68 Vert stored 21 years - Page 43 - Team Camaro Tech
Build Projects follow along start to finish
post #631 of 1068 (permalink) Old Jan 11th, 13, 12:04 PM Thread Starter
George
Re: 68 Vert stored 21 years
HELL YES I'm gonna drive it!
Sanding 400 wet
I can see this taking forever....
George Kettler
US ARMY Retired, Scouts Out!
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427, owner 23 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73 http://www.camaros.net/forums/showth...183654&page=68
kettbo is offline
post #632 of 1068 (permalink) Old Jan 11th, 13, 01:31 PM
Vintage 68's Avatar
Cool Re: 68 Vert stored 21 years
Sanding 400 wet ...
... I can see this taking forever....
It sure seems like it anyway
Looks like you're coming along quite nicely George
I would recommend a longer and stiffer block for those 'flat' doors and other areas
Unless these are preliminary blockings and you're still a couple coats away from final block ...
Seems like I always found issues later when using a small/thin block on dark/bright color vehicles - maybe one of the 'pros' can chime-in
1968 Convertible
Some trucks
Vintage 68 is offline
post #633 of 1068 (permalink) Old Jan 11th, 13, 01:58 PM
I would not use a thin flex block even on preliminary blockings.
Or anywhere through the process on straight panels.
Not sure where you are in procedure or how you are painting this car. Pieces or together. Longest block possible initially, and then the longest for final on a given area. If you are painting this in pieces the car gets jambed then final sanded.
Primer long dry blocked with 180 until straight, packed with 3 final coats primer, jambed, assembled, then wetblocked with 400 & 600 grit with 6" and 8" blocks. Now ready for sealer and color.
Sauron67MM is offline
post #634 of 1068 (permalink) Old Jan 13th, 13, 10:09 PM Thread Starter
George
primered 3 coats, long-blocked, found a few areas, fixed them
primered again 3 coats, long blocked, few more things turned up
primered WEDs last week,
George Kettler
kettbo is offline
post #635 of 1068 (permalink) Old Jan 14th, 13, 03:57 AM
Greg
Originally Posted by sauron67mm View Post
i would not use a thin flex block even on preliminary blockings.
x2
My 69 Build thread : http://www.camaros.net/forums/133-build-projects/211427-20-year-69-project.html
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #636 of 1068 (permalink) Old Jan 14th, 13, 09:56 AM Thread Starter
George
Greg,
I've not seen you post on this thread before. I'm on my second year on the Camaro. Year and a half on the body at AutoBody at a tech school in Tacoma. Teacher Doug for my class is a grouchy ol bodyman who has done more than a few show cars in the day. I swear he put dents in my car at night because he used to walk up, says "lookie here" on some new ripple I'd missed, etc. I'm not perfect but I am shooting for perfection in my first attempt at this. The teacher for the other class, Bill retired. New guy Joe is on board, comes from a shop specializing in Chevy Muscle cars. Paint guru by specialty, has a 69 Camaro Ragtop, several Chevelles. If I miss something, these two guys keep me straight. Anyway, now closing in on this, last full coat of primer is on the pig.
Yes, longboarded with 180 until I could not stand it any longer, then a few more weeks at it, more primer coats then repeat.
Yes, have some longer blocks I am using on the 400 wet sand, pics shows me with 6" soft pad
Yes, will do 600, that comes up next
Lot of metal flake in the Rallye Green paint. Have engaged Joe and Doug on painting the car apart in both booths, vs loosely together, vs jammed, assembled and gapped etc.
George Kettler
kettbo is offline
post #637 of 1068 (permalink) Old Jan 14th, 13, 11:32 AM
Vintage 68's Avatar
Wink Re: 68 Vert stored 21 years
It was impossible for me to tell if you have/had 'long' blocked the flat areas already and were just working on the 'cove' areas of the doors or not from just those few photos - thus my comment.
I often use a soft-pad or various shapes during first few blocks to get the detail area, prior to moving on to the big-flat(s).
1968 Convertible
Some trucks
post #638 of 1068 (permalink) Old Jan 14th, 13, 12:03 PM Thread Starter
George
John,
All good!
Have an assortment of blocks. Plus anything someone else might have that I do not.
Now getting dish pan hands from this wet sanding.Seems the more ya do, the more there is to do. Teacher Doug says stick with it, huge payoff coming. Thing is, each level of 'niceness' requires a lot of time. While glad I did not go quick and dirty, I fear the car will have such a good look that it will become a garage queen. LOL. Really wonder if all the extra time in the hood and decklid will be for naught after a few months of use, or some loser putting a door ding into my body panels.
I am hoping for Sauron-like effect here, pretty sure I'll be 9/10 or better. I know now, mechanical work is far easier than body shop stuff
George Kettler
kettbo is offline
post #639 of 1068 (permalink) Old Jan 15th, 13, 02:57 PM Thread Starter
George
trying to keep the motivation up....dreadfully boring wet-sanding but I know I am closing in on this phase of the project
getting some shine after 600 grit
"acid test" of wax and grease remover sprayed down the door
really shows any ripples
it appears to my untrained eye that these take-offs are done, now to get after the shell, fenders, nose goodies
George Kettler
kettbo is offline
post #640 of 1068 (permalink) Old Jan 16th, 13, 05:39 PM Thread Starter
George
went around the car, passenger qtr, fender and all the dvr side today with 400 wet. whew. still have rockers, tail pan, lower nose takeoff metal, and wiper/cowl plate
George Kettler
kettbo is offline
post #641 of 1068 (permalink) Old Jan 16th, 13, 07:30 PM
69z28freak's Avatar
Looking great George. Now if it was me, right about now I'd take a left turn and build a Pete Estes '68 Z/28 convertible clone. It's a mild obsession I have!
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
http://www.camaros.net/forums/showth...ght=69+grandma
69z28freak is offline
post #642 of 1068 (permalink) Old Jan 17th, 13, 10:45 AM
Todd
6781camaro's Avatar
Looking great George! You probably already know, but is your header panel just loosely fit?
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too), '68 Conv. V8 4-spd Builder
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/133-build-projects/146455-69-coupe-ground-up-rotisserie-resto-nows-time.html
6781camaro is offline
post #643 of 1068 (permalink) Old Jan 17th, 13, 01:33 PM Thread Starter
George
Todd,
The front metal is just hanging on there by a thread. Yes, know the header is loose I had to give up 5 stands I was using for all my take-offs...ebb and flow of available stuff here in the shop. Teacher Doug said I had to share/play nice with the kids here
George Kettler
kettbo is offline
post #644 of 1068 (permalink) Old Jan 17th, 13, 03:53 PM
George, doing great work, I want to see the best code J paint, both mine came Ralley Green.
john68 is offline
post #645 of 1068 (permalink) Old Jan 18th, 13, 08:45 PM Thread Starter
George
things are getting exciting! posting waaaaay too much!
after a day with 600 wet, this is what I ended up with
now for the jambs, rockers, little of this, some of that...a few spots of primer a bit of sanding....
can just about pencil in a paint day John. Better warm up my VISA for cost of Sealer, Color and Clear!
George Kettler
kettbo is offline
Human Verification
