 Butternut Yellow Z/28 in the early 80's and for all the good, bad, and ugly reasons the restoration process just sat. Now the time has come to start the process and thought it might be beneficial to someone (including keeping me on track) to update the restoration process via this thread. A little background first: 01B built Camaro with black std. interior, original born with engine, M21 trans. and rear. Fall of 2008 I found the original owner (Eddie M.) with an old 1972 Phillips 66 charge receipt that was under the front bucket seat carpet. Eddie was a great person to talk to along with being a car guy so he told me a lot about the Z/28. Purchased at Roger Dean Chevrolet in Charleston, WV in late March or early April, 68 according to Eddie. He told me he was the one who purchased and added the air cowl plenum and headers as he was into the trans-am scene and Mark Donahue. Verified as well that the Z/28 had come with 302 fender emblems but he later added the Z/28 emblems to the fenders. When my wife and I purchased the car way back when it had most of the things original except for a few items like the water pump, starter, exhaust manifolds (remember those headers) but most of the hard to find (high $ stuff today) was there.Some might ask since the car sat so long what prompted the recent start up? Well, for many years it was "I'm going to get to it one of these days" but it never happened and the reason became obvious to me that to do the car correct it was beyond my skills hence Lonny Gordon and his team at East Coast Muscle Cars were chosen. Their workmanship is just fantastic along with being just great people. So the journey begins but would not have without the support of my wife:D For those of us married, we know how important that is, right? :yes:
Here is the car in the late 70's!
The Z just before it left for East Coast Musclecars!
Chick’s Team Camaro Build Thread - Time for Another 68 Z/28 to be Restored
Table of Contents
68Z-1970 Picture of Eddie Meadows (orig. owner) – Post 32
68Z-1983 Purchase - what I brought home in pieces - Post 1244
68Z-2010 How it looked from lacquer paint job in mid-80’s - Post 1
68Z-2016 Saw some sunlight for 1st time since 1979 – Post 1263
68Z-2017 Reunited with original owner Eddie Meadows – Post 1317
68Z-2017 Picture taking for Hemmings Muscle Machines – Post 1348
A-Arm assembly painted - Post 272
A-Arm rubber flap shields-drilling NOS inner fenders – Post 1045
A-Arm rubber flap shields making staples – Post 1045
A-Arm rubber material with cords – Post 971
A-Arm shims - Post 674
A-Arm upper rubber bumper #384220 - Post 214
Air cleaner connector #3923260 to valve cover - Post 592
Air cowl plenum air filter A226CW original vs. later - Post 236 & 241
Air cowl plenum air filter cheap replacement – Post 1191
Air cowl plenum carb stud – Post 1013
Air cowl plenum installed – Post 1191
Air cowl plenum original installation – Post 1011
Air cowl plenum original seal – Post 1013
Alternator - after restoration original dated 7H10 - Post 148
Alternator - before restoration original dated 7H10 – Post 46
Alternator brackets - comparing original GT stamp to reproduction stamp - Post 160
Alternator bracket to header and alternator installation - Post 795
Alternator bracket alignment front vs. rear on alternator - Post 800
Alternator bracket alignment rear of alternator vintage picture - Post 804 & 806
Alternator wiring boot original - Post 344
Aluminum restoration, intake and distributor – Post 128
Assembly of car - rear in subframe in front - Post 454
Assembly of cowl (Firewall) and under dash list – Post 839
Assembly of fenders and front end - 1069 & 1073
Astro ventilation parts and info - 764
Ball joints riveted - Post 160
Battery cable negative clips #3857706 - Post 609 & 612
Battery cable negative clips #3857706 located on frame - Post 621
Battery cable negative clips - how to install - Post 682 & 687
Battery ground for Y55 - location and hardware – Post 1191
Battery hold down clamp bolt - original with 0.87 inch diameter washer - Post 1293
Battery hold down clamp NOS correct piece – Post 860
Battery hold down clamp original vs. Service replacement- Post 366 & Post 490
Battery hold down clamp original dip painted and stampings – Post 1293
Battery hold down clamp painted original survivors (3) - Post 511
Battery hold down clamp restored and bolt – Post 1183
Battery tray – Post 1273, 1275, 1276, 1280, 1281, 1283 & 1287
Battery tray continued – Post 1291 & 1292
Battery tray continued - how to make tab correct - Post 1304
Battery Y55 NOS purchased 1983 (no Energizer script) – Post 1183
Battery Y55 NOS early 70’s vintage with Energizer script- Post 1261
Battery Y55 - How to gut – Post 1394 & 1396
Bezels - Side marker lights painting grooves black – Post 959
