Oh no - another '69 Z/28 project... - Page 8 - Team Camaro Tech
Build Projects follow along start to finish
post #106 of 118 (permalink) Old Mar 23rd, 16, 10:45 AM Thread Starter
john
camaro_z28_1969's Avatar
Re: Oh no - another '69 Z/28 project...
I had the 'new' bucket seats and my original rear seats and arm rests re-upholstered so they'd match. He did the pleats and piping similar to the originals. We couldn't find the dark green metallic vinyl to match the factory colors, so I picked this color. It's not a perfect match, but I think it'll work.
ID:	142682   Click image for larger version
ID:	142690   Click image for larger version
1969 Z/28 - owned since 1971 - garaged since 1985 - in process of restoring it
camaro_z28_1969 is offline
post #107 of 118 (permalink) Old Mar 23rd, 16, 11:06 AM Thread Starter
john
I had an engine built locally. It's a 383, with roller lifters, and original-style rocker arms so I could use the valve covers Jerry McNeish restored for me. It has aluminum heads, and I had the engine painted chevy orange to keep the original look.
I had a set of blackjack alumi-kote headers I bought decades ago brand new still in the box that I put on it. You can also see my original brake booster Jerry also restored.
The transmission is my original Muncie that I had rebuilt by the same guy that rebuilt my original rear end.
I did a test fit of the original inner fenders just to see how everything would look.
Name:	camaro_z28_1969-albums-engine-compartment-photos-picture25210-img-20140510-111544.jpg
ID:	142706   Click image for larger version
Name:	camaro_z28_1969-albums-engine-compartment-photos-picture25218-img-20140512-140539.jpg
ID:	142714   Click image for larger version
Name:	camaro_z28_1969-albums-engine-compartment-photos-picture25226-img-20140512-175109.jpg
ID:	142722   Click image for larger version
Name:	camaro_z28_1969-albums-engine-compartment-photos-picture25234-img-20140512-184419.jpg
post #108 of 118 (permalink) Old Mar 23rd, 16, 11:11 AM Thread Starter
john
I stripped and cleaned my original emblems, then repainted them using the One Shot sign paint.
ID:	142746   Click image for larger version
ID:	142754   Click image for larger version
ID:	142762   Click image for larger version
post #109 of 118 (permalink) Old Mar 23rd, 16, 12:05 PM Thread Starter
john
I found out about a guy that does mobile bodywork - he comes to my house and works on the car in my garage for an hourly rate. And I schedule when I have the time (and money) to have him come over to work on it. Since I had bodywork that I didn't have the knowledge/expertise to do, this worked out great for me. I could help with various projects (metal prepping, sanding, etc) and he does the more difficult things. Here's some pics of the bodywork on the bare metal.
The biggest concern I had at the beginning when I started stripping the car was the 'repair' that was done before I bought the car in 1971. It appears the original owner wrecked the car, taking out the driver's side quarter panel, and putting a dent in the driver's side front fender. What someone did to repair these was to cut off the vertical section of the quarter panel from the door to the rear panel, and from just below to top of the quarter panel to just above the bottom of the panel. They left an inch or so of metal. Then they laid a new section of quarter panel over the top of the original panel and brazed it together. When I started stipping that section, there has at least a 1/4 to 1/3 inch thick layer of the old red bondo covering the ridge on top of the quarter panel to the sail panel and trunk gutter.
The solution we came up with was to take a thin cutoff disc and cut straight down thru the original panel at the edge of the lip of the 'new' quarter panel. This way he could butt weld the two pieces together and do away with the ridge that we had. I then got to climb in the trunk with my die grinder and grinding bits to strip the brazing and original sheetmetal off the bottom side of the 'new' panel. That was an experience!!! But it definitely made for a lot better looking repair job, and made it possible to mig weld the pieces together without the mess of the brazing.
