Round Two! '68 Coupe Ground-Up / RotoSS Resto! - Page 28 - Team Camaro Tech
Build Projects follow along start to finish
 2Likes
post #406 of 861 (permalink) Old Nov 17th, 12, 09:41 PM Thread Starter
Todd
6781camaro's Avatar
Re: Round Two! '68 Coupe Ground-Up / RotoSS Resto!
Originally Posted by stamatisg1977 View Post
On my way to work tonite I filled up a five gallon can of diesel fuel for my heater. Gotta do the brakes on my truck. Ill have the Hester blasting on me in the background
Steven
Nice... but does a diesel heater give off a rancid odor when running? Be careful inhaling that if so. Smells like a rotten egg-fart.
Honestly I miss the seasons up there, but could never move back right now. With 3 kids, it would be waaaaaay too expensive. Maybe later in life. Today it was 76 degrees and partly sunny here. Perfect day for Camaro work. Crazy weather for November huh? Don't work too hard at work. Save your energy for the Camaro!
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too)
, '68 Conv. V8 4-spd Builder
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
My build thread:
6781camaro is offline
post #407 of 861 (permalink) Old Nov 17th, 12, 09:44 PM
Steven
stamatisg1977's Avatar
Haha when I have it heating the garage I have the main door open a little and have the intake of the heater outside. It doesn't really smell that bad I just won't paint with it cause 1. Explosion risk 2. The elements that it produces can ruin the finish
Steven
69 Le Mans blue SS X55 soon to be LS3
Tremec TKO 600
When Am I Gonna Be Done?!
Follow my journey here:
Here to help and be helped
stamatisg1977 is offline
post #408 of 861 (permalink) Old Nov 18th, 12, 05:38 AM Thread Starter
Todd
6781camaro's Avatar
Good point there. Be careful. Can't wait to see your Camaro in color again.
My build thread:
post #409 of 861 (permalink) Old Nov 19th, 12, 08:41 AM
Tim
Send a message via AIM to Tim1968
looks great bud! i had a great time workin on the 'maro with with you. sorry i had to bug out early but you know how it goes, when the boss says get home thats what you do...happy wife, happy life. looks like ill have 7 days off on december and i think we will be gulf coast bound for family stuff, so im sure we could get at least 2 good work days in. Good job on the floor, im glad it cinched up to where it needed to be...those 1/4s should next on the chopping block....maybe even get her rolling?!
Tim
1968 Chevrolet Camaro - getting new sheetmetal at the moment -
'12 Chevy Cruze - Daily Driver
Tim1968 is offline
post #410 of 861 (permalink) Old Nov 19th, 12, 09:07 AM Thread Starter
Todd
6781camaro's Avatar
Thanks Tim! Yea-- it was nice having some helping hands and company. Worked out great! Just came in from plugging the firewall to floor seam now. Really happy with it. Just need to reshape the radii on the firewall tranny hump now to match the new floor. It's a little too rounded there from dollying it without a reference of the new floor in place. Easy fix! Looking forward to hanging again. 'Till then, keep up on the thread and you'll see what I'm up to... Looking to weld in the roof braces next!
My build thread:
post #411 of 861 (permalink) Old Nov 19th, 12, 11:01 AM Thread Starter
Todd
6781camaro's Avatar
Ran out of time, but got 2/3 of the front seam done. Either I need to continue stretching out the corners of the firewall edge, OR/and make a relief slice on each top radii (corner) of the trans tunnel to close the radii more so they meet there. Most likely both will be needed. I'll first flip it over (rotisserie) and work those corner radii, then if they do not reshape enough, I will then make the slices on the new floor to close those corner gaps (only 1/4" but we know it shouldn't be there.. So either the trans tunnel on the firewall was once reshaped in the past, OR they stamped this trans tunnel on the new floor a little too tall towards the front. I'll get 'er done! Stay tuned!
Here you can see the 1/4" gap along the trans tunnel portion of the seam. I will reshape that and/or slice the new floor so it meets flush there.