Body and components media blasted to bare metal – Post 8, 9 & 10
Body rubber flap in rear quarter housings - originals - Post 196
Body work – Post 53, 59, 61, 65, 69 & 98
Body work continued – Post 106 & 113
Brake booster hose bracket-original vs. reproduction - Post 269
Brake booster restored and hardware - Post 155
Brake booster valve comparisons original to later types – Post 814
Brake booster valve comparisons original to newer reproduction found – Post 1306 & 1309
Brake booster valve and seal #546180 both original - Post 607
Brake booster valve and seal with original clamp installed – Post 902
Brake clutch pedal assembly restoration - Post 410
Brake drum internal components and stamping - Post 258
Brake drum paint for components - close match - Post 262
Brake drum shoes and assembly - Post 486
Brake emergency cables with hardware installed – Post 1409
Brake hose rubber U-shaped clips - original to reproduction - Post 182 & Post 259
Brake hose rear original - Post 280 & 302
Brake line and hardware installed pictures – Post 1176
Brake line clips and hardware (note - ignore bluing for ’68) - Post 524
Brake line clips and hardware by part number in AIM - Post 541, 543 & 545
Brake line clips and hardware by part number in AIM - Post 587
Brake line rear bracket original vs. reproduction - Post 416
Brake line rear bracket with bolt attached to 12 bolt - Post 448
Brake master cylinder (found out later a re-stamp) – Post 129 & 796
Brake master cylinder and booster NOS 5/31/68 – Post 851
Brake master cylinder WT original vs. re-stamp – Post 1362
Brake master cylinder WT original rebuilt and valve with distribution block – Post 1365
Brake system directional block and valve restoration – Post 852
Brake system valve nut re-face (Note valve nut should be phosphate for ‘68, clear zinc for ’69) – Post 856
Bucket seat rail for seat in and out - Post 304
Bumper front installation – Post 1161
Bumper guards NOS – Post 114
Bumper rear NOS guards and installation – Post 1151
Bumper rear license plate light Bracket installation and light differences – Post 1146
Car Show: 11/2016 MCACN - Celebrity Pick Award winner – Post 1267
Car Show: 12/2016 East Coast Indoor Nationals December 2016 - Two awards – Post 1272
Car Show: 06/2017 Camaro Nationals, Gold – Post 1317
Car Show: 06/2017 Camaro Nationals judging demerits – Post 1329 & 1330
Car Show: 06/2017 Camaro Nationals judging demerits – Post 1349
Car Show: 06/2017 Camaro Nationals judging demerits – Post 1355 & 1360
Car Show: 11/2018 MCACN 999/1000 and Platinum Pick best stock Chevrolet – Post 1382
Car Show: 06/2019 AACA Senior award – Post 1398
Carb dated 7A1 List 4053 – Post 68
Carb manifold stud – Post 1087, Post 1111 & 1119
Carb manifold stud information (Stan NCRS judge) – Post 1189
Carb stud original ‘68Z - Post 592 & 1011
Car cover (have 4 of these) no longer available – Post 1157
Chromed original items - Post 757
Clutch bellcrank lower push rod - Post 791
Clutch fork #3892632 and spring - Post 590
Clutch fork hardware and GM number list - Post 683
Clutch fork spring and rod attachment issue with headers – Post 823
Clutch fork spring and rod attachment issue with headers fixed – Post 960
Coil spring tag Skip’s ‘68Z survivor - Post 540
Console gages original - Post 279
Console restoration pictures + (part numbers) and installed – Post 1138
Console special nuts #3792287 - Post 691
Cowl insulation under dash pad (NOS) - purchased 1979 - Post 414 & 419
Cowl insulation under dash pad (NOS) - purchased 1979 restored - Post 449
Cowl insulation under dash pad rubber plugs original #3868790 - Post 595
Cowl painted black - before paint Post 140 & after paint - Post 150
Cowl painted butternut yellow blend in - Post 243
Cowl panel seal #3927464 – Post 963
Cowl panel - Z28 stripe dimensions – original - Post 3 & 963
Cowl picture showing locations clips, lines, speedo, oil, grounds, etc. - Post 719
Cowl reverse backup light wiring to cowl connector - Post 726
Cowl seal #3927464 – Post 62
Cowl stampings PTB Post 692 & 698 (green)
Dash heater and defroster control panel restoration original - Post 775
Dash installed – Post 1111
Dealership script, Roger Dean added to car – Post 1265
Dimmer switch grommet original - Post 745
Disc brake caliper original 4 piston - Post 163 & painted Post 404
Disc brake distribution block and pressure regulation valve - Post 186
Disc brake hose bracket - Post 160
Disc brake hoses (NOS) - stenciled - Post 351
Disc brake mounting plate original re-plated - Post 249
Disc brake shoe kit #5470879 - Post 429
Disc brake pressure regulation valve ‘68 to ’69 – Post 877 & 880
Distributor cap D308/D308R - Post 594
Distributor original #1111266 dated 7A25 - Post 52 & 664
Distributor vacuum lines - Post 581
