1995 camaro starts but dies a few seconds after - Team Camaro Tech
post #1 of 4 (permalink) Old May 28th, 11, 09:02 PM Thread Starter
ryan
ok so I have a 1995 3.4 camaro recently i replaced my head gaskets, intake gaskets, O2 sensors, crank position sensor, harmonic balancer, cam position sensor,ignition control module, catalytic converter. So the problem im having now that it starts sometimes but also sometimes i have to push on the throttle to get it to start and once it starts if i let off the throttle it stalls. Also the plugs are getting gas and carbon fouled which to me is indicating week spark or some type of timing off somewhere. Some ideas I have are maybe the fuel rail, fuel pressure regulator, cam sensor interupter. Anyone have another idea?
camaroprodigy is offline
post #2 of 4 (permalink) Old May 29th, 11, 05:32 AM
Re: 1995 camaro starts but dies a few seconds after
TPS sensor ?
Any codes getting thrown would help also
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #3 of 4 (permalink) Old May 29th, 11, 10:53 AM Thread Starter
ryan
doesnt throw codes plus it is a pain to read them because its a obd 1.5 which has an obd2 connector but and obd1 computer and you need a tech1 scanner. After sleeping on it lastnight i'm was thinking to take it back apart and check the timing chain and camshaft interupter. all i know for sure is im done throwing parts at it
post #4 of 4 (permalink) Old May 31st, 11, 09:41 PM
darrell
a ground issue chek all ground location as stated by GM--had the same problem on my 5.7 and swapped out fuel rail , reg and injectors off another motor stored and it fixed it
97Z4C is offline
Human Verification
