Test-N-Tune, X half a dozen! - Page 2 - Team Camaro Tech
Build Projects follow along start to finish
 1Likes
post #16 of 41 (permalink) Old Mar 15th, 15, 04:23 PM
Re: Test-N-Tune, X half a dozen!
Keep working that 60' and you should get there.
That's my goal too...10.XX I found my converter was slipping 17% and I may have hurt it ?
New custom spec'd converter needs testing, as I ran out of time last year between work and weather
Crossed fingers for mid-10's this year....time will tell.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #17 of 41 (permalink) Old Oct 25th, 15, 02:41 PM Thread Starter
Midwest Chassis rear bumper support but it isnt new.....
A full 10lbs of metal removed, about 1 pound went back in.
Losing the catback and 4" cutout, going to a single 4" bullet. Total weight lost will be a minimum of 35 lbs.
I love stock appearance......
To come.....
I also have a 5 gallon bucket of misc brackets, bolts, back of the radio etc thats up to 30lbs and Im not near done yet. I also found a full gallon of coolant in the spare tire well so figure that was an extra 8 pounds I was dragging around for nothing :bang:
Got a chance to tinker some more.
01ssreda4 is offline
post #18 of 41 (permalink) Old Oct 25th, 15, 02:41 PM Thread Starter
Decided to run the 4" pipe all the way out the back for the fumes, and the drone. I realized I had to delete the upper panhard support brace to make room for the pipe. I don't trust running without one so I fabbed up some supports of my own.
Running vertically supporting the bracket
This is what I started with, to go after the Y merge.
It snaked over the rear end quite nicely, with a little gap on top and bottom. Its ****ing loud.....
After some inspecting I realized WOT blasts make for super hot exhaust pipes. Was too close to the gas tank for comfort and melted a tiny bit of the bumper. So I wrapped the rear section and repositioned the tailpipe slightly.
The cutout i removed.
Got to tinker some today. Switched from a Chrs1313 AC ram air to a SSRA Megamouth (non-AC) ram air
Cut out the lower radiator support. It was worth 5lbs. The edges of the bracket are still strong enough for an adult male to hang from. I'm gonna run some aluminum flat bar across to give the air dam something to mount to.
post #19 of 41 (permalink) Old Oct 25th, 15, 02:42 PM Thread Starter
Before my 11.2 run I had done the following weight reduction:
ABS Delete: 10
Bumper supports F+R: 40
9.5" converter: 15
Cruise delete: 5
Power seat delete: 10
Lightweight battery: 20
Spare tire delete: 20
Monsoon delete: 20
K Member: 30
Front swaybar delete: 15
Midwest rear bar: 5
Front fender cut: 5
Lightweight carpet: 20
Driver airbag delete: 5
Total: 220 lost
Since I've done:
AC Compressor/bracket: 20
Sway bar brackets: 5
AC fan delete: 5
Lower radiator support cut: 5
Catback delete: 30
Misc bucket of brackets: 35
Spool: 20
Condensor and evap: 5
Coilovers: 10
Spare tire well delete: 10
Upper panhard delete: 5
Total so far: 150
Total 370 lbs.
I was concerned with the air going around the radiator since the condenser was gone. So I fabbed up a couple pieces out of ABS, pictured here plus the hole I was facing.
Life gets in the way at times, but I'm still working on it.
post #20 of 41 (permalink) Old Oct 25th, 15, 02:43 PM Thread Starter
UPS delivers happiness in a box.
3120, stock brakes, no driver, 1/8th tank of gas.
Found this guy wondering around the shop. I taught him the way home.
Center of lower radiator support cut out
Airbag computer with bracket:
Compressor with one hard line still attached:
Ebrake handle
post #21 of 41 (permalink) Old Oct 25th, 15, 02:43 PM Thread Starter
Ebrake cables
Passenger airbag
AC side cooling fan
2 door speakers
I originally got this kit, with Strange aluminum hubs. After looking I was sure it would not fit behind a stock wheel due to the design and the large dust cap. After searching around I found most drag wheels allow for the dust cap to come through the center. Since switching wheels was not an option I contact Midwest Chassis and they revised the kit to work with a stock hub and therefore stock wheels.
The kit for drag wheels:
Here's the modified kit and brackets:
So once I had all the correct parts, I fit it all to the car. You will need either brake line adapters, or a brake line kit. I got the kit from Midwest and it work well. The old hard lines are a pain to break free from the stock adapters so go easy on them. You can see the new line and adapter in place in this picture.
Here they are behind the wheel:
post #22 of 41 (permalink) Old Oct 25th, 15, 02:44 PM Thread Starter
And the weight. I assembled all the strange stuff on the scale and got 25lbs total. I assembled one side of the stock stuff and got about 31lbs. So 62 vs 25. So a 37 pound weight drop:
For driving impressions, the first few stops felt about like stock. After say a half dozen stops the pedal got more reactive and sensitive and the brakes had a very nice initial bite. Very confidence inspiring. I did not do any hard panic type stops but for normal driving you wouldnt know they were there other then the fact that the car seems to stop very well.
So we know what the new stuff looks like:
Yanked the old stuff off and promptly put it for sale: Its a BMR setup, which has worked good for me.
2 concerns, weight by needing to add the stock transmission crossmember back and ride quality. So lets look at the weight....The BMR torque arm was 25lbs. Then their crossmember was 10 pounds. Making the old setup 35 lbs.
Here's the stock trans crossmember: Its fully boxed and heavy. It should be as the torque arm is mounted to the trans when stock:
The stock trans crossmember:
We are gonna un-box it by cutting the stock welds.
post #23 of 41 (permalink) Old Oct 25th, 15, 02:44 PM Thread Starter
Now this little piece removed might not weigh much:
I mighta hole sawed it too......