Door arm rest pads, original vs. PUI – Post 1080
Door glass hardware – Post 1053
Door handle gaskets (NOS) #1154551 - Post 377
Door handle original thickness vs. other years - Post 326
Door handle re-chromed and #9709600 push button - Post 374
Door handle ready for installation - Post 700
Door hinge area painted – Post 20
Door hinge bolts (3 different manufacturers) - Post 20
Door key lock and gaskets - Post 809
Door key lock original vs. Service replacements - Post 1379
Door latch originals and door latch rod covers - Post 508 & 1053
Door latches painted – Post 1068
Door light switches - original - Post 700
Door lock original push knob – Post 365
Door mirror taking glass out for re-chrome - Post 585
Door mirror original date code 10-DMI-7 - Post 43
Door mirror original restored and installed – Post 1161
Door rubber bumpers - original - Post 700
Door rubber bumpers (NOS) #4721222 – Post 1094
Door sill plates (NOS) with rivets purchased 1979 - Post 810
Door weather-stripping (NOS) – Post 1134
Door window cranks - Post 540 & 567
Door window cranks assembly after re-chrome – Post 881
Door window fuzzies - Post 1077
Drag link original blued - Post 208
Driveshaft paint markings after Evaporust bath - Post 271
Driveshaft paint markings installed – Post 1409
Driveshaft yoke - paint markings - Post 285 & restored Post 426
Driveshaft restored - Post 322
Drum brake hardware - Post 393 & 395
Drum brake wheel cylinders rear - Post 276
Emblems - fender (NOS) 302, bezel and Camaro – Post 959
Emblems - fender original 302 emblems Eddie had taken off car late 60’s – Post 1317
Emblems - trunk lid Fisher #7752901 - Post 1361
Emergency brake cables - Post 401 & hardware 413
Emissions sticker radiator support – Post 1187, 1188, Post 1238
Engine assembly #3830711 head gaskets, pistons, heads, etc. - Post 506
Engine cam, Crane blueprint specification – Post 1130
Engine compartment original ‘68Z (cook_dw) with air cowl plenum - Post 1004
Engine dress up starting - Post 582 & 608
Engine dyno sheet - Post 531
Engine head bolts original - Post 481
Engine mount #6258154 (not correct purchased 1979) - Post 484
Engine mount correct - Post 500 & Post 505
Engine mount hardware original vs. reproduction - Post 482 & 539
Engine oil pan drain hole “TR” bolt - Post 43
Engine painting at plant picture - Post 646
Engine piston original - Post 412
Engine stamping pictures - Post 168
Engine with transmission going in subframe - Post 735 & 736
Exhaust Gardner installation – Post 1168
Exhaust pipe hanger rear originals - Post 554
Fan shrouds, original vs. (NOS) Service replacement – Post 1087
Fender side marker bezel differences – Post 70 & 71
Flasher signal Stat 175 - Post 783 & 785
Fuel pump AC40524 used on ‘68 Z/28’s – Post 1260
Fuel pump original bolts - Post 201
Fuel pump plate, black or bare metal – Post 872
Fuses color coded – Post 1294
Gas cap locking (NOS) #986970 – Post 62
Gas cap originals riveted handle - Post 373
Gas cap originals riveted handle look added to NOS cap - Post 546
Gas pedal #3920296 review - Post 365
Gas line clip #3881339 clip with screw #3886522 & #3841230 - Post 586
Gas line clip #3881339 install how to - Post 608
Gas tank anti-rattle strips – originals - Post 269 & 1143
Gas tank filler neck cover and phosphate screw – Post 1014
Gas tank filler neck hose and hardware - Post 298 & 300
Gas tank filler neck hose hardware clamps original - Post 302
Gas tank filler neck installation - Post 1014
Gas tank installed – Post 1143
Gas tank sending unit original vs. #19179532 Service replacement - Post 520
Gas tank strap - original semi-gloss black - Post 251
Gas tank strap and bolts with nuts - Post 268
Gas tank strap original bolt vs. reproduction - Post 275 & Post 425
Glass quarter windows and trim – Post 1053
Glass windshield with rear glass and trim – Post 1127 & 1128
Glove box door Camaro script removal and parts – Post 905
Grille end bracket installation with rivet – Post 1144
Grille installation – Post 1117 & 1152
Grille matched for original look gray and painted – Post 1144
Grille prep for paint (NOS purchased 1983) - Post 957
Ground at gauge cluster housing (speedo/tach) - Post 1139
Ground strap screws #9420415 - Post 595
Hardware #124829 Z-bar nut – Post 1315
Hardware #272876 shackle nut phosphate – Post 1301
Hardware #3831892 - Post 427
Hardware #3873852 beside #3747933 carb studs – Post 1013
Hardware #3933052 10-24X1/2” AMK correct – Post 945
Hardware #5959164 rear tail-light screws – Post 980
Hardware #9418962 console screw – Post 1043
Hardware #9420415 ground strap screws – Post 595
Hardware #9780422 three different suppliers - Post 748
Hardware and fastener list by part number - Post 1253
Hardware- fender clips - Post 302
Hardware spoiler – Post 1087 (Found later to be acorn nuts!)