My build thread:
post #412 of 861 (permalink) Old Nov 20th, 12, 05:40 AM
Jeff
Looking good!
fordpowerjoke is offline
post #413 of 861 (permalink) Old Nov 20th, 12, 05:42 AM Thread Starter
Todd
6781camaro's Avatar
Thanks Jeff!
My build thread:
post #414 of 861 (permalink) Old Nov 20th, 12, 09:13 AM
Steven
Great work Todd. Are you planning to spray your sound deadening or use the sheets? If sheets are you going for full coverage or uses strips in certain places?
Steven
Tremec TKO 600
post #415 of 861 (permalink) Old Nov 20th, 12, 12:09 PM Thread Starter
Todd
6781camaro's Avatar
Thanks! Hmmmmm... most likely will use either Hush Mat or Dynamat in sheets where effective.
Here's where:
  1. under the seat mount brackets before welding them in
  2. covering each inner wheel well tub
  3. trans tunnel and main floor sections (quadrants where feet sit)
  4. firewall under the factory insulation pad
  5. outer door shell surfaces in strips
  6. roof panel
  7. package tray surface
  8. trunk floor in sheets
  9. inner quarter panel surfaces as much as possible
I've installed Hush mat in my brother's 2006 Honda Accord and I can definitely say I was impressed as to how effective it was. Amazing before and after difference in noise levels. I've used Dynamat as well, but mainly for audio system installs, not a full resto like this...
I may also spray the underbelly of the entire shell, including the outer wheel wells, with lizard skin to protect and sound deaden it even further from the outside. That should make a huge difference... It's quite far into the future for me, but that's my plan.
My build thread:
post #416 of 861 (permalink) Old Nov 21st, 12, 02:53 PM Thread Starter
Todd
6781camaro's Avatar
Alrighty then... The Floor is in! LOTS of plugwelds and I busted out my arsenal of locking pliers today! I even fitted and screwed in the seat track mounting frames--- just need to punch out and drill the plug welding holes on those and they will be done Friday!
I was able to hammer and dolly the trans tunnel both on the floor and the firewall to make it match without slicing either. I also used the heat of the plug welds to help shrink the top corners of the floor around the trans tunnel to make it fit snug there! While it was red-hot at the corners, I gently tapped them and rounded them down with a body hammer to shrink them into position snugly... (these tips and tricks on this site come in handy if you remember to use them.) Thank you guys for helping!
My build thread:
post #417 of 861 (permalink) Old Nov 21st, 12, 03:36 PM
Tim
Looks great Todd. I am experiencing a bad case of ROTISSERIE ENVY!!! I've been crawling under the car to grind down the welds. PITA!!!! You make it look too easy!
Tim
My 1968 convertible build:
tjgimp is offline
post #418 of 861 (permalink) Old Nov 21st, 12, 03:58 PM Thread Starter
Todd
6781camaro's Avatar
Rotosserie envy-- lol! Muhahaahhaahaaaaa! I know--- sorry about that. I feel for ya... not easy without it. It does make it alot easier to access everything on the car. (and for emptying out all the black beauty after blasting!) I appreciate the kudos Tim! Having fun down here now... If I only had more time!!!!
I already cleared this Friday with the Mrs. so I can weld in the seat track mounting brackets.
My build thread:
post #419 of 861 (permalink) Old Nov 22nd, 12, 07:50 PM Thread Starter
Todd
6781camaro's Avatar
Wishing everyone a Happy Thanksgiving! I think I ruptured my gizzard from eating so much!
Now let's get back to work! It's almost Friday-- time to get back on the plugwelding gig for me! A new pair of bucket seat mounts is waiting for my '68. Here we go!
My build thread:
post #420 of 861 (permalink) Old Nov 23rd, 12, 07:48 AM
Steven
Happy thanksgiving Brotha. In a little bit I'm gonna start tackling the front coilover conversion. Can't wait lol
Steven
Tremec TKO 600
Human Verification