ID:	142778   Click image for larger version
post #110 of 118 (permalink) Old Mar 23rd, 16, 12:17 PM Thread Starter
john
As part of that same original repair job, they drilled holes for a slidehammer, and used another 1/4+ inch of bondo on the front fender to hide that. We were able to mig weld those holes closed and metal work the fender back into shape. I had the normal rust spot at the bottom rear edge of both fenders which we fixed with small patch panels welded into place. A little bit of Rage Extreme over the top of those repairs and various other dings scattered around the body and we were good to go.
ID:	142794   Click image for larger version
ID:	142802   Click image for larger version
ID:	142810   Click image for larger version
post #111 of 118 (permalink) Old Mar 23rd, 16, 12:22 PM Thread Starter
john
Next up was etch primer and 2k primer. And lots of block sanding followed by more 2k primer and more block sanding and more primer and even more sanding.... But the results were well worth it.
ID:	142834   Click image for larger version
ID:	142842   Click image for larger version
ID:	142850   Click image for larger version
post #112 of 118 (permalink) Old Mar 23rd, 16, 12:25 PM Thread Starter
john
Then came the biggie - paint was ready to go on. Boy was my wife happy to see something other than bare metal, followed by lots of primer dust on the floor!!! It was painted in my garage with my hi-tech 'zip lock baggie' paint booth I fabricated. I should have bought stock in the plastic sheeting company...
ID:	142874   Click image for larger version
ID:	142882   Click image for larger version
ID:	142890   Click image for larger version
post #113 of 118 (permalink) Old Mar 23rd, 16, 12:37 PM Thread Starter
john
After that was done, then it was colorsanding the front panels and the rear panels so we could do the stripes. It was an almost 8 hour job just laying down the masking for the stripes. That project is definitely not for the faint of heart if you've never done it before....
ID:	142914   Click image for larger version
ID:	142922   Click image for larger version
ID:	142930   Click image for larger version
ID:	142946   Click image for larger version
ID:	142954   Click image for larger version
post #114 of 118 (permalink) Old Mar 23rd, 16, 12:46 PM Thread Starter
john
So that is pretty much where I'm at now. There was a lot of work that went into all of this project so far. It's definitely true when they say most of the work is in the prep.
Just a brief list of the materials we used for the bodywork, priming, and paint. We used the Evercoat Rage Extreme filler, Acme Finish 1 etch primer and 2k primer, PPG DBC paint in Fathom Green and Dover White, and PPG Concept 2021 clear. There are 3 coats of clear on the panels that were striped, followed by 3 coats of Dover White for the stripes, and another 5 coats of clear on top of that to bury the stripes. There's 5 coats of clear on the rest of the car that didn't get striped. PPG is another company I should have bought stock in...
I've got more updates as far as the wiring, the dash, and the Digi-tails led light kit I installed for the rear taillights but I'll have to post those a little later.
post #115 of 118 (permalink) Old Mar 23rd, 16, 01:18 PM
Nick
Rarerat's Avatar
Looks great, real nice work!
Rarerat is offline
post #116 of 118 (permalink) Old Mar 23rd, 16, 04:16 PM
Tim
Fantastic John, car is looking awesome
Have you done the first fire on the 383 yet?
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
post #117 of 118 (permalink) Old Mar 23rd, 16, 06:49 PM
Thumbs up Re: Oh no - another '69 Z/28 project...
OMG, Holy crap, does that ever look sweet. I'd be proud of that baby. Well done.
Mark 1970 Z28 M22 3.73 - Lunati 20120121 Retrofit Roller Cam
Owned:
1968 Z/28 in '74
1971 Z28 in '75 4-spd
Ordered new 1977 Z28, 1978 Z28, 1980 Z28, all 4-spds.
1970 Z28 owned since 1981 4-spd
COPO is offline
post #118 of 118 (permalink) Old Mar 24th, 16, 10:02 AM Thread Starter
john
Thanks for the compliments.
Tim, no I haven't fired it up yet. Still have some more wiring to finish up in the engine compartment. Hopefully soon though....
Human Verification