Header gaskets made as GM originals - Post 508 & 1301
Header GM hardware - Post 1308 & 1309
Headers-Kustom reproduction - Post 263 & coated Post 279
Headlight buckets original restored – Post 1119
Headlight electrical connectors original - Post 309
Headlight T3 date stamping original – Post 39
Headlight T3 testing - Post 884 & installed Post 1152
Headliner installed - Post 1080
Heater box and core dated 67L - Post 485
Heater hose – Post 995 & NCRS information Post 1042
Heater hose with GM logo picture taken Summer ‘68 (cook_dw) (Note: Heater hose for 68 used GM logo & by early 69 models changed to grooved) - Post 1004
Hood bumpers - original vs. reproduction - Post 1073
Hood hinge #3910668 comparison original to Service replacement - Post 269 & 270
Hood hinge to fender screw differences – Post 1254, 1255 & 1256
Hood hinge and latch restored - Post 361
Hood hinge hardware #9419301 - Post 480
Hood latch parts - Post 256
Horn relay restored - Post 148
Horns restored by horn works - Post 170
Horn screws original zinc - Post 413
Hose clamp original - Post 365
Idler arm original #3917581 and seal #5693027 – before and after - Post 204
Ignition coil bracket original vs. Service replacement - Post 413
Ignition coil comparison - Post 492
Ignition switch - pick it when you have no key – Post 1379
Inner fenders NOS - layout for A-Arm flaps - Post 1020
Inner fenders NOS - drilling for stapling rubber shields & making staples – Post 1045
Intake manifold bolts shouldered and non-shouldered - Post 581
Intake original #3017610 restored - Post 664
Intake oil fill tube cap - original vs. Service replacement - Post 369
Intake thermostat housing – Post 37
Interior bucket seat catch stops restored – Post 1251 & 1261
Interior carpet installation front – Post 735
Interior carpet original tag – Post 4
Interior door panel fuzzies (NOS) vs. reproduction – Post 1143
Interior door panel installation – Post 1156 & 1157
Interior lace vs. reproduction – Post 1191
Interior (NOS) package tray #7666129 – Post 1134
Interior pillar post seals original – Post 349
Interior rear view mirror original restored – Post 1140
Interior sail panels re-glued and installed – Post 1097
Interior seat belts – original - Post 1142
Interior seat belts - original Model 137 vs. Model 177 – Post 1183
Interior seat rear - Al Knoch issues – Post 1191
Interior seat rear - correct burlap and spring & view from trunk – Post 1251
Interior seat rear - correct original cover installed – Post 1297
Interior seat track hardware original restored – Post 1191
Interior sill plates (NOS) purchased 1979 with rivets – Post 1191 & 1232
Interior window - vent knob repair and put back on after chroming – Post 1303
Judging Bow Tie results – Post 1232 & 1238
Keys-Briggs & Stratton - Post 304 & 1249
Kick panels OER installed - Post 709
Leaf spring bushing - front #362108 - Post 441
Leaf spring comparison original vs. reproduction and installed - Post 441
Leaf spring hardware original - Post 402 & Post 441
Leaf spring J-nuts safety issue - Post 465
Leaf spring - rubber #3908370 for spring eye - Post 186 & Post 441
Leaf spring shackle plates restored - Post 442
Leaf spring stampings - Post 201
License light fixture removed - Post 275
License light fixture original restored vs. Service replacement - Post 667
Mirror - rear view original and Paragon replacement - Post 214
Muncie shift ball with Knob (NOS) #3922525 – Post 1138
Muncie shifter boot retainer ring screws – Post 1077
Muncie shifter bracket original bolts installed – Post 1408
Muncie shifter nuts with washers attach rods to transmission - Post 748 & 750
Muncie shifter original Niagara orange cap - Post 378
Muncie shifter original handle re-chromed - Post 374
Muncie shifter rods BB vs. SBC - Post 409
Muncie shifter with console (under cover) – Post 1020
Muncie shifter with stabilizer bar (Note: there were 3 different stabilizer bars used between engines and transmissions) - Post 385 & 409 & 859
Molding reveal – Post 1077
Nova L78 came home again - Post 674
Oil dip sticks ‘68Z two versions – Post 1041
Oil filter PF-25 original with embossed bottom - Post 328
Oil filter PF-25 and PF29 - Post 666
Oil Filter PF-29 correct for 1968 - NOS vs. Repro – Post 1312
Oil filter stenciling - Post 677 & 680
Oil pan differences original vs. Service replacement - Post 412
Oil pan ready to paint - Post 472
Oil pan splash shield original round hole - Post 412
Oil pressure line and fitting link to CRG – Post 830
Oil pressure line fitting to block – original – Post 845
Oil pressure line fitting installed - Post 902
Oil pressure line routing – Post 1020
Paint – 1st step, Lonny washing to prepare for paint - Post 174
Paint – 2nd pictures of body after wet sand and buff - Post 289 & 290
Paint primer steps – Post 79, 85 & 97
Paint Z/28 stripes layout – Post 1084 & 1087
Paint Z/28 stripes original parts – Post 3 & 963
Paint Z/28 stripes painted on – Post 1144
Parking light bulbs – Post 1146
Parking light fender bezel - Post 373
Parking light grille original housing, lens, screws and gasket - Post 334
Parking light quarter panel installation and bolt up – Post 1014
PCV - ventilation valve spun correct vs. Service replacement - Post 369 & Post 633
Plastic scratch remover “Novus” - Post 634 & 639
Plugs rubber rear quarter original #4805844 - Post 419 and #4802102 Post 590
Plugs rubber rear quarter original installed – Post 979
Quarter window glass and seals original - Post 596
Radiator cap RC-15 original vs. reproduction - Post 369
Radiator cap RC-15 original 68 and 69 restored - Post 508 & 1098