TA crossmember cleared my Flowmaster 3 into 4 merge very comfortably.
The Midwest torque arm: about 17lbs.
And this is their crossmember with DS loop:
The conclusion, the BMR setup was 35. The Midwest is 17, I was able to get the TA crossmember down to 5 by eliminating the DS loop, so we are at 22. I was able to get the stock transmission crossmember down to 4 so that's 26. We lost 9 pounds.
Driving impressions: Nice. Quiet, not harsh, I'm really impressed. Traction is about the same on the street. Pinion angle is -2.5.
[SIZE="4"]Special delivery:
Here's the stock stuff:
post #24 of 41 (permalink) Old Oct 25th, 15, 02:44 PM Thread Starter
Teardown:
Stock weighs 28 per side:
The carnage, new bearings and wedding rings needed:
Going together:
Done!
12 per side for Strange.
So stock was 28+28=56, Strange was 24, so 56-24=32lbs in savings.[/SIZE]
So I finally decided to collect the fruits of my labor. Track time, TNT, we been planning it for over a month. Well the weather turned out really nice and DA was in the 750-1000 range. So, everyone and their momma came out.
Long story short I made three passes. I adjusted the coilovers in between each pass looking for traction. The second two passes I wheel hopped bad. Due to the crowd I decided that was enough for me for one night. I did noticed with the new brakes I can brake stall really high now. With the stock brakes it would push through pretty quick. I notice a bad vibration on the way home, and Im thinking its driveshaft related, broken ujoint or something. I made it halfway home and had to call the old lady to come bring the car hauler.
post #25 of 41 (permalink) Old Oct 25th, 15, 02:45 PM Thread Starter
This, doesn't look right.
Decided to not chance it and just make the repair on the trailer:
Wheel holes are wallered out, brake rotor holes are too, and the centering register on the axle is ****ed. So I will be replacing all of them. Caliper took a little rubbing from the rotor but looks mostly cosmetic.
Strange was so kind to drill both 12mm and 1/2" stud holes. I will be going back with 1/2" this go round to see if I can stop this **** from happening again.
Here's the passenger side wheel studs.....whoops.
So I waited about a week for new 1/2 studs and a brake rotor from Strange. I didn't get in a hurry to get it fixed due to I'm still waiting on a wheel. I went ahead and patched it together yesterday and put the stock wheels back on the rear to get it off the trailer.
This is the damage to the caliper where the rotor rubbed the inside of it. Looks like i stopped in time and didnt do major damage to the caliper.
Here's the new 1/2 studs after installation.
Here's the complete assembly with the new center register and rotor. You can see from this picture the rotor is stud-centric meaning it depends on the studs to center itself. Common sense tells you if it fits with 1/2 studs and 12mm are smaller, then there was some slack with the 12mm. Enough to cause an issue? Well I cant say for sure but I do believe these were designed to work best with 1/2 because the fit is much tighter. Strange should mention this detail in their product literature I think.
I'm making a lug nut swap also. I'm including this picture for those who may not be familiar. Stock wheels use a hex nut conical seat on the top left. Drag wheels use something like the mag type hex nut with a washer. That type goes through the wheel to grip the stud all the way at the base making it stronger. Even with stock wheels you can use the hex nut ET (extended thread) and it gives a similar effect of the mag type where it actually passes through the wheel and engages more thread and in to a further point.
post #26 of 41 (permalink) Old Oct 28th, 15, 06:45 AM Thread Starter
Making some good use out of a pair of old 10 spokes. I figure these will hit the lugs a little softer then the radial giving the lugs a chance to survive plus they are sticky as hell so traction shouldnt be a fight like it was with the 18s. This is a Hoosier full slick 28x10x17.
post #27 of 41 (permalink) Old Nov 5th, 15, 08:53 AM Thread Starter
Kill mode!
post #28 of 41 (permalink) Old Nov 5th, 15, 01:41 PM
A few suggestions....See if you can get a spacer to make up the difference on the stud Vs. rotor holes. I've seen this become an issue a few times where it allows the rotor to rock and causing just what you had....but 99% sure yours was due to wheel hop
ALWAYs torque your lugs properly.
ALWAYs check your lug nuts.
68 Camaro~LSx
<-Pics
post #29 of 41 (permalink) Old Nov 5th, 15, 02:42 PM Thread Starter
I realize the rotors were a tad loose with 12mm studs. They are snug with 1/2". I wish they woulda stated that when I bought them and we probably would have avoided them breaking in the first place.
post #30 of 41 (permalink) Old Nov 21st, 15, 06:45 AM Thread Starter
Delay from technical difficulties.
I took off work for the race saturday, I had everything ready on the car. Car was washed, truck and trailer were washed and loaded.....and the weather just wouldn't cooperate. Friday night all cleaned up we sat in the garage hoping things would clear for the race the next morning....
They decided to postpone the race till the afternoon and around lunchtime when we thought the weather was going to break we headed to the track. That didn't work out and we ended up coming home dripping wet and the race postponed.
Around midnight the weather finally got moving and they had a fresh water logged track to prep for an early AM race day.
Sunday morning the weather was fantastic, temp in the 60s, and DA ranged from negative 400 or so to around 500 last time I checked.
Couple of random staging lane pics:
Fastest pass of the day, but I only ran 3 times. It went .08, .09, .08 in that order.
And finally some go pro footage:
LSX Monsters Shootout 2015 - YouTube
I'm at 3:25 on XXX Motorsports footage:
LSX SHOOTOUT TEST n TUNE (Part 2) - YouTube
Human Verification