Radiator clutch fan stamped 11 2 67 SC - Post 258
Radiator petcock original ‘Weatherhead Company’ - Post 298 & 1094
Radiator tag original - Post 202 & 1094
Radio speaker AM front original - Post 578
Rag joint - ‘68 original on left ‘67 Corvette right one - Post 140
Rag joint restored - Post 163
Rally wheel DF showing two kinds font - Post 430 & Post 607
Rally wheel paint #1403 Krylon dull aluminum to argent silver - Post 520
Rally wheel with tire micro weights - Post 285 & Post 335
Rally wheel with trim ring and centers (NOS) 1980 – Post 1173
Rally wheel valve stems - Post 566 & Post 575
Rear 12 bolt air vent - original vs. reproduction (nice) – Post 819
Rear 12 bolt bumper rubber and hardware installed - Post 442
Rear 12 bolt stamping BV 1129 G1 - Post 169
Rear 12 bold hardware - #3930052 cushion and installation - Post 445
Rear 12 bolt ring gear dated 11/67 and axles – Post 116
Rear 12 bolt U-bolts - Post 429 & Post 441
Rear 12 bolt yoke - Post 369, with like new slinger - Post 377
Rear glass interior trim painted – Post 979
Roger Dean emblem – Post 848
Rocker panel molding (NOS) – Post 78
Rust Prevention Magic - Post 375
Seal #3921853 and clip (LH) below master cylinder – original – Post 957
Seal #3921853 and clip (LH) below master cylinder installed – Post 963
Seal seamer - cowl - Post 140
Shock absorber rear and cap – Original – Post 979
Shock absorber rear installed picture – Post 1409
Smog pump set-up (not used) - Post 319
Spark plug wire loom - left side - Post 373 & 979
Spark plugs AC43 comparison - Post 300
Speedometer cable CA and FB plug original - Post 510
Speedometer cable clips original - Post 511, 523 & 1408
Spoiler front – Post 1158, 1170 & 1252
Spoiler front screw location with dimensions to AIM for reference – Post 1252
Spoiler front screws – phosphate – Post 1301
Spoiler rear installed with acorn nuts –Post 1170
Spoiler rear acorn nuts original 7/16 inch height – Post 1330
Stabilizer link hardware differences - Post 195
Stampings body panel parts - Post 138
Starter brace original vs. Service replacement - Post 565
Starter painting per John Pirkle Jr. and NCRS link - Post 627
Starter solenoid cap brown vs. black - Post 630
Steering arms and knuckles #3902519 and #3902520 original markings - Post 155 & Post 156
Steering box nut and washer – phosphate – Post 1302 & 1407
Steering box original with RSC cover bolts - Post 253
Steering box original with date code 3567 (12/22/67) - Post 594
Steering knuckles restored with paint markings - Post 262
Steering rag joint installed - Post 800
Steering tie rods – Post 1176
Steering wheel original – Post 936 & 937
Subframe – Post 105 & 107
Subframe assembly - Post 287
Subframe body mount - #3901361, #3928380 and #1408366 – Post 158
Subframe body mount washer #3901365 - Post 365
Subframe bolts originals restored - Post 252
Subframe bolt and washers as installed - Post 795 & 1409
Subframe mount #3 taping - Post 262 & 1301
Subframe mounts to body and install - Post 752
Subframe painted - Post 138 & Post 140
Sunvisor brackets original re-chromed - Post 374
Suspension and steering component finished pictures – Post 1407 & 1408
Tachometer Tic-Toc-Tach original - Post 279 & Post 335
Taillight bezel gaskets - original - Post 275
Taillight bezel installed – Post 1014
Taillight bezels re-chromed - Post 374
Taillight bezels restored - Post 513
Taillight bulb connectors original - Post 310
Taillight lens wick, seals and screws #5959164 – Post 980
Temperature sending units (three types) – Post 1098
Temperature sending units (original type) and connector – Post 1111
Timing gear cover original bolts - Post 201
Tire - Goodyear Wide Tread January ‘68 dated - Post 535
Tire pressure sticker - original on glove box door – Post 52 & 905
Tire jack shaft re-plated - Post 249
Tire valve stem length and “Schrader” cap - Post 535
Transmission bell housing original (Note paint & yellow crayon mark) – Post 36
Transmission cross-member Muncie shifter - Post 302 & & 361
Transmission drain plug “W”- Post 45
Transmission rebuild – Post 126
Transmission reverse back--up light switch cover plate - original with stamping – Post 902
Transmission reverse back-up light switch holder #3864296 original - Post 397
Transmission reverse back-up light wiring to cowl connector - Post 726
Transmission shift levers and AIM back-up switch - Post 714
Transmission stamping P8T29 December 29, 1967 – Post 45 & 231
Trim - wheel well and rocker spears (#3904540) installed – Post 1151
Trunk bumper jack shaft re-plated – Post 249 & 1187
Trunk bumper jack UN hook – Post 1187
Trunk gas tank neck cover - original - Post 251
Trunk lid Posi glued and jacking instructions on – Post 1161
Trunk lid - removal of washer marks - Post 350
Trunk lid rubber bumper #4721222 – Post 86
Trunk lock retainer and screw – Post 1048, 1053 & 1065
Trunk shock cap original vs. reproduction - Post 423
Trunk spare tire holder and original wing nut vs. reproduction – Post 1187
Trunk spatter 1st attempt (wrong) - Post 243
Trunk spatter 2nd attempt (correct) – Post 964
Trunk weatherstripping - original type with string and later NOS – Post 1098
Trunk wiring harness clip installed – Post 1068
U-Joints originals – Post 861
Upper control arm washer - original to reproduction - Post 241
Valve cover grommet #14091870 - Post 626
Valve covers (NOS) purchased 1979 - Post 483
Vin hidden cowl – painted - Post 10 & 150
Voltage regulator restored dated 7M - Post 148
Water pump by-pass hose being painted - Post 941 & 964
Water pump original hose fittings re-plated - Post 249
Water pump Zinc fittings ground strap with heater hose elbow - Post 1309
Wheel house preparation – Post 106
Wheel stud - original - Post 182
Window sticker reproduction – Post 1261 & 1265
Windshield washer bottle cap and hose original – Post 327 & 1119
Windshield washer pump original #4912365 vs. later #4919332 - Post 225
Windshield washer pump restored - Post 270
Wiper arm blades correct -Post 886, 895, 898 & 899
Wiper arm mechanism before after Evaporust - Post 258
Wiper motor original dated 35167 - Post 520
Wiper motor original #5045441 and how to test – Post 900
Wiper motor original #5045441 and stenciled date code – Post 902
Wiring harness - engine connector (has wrong yellow zinc bolt) - Post 809
Wiring harness - engine connector with correct clear zinc bolt – Post 820
Wiring harness engine - original alternator boot, push in pins black - Post 344
Wiring harness - engine - original push in plugs black – Post 1119
Wiring harness junction block - original restored - Post 366
Wiring harness - trunk original vs. reproduction - Post 311
Wiring harness - trunk installation of clips – Post 1014
Wiring harness - trunk ground screw Zinc – Post 1014
Wiring harness - trunk ready for installation - Post 501
See less See more
3
#1,352 ·
Sure.....was wondering what thehole in the firewall looked like
Wanted to fab something up out of aluminum thats similar but not stock..
whats left of my AC from my 67 a body .You get the idea....think it may work?
Think the cowl is more functional than the hood (has a 69 Z skin on it can you tell I like camaros lol)
#1,355 ·
Next up, the mysterious door mirror.
During Legends judging two of the judges called me over and asked about our outside door mirror which in response I communicated it was the original that was re-chromed and has a October 67 date code on the glass. I had taken out the dated glass by soaking in mineral spirits for a couple days. They showed me ours had no mold line normally noted and the only thing any of us could think of was it must have been buffed off during chrome preparation, thou that would take a fair amount of time to complete and one might think it would end up with more of a flat area.
Our mirror base showing the underneath part # and the top area where one would normally see a mold line.
My assumption that the mold line was taken off at the chrome platters kind of changed or at least cautioned when I observed a very original un-molested Lemans Blue 21K mile 68 Z/28 being judged in that always great survivor class at this years MCACN which just happened to have the same looking door mirror base as ours.
To be honest I’ve never looked at mirrors on cars prior looking to see if the mirror had a mold line or not but I am now. Can anyone looking at this thread look at your original mirrors and communicate if you have one without that mold line. Reproductions have the mold line that I’ve looked at.
#1,356 ·
Chick,
Here are some pictures of my original mirror (1st and 2nd picture) and also of my NOS Service Replacement mirror (3rd and 4th picture). Both have the mold line.
#1,357 ·
Thanks Bob and yes, by far what your going to see is some amount of mold/cast line but now since I noted the same type of mirror as ours without that mold line I thought I'd reach out to see if anyone else has one or? Again, I could just assume the chrome platter took it off preparing the piece for chrome but it had no pits or reason to work that area that would have removed that plus the platter has restored many of these mirrors in the past. Bottom line, since I saw the mirror on the survivor it seemed logical to do a little more investigation. Everyone, check your mirrors! :)
#1,362 ·
Next up on the demerit list from judging was an item that really caught me off guard. As in any car being restored there is usually something here and there that is missing, changed, or was taken off, etc., and our 68Z was no exception. One of the few parts that had been replaced was the Master Cylinder so reaching out I procured a WT stamped 5460346 rebuilt and ready to go. What the judging report told me when received was that WT stamped master cylinder I had purchased in 2010 and had on our car was a re-stamp. Dang, that stung! I had taken so much time reviewing parts and working to become somewhat knowledgeable but since that was purchased from a reputable source I never checked or reviewed what a legit WT stamped master cylinder should look like. Well know now and want to pass on the lesson learned but first I want to communicate the reputable source I purchased that now known re-stamped master cylinder from is giving me a 100% refund.
You know I’m sure I had a close up picture of that stamping on this build thread showing the tab where stamped was machined and stamped after being painted, other words, the tab area should be void of any paint. Wish it would have been caught early and saved some work and frustration. Now let’s take a look at the stamping on this re-stamped master cylinder. Look at the W and the T! No doubt about it, it’s a re-stamp.
A good friend of mine in a sunny state let me know he had purchased a few master cylinders at an estate sale and sold me this legit WT 5460346 for what he had paid for it. Thank you Mike! I’m planning on re-building it (will send it out) and then making the swap. Look at the W & T combo and note the difference in the stamping!
Hopefully this above info might help someone else from making a bad decision.
#1,365 ·
Had White Post Restorations rebuild the correct WT stamped master cylinder I had obtained from a friend. White Post has completed a couple rebuilds for us and have been happy with the results. They have a simple procedure where you download an “instruction & to do” sheet to fill out that also lists prices. I also sent back our valve as it’s been weeping at the back under the rubber cover. Note they did not restore that prior but was informed the reason for leaking was a seal issue and this brings up a good restoration point. I had my brake items restored years before they were ever installed but will not do that in the future as I think it might be advantageous to wait until closer to the needed install time. I did note on their “to do” sheet not to paint as I wanted to complete the paint step on both pieces. Originally the master cylinder was painted black and then machined so those smooth surfaces along with the machined tab with the stamp should be void of paint. In the package of our Master Cylinder and valve was a sheet White Post supplied with their “often asked questions” that stated they recommend Dot 3 or 4 brake fluid and not synthetic. In fact, the use of synthetic nullified their warranty. Geez, everyone I know in cars restored utilize synthetic brake fluid. Maybe I’m missing an issue here!
Getting back to the brake upgrade I decided to also remove the distribution block off the car and remove the black paint. Upon my inspection of our original block it had remnants of paint but Judging hit it for being painted and said it should be natural so now was the time to complete. The block before and after and parts ready to install. The block is bare metal and I have it coated with a rust inhibitor.
#1,363 ·
Very pleased to announce that Chick has accepted our invitation to join us with his '68 Z for our Class of '68 Invitational display at the Muscle Car and Corvette Nationals show, November 17-18.
Knowing that this is without a doubt one of the best '68 Z's in existence, we are honored to have Mr. Renn joining us.
Please make a point of checking out this beauty at the show and saying Hello to Chick!
Bashton
MCACN Managing Member
#1,364 ·
Thank you Bob for both the invite and the kind words concerning our 68Z. I've attended the past four MCACN events and without a doubt it's the best muscle car gathering I've ever witnessed. Look forward to attending in 2018 and being part of that "Class of 68 Invitational" display.
#1,368 ·
Very nice! Good info as usual.
Thanks Jim and Ryan! Jim, come out to this years Muscle Car and Corvette Nationals (MCACN) and spend some time with both the car and myself. The cars more interesting (LOL) but great to meet folks from the forums. This will be my 5th consecutive year attending the show and honestly its the premiere show IMO and look forward to both the cars and friendships.
On another note I recently found the bail wires on some master cylinders are different in height. When I purchased the correct WT stamped 5460346 master cylinder aforementioned it did not have bail wires to hold the lid. No big deal I thought since I had a couple spare 69 model 5468309 master cylinders but when I took a pair off to use I quickly found those 309 bail wires did not even touch the lid. I then checked a master cylinder off a 67 Corvette non power assist 5455509 and the bail wires were the same as the 346. Friend gave me a GM part # 5455518 bail wire and that does fit the 5460346. Another good friend sent me a spare pair to utilize and I owe him a cold one or two. LOL The repro of that GM part # 5455518 is sold by most of the Corvette parts houses.
Here you see the difference:
#1,369 ·
I have several detail things I will be hitting on in the next month, one being helping a friend with his 68 Camaro locks with our local guru and some things to look for plus a brake update, and would like to detail some hardware correctness underneath that might help others in restoration but first this:
Hemmings Muscle Machines August Edition will have our 68Z in a "Restoration Profile" article. The July issue came out last week so it will be the next issue out in approximately three weeks.
#1,371 ·
Hi Pete! First off, do you have console gauges? If so, the sending unit pictured by itself (not the one with threaded end or top hat looking) should be what you need and the lead for attaching to that sending unit is around mid inner fender on the drivers side. Does that help you? That type of sending unit (repro) are sold by many of the Corvette part houses.
#1,375 ·
Thanks Vince! How come the CA gang are receiving their copies before us Eastern dudes? LOL! A friend in CA sent me an email today that he enjoyed the read yet I have not received our monthly delivery. This weekend was Carlisle's now called "Chevrolet Nationals" and we had the 68Z in their "solid lifter display" and while there I visited the Hemmings agent selling subscriptions to their magazines and they had the new August issue of Hemmings Muscle Machines and he gave me a copy. For those that might want to purchase a copy it's a six page article in their monthly "Restoration Profile."
Thanks again Vince!
#1,378 ·
I have most of this info somewhere in the build thread but since I was answering another thread with the below info here it is again on how to make A-Arm Staples and use of needle nose pliers to obtain original looking circular bend.
In the past members like JohnZ stated the factory used 16 gauge plain steel wire and its easy to bend/form with a pair of flat pliers and bend with a pair of needle nose pliers to obtain the original look. I did not use stainless on our restoration due to judging deductions. KevinW pointed out in threads you may want to open the original holes up one drill size to assist with assembly. I had GM NOS inner fenders so I marked where original holes were along with angles and made a template to drill but for the staples “here is what I did!”
With JohnZ’s comments in hand I measured the width of original staples and found a pair of pliers I had very close to their width and with a little grinding and measuring bingo, I had a simple tool to make the staples width but what about the length of the two outer lengths, the ones that you will be working to curl to give the same look as originals? That I had to play with and experiment with both that length while practicing the forming with the needle nose pliers. If your just going to bend that leg over flat then guess it does not matter but its not difficult to bend the staples to a circular bend with an original look, but a little practice goes a long way. I started by bending the first 90 degree angle but the length that goes thru the inner fender and A-arm flap to be bent was longer than needed for trimming to length at the end. Immediately after bending the 1st 90 degree bend I made the 2nd 90 degree bend but to assist with making bend a crisp 90 degree I placed the staple being held with that pair of pliers in a vise and made a simple press operation. After the staple was formed I then used a side cutter to trim the two lengths to the desired length that was going to work for the final look. It is most important that while forming the circular bend with needle nose pliers that someone or something holds the staple in place securely on the other side or you'll end up pulling the staple down past the 90 degree bend and losing that crisp look.
The pliers and forming of the staple:
What an original bend looks like:
One of my staple bends duplicating the original look:
One of our 68’s inner fenders when completed:
#1,379 ·
Sorry for the delay in this info I’ve been wanting to post about keys and locks. Some info is a repeat but some is new from recently helping a friend with his 68 who purchased the car with no keys. Correct keys for a 68 are coded C & D. When looking at a lock one should know what a clear sign of being correct looks like. If the lock does not have the extended section as shown in the photo arrow and only a rectangular slot it is not technically correct and easily picked out by a judge.
What we found out was the door locks and ignition switch did not match key wise so either the door locks or ignition or possibly both came from another donor. No problem for our trusty local locksmith as he drilled a small hole enabling him to pick the lock so internal parts could be coordinated to match a key now cut for the doors.
Here you can see of the internal parts that make up the internal part of a lock.
One of the door locks had the outer retainer already replaced and the other needed changed due to a dented retainer. Note original lock outer bezels had a type of pressed on 360 degree bezel. After carefully prying an original bezel off the correct looking replacements have 4 tabs to bend over to attach. Once installed in the door no one would know the bezel has been changed.
As most of us know a 67 key will not even enter a 68 lock and vice versa but any cut 68 key will enter a 68 lock but that is all it will do unless the key and lock have been matched to work. Keys for 68 are coded C & D. In this case the friend had an old NOS 68 service replacement glove box lock and since the trunk lock and keys had been matched there needed to have a process to match up that NOS glove box lock to match the trunk key? Well my locksmith friend showed me! He placed the 68 trunk key in the 68 NOS glove box lock and prepared to cut off all the parts (I will call them tumblers for not knowing the correct name) that came out of the cylinder when key was entered. That is what’s needed to be removed. One could use a hack saw and file but this tool is all encompassing and completes the job. Bingo, once cut and cleaned the key can be inserted and then turned to lock the glove box.
Mentioning the cut of keys is interesting as well as our trusty locksmith has an original punch cut tool enabling him to cut new NOS keys as they were back in the 60’s. And yes, he did our keys for our 68Z and even stamped the punch outs with the code on the spares. Of course I’ve much simplified the process but tried to give an overview.
#1,381 ·
Hi Jerry, can you send me a picture of your orig. Rochester Products "D" key. I've heard of them being used but do not remember them back in the day. As you know having one they are very similar to the B&S keys since B&S had them being made under license to Rochester. For anyone interested in some great info and picture of early keys check this out. And I will ask our locksmith who's Dad was a locksmith if he knows of any "D" Rochester available blanks.
More to a GM key than I first thought.
#1,382 ·
This past weekend we had the pleasure of attending the Muscle Car & Corvette Nationals, our 5th MCACN, as our 1968 Z/28 had been invited to be in their “Class of 68 Invitational Display.” This year the MCACN show celebrated it’s tenth year and the cars exhibited just keep getting better and better and one has to wonder where they all come from. The automobile I liked best was a yellow 67 L88 Corvette supposedly still housing it’s original born with 427. Wow! Our 68Z garnered a 999 out of 1000 as they found a very small piece of masking tape along a front ridge of the hood. Now how did I miss that? LOL After judging concludes I was told judges communicate their top judged car/s which enables another group of judges to review the cars after hours to determine the overall best stock Chevrolet among all those Camaro’s, Chevelle’s, Nova’s, etc.. What a moment when they announced my name to come up and accept their “Platinum Pick Judges Choice-Chevrolet Stock” especially when this show is one of if not the premiere muscle car show in the country. Difficult to describe the rush of appreciation and then remembering the team of friends and vendors that made this possible. Huge thanks to East Coast Muscle Cars and my always there assisting friends of Lonny and Skip. Said it many times, “I’m one lucky guy!”
#1,383 ·
Congratulations Chick. It was great to see you and the 68Z again. The award was well deserved and you are indeed a lucky guy to have Skip and Lonnie in your corner indeed. Great stand up guys with a wealth of knowledge. Who could ask for more. Looking forward to seeing you next year and keep up the great work
#1,387 ·
Always a pleasure talking to my up North friends Mike and thanks for the kind words.
Car looks beautiful on display Chick. Being new to the car scene, that show looks worth traveling to see next year. Amazing pieces. Happy Thanksgiving. I’m grateful you preserved a piece of history.
Thanks Dan and yes, this is one to travel to. Need to talk to you about you know what. LOL
Chick great to see you and your car again. Congratulation's on two well deserved awards. These are not easy to come by and mean a great deal in the muscle car world. Your vast provided information and your car set a new benchmark. Thanks Again. George
Great seeing you George and us getting somewhat caught up. And a huge thank you for the compliments friend.
