Wheres this lost 1969 Z28 ? I have the dz302 - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 50 (permalink) Old Sep 30th, 09, 02:40 PM Thread Starter
Brad
LOST 1969 Z28 Hello im new to the site but a camaro fan and owner for years. I have a DZ 302 that was pulled from a car in central Illinois years back. my goal is to find this car and get the motor and car back together. car and motor were seperated back in 1989 - 1993 . in the jacksonville , Illinois area i have the vin from the block ,also have the casting date and the Dz code. Ive owned this motor for close to 20 years and should have looked for the car years ago. Is this car still alive and around ? any info would be great . Thanks Team Camaro.
LOST 1969 Z28 is offline
post #2 of 50 (permalink) Old Sep 30th, 09, 03:31 PM
Bobby
Re: Wheres this lost 1969 Z28 ? I have the dz302
whats the numbers off the block, and the vin#?
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi.
69CamaroRT is offline
post #3 of 50 (permalink) Old Sep 30th, 09, 03:39 PM
Jonesy's Avatar
Kind of hard to narrow it down without the VIN.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
1984 Camaro z/28 LG4 auto
Jonesy is offline
post #4 of 50 (permalink) Old Sep 30th, 09, 03:43 PM Thread Starter
Brad
Cast date j 24 8
on the engine pad v1028dz
vin 19N533226
casting 3932386
std bore.
post #5 of 50 (permalink) Old Sep 30th, 09, 04:01 PM
Jonesy's Avatar
Its gonna help to give the full VIN. I can tell its a Norwood built car.
So the partial Vin is 9N533226 or 9N543226. November 68 built Norwood z/28. Got any pics of the pad stamping? Whats the casting on the back of the block?
Jonesy is offline
post #6 of 50 (permalink) Old Sep 30th, 09, 05:51 PM Thread Starter
Brad
Info updated above ,
Brad
post #7 of 50 (permalink) Old Sep 30th, 09, 06:47 PM
Russ
rafbody's Avatar
Assuming the car is still out there, that will make someone very happy being a pre x code car.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #8 of 50 (permalink) Old Sep 30th, 09, 09:04 PM Thread Starter
Brad
you say this would be a pre x code car ? when did they start putting the x codes on ? so your telling me the plate on the firewall will not have x77 or x 33 ? what letters or numbers will be there if any ? i must say this seems to be a great camaro site. thanks guys.
Brad
post #9 of 50 (permalink) Old Sep 30th, 09, 09:52 PM
Doug
Brad,
I believe the X codes started around mid December of '68. Your block is too early for that.
Hope you can reunite the DZ with the original Z.....
Doug
1969 Van Nuys RS Z/28. Protect-o-plate and chassis broadcast copy. Hugger Orange, original 711 interior, including carpet. Original drivetrain: DZ, M-20, 3:73 BO code peg leg. Flat hood, no spoilers.
z28doug is offline
post #10 of 50 (permalink) Old Oct 1st, 09, 07:13 AM
Ed
The car's not in the database, but I would recommend posting the numbers on the CRG site anyway. You never know...
Ed
bertfam is online now
post #11 of 50 (permalink) Old Oct 1st, 09, 07:08 PM
Russ
rafbody's Avatar
Brad
There will not be any codes on the trim tag. The x codes started the second week of December (12B). Prior to that date there was nothing on the trim tag to decode a 69 Camaro.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #12 of 50 (permalink) Old Oct 4th, 09, 03:49 PM Thread Starter
Brad
hey guy thinking of selling this DZ 302 motor. will consider offers. all info on codes are stated above. this block was dipped and magged years ago and may need it again . sitting close to 20 years. was greased on a regular basis. block was checked recently and found to be still stock bore. the parts i have include the block, 1178 crank , factory pistons and rods , pins , pan, 1 pully, stock bolts. NO HEADS ,INTAKE, CARB. PRE X CODE CAR .
post #13 of 50 (permalink) Old Oct 4th, 09, 04:09 PM
I just looked through my papers but couldnt find anything with a VIN for my old 69 Z/28. It was a Nov. 68 built X77 car, of course no X code on the cowl but it did have the X7 on the rear seat bulk head.
The first owner swapped the engine with a friend due to his being modded before it was traded in at a local dealer. It had only 34k original miles when I owned it. I know this because I found a reciept in the glove box dated 1970 with a signature and I tracked down the owner of the signature and got the story as well as original photos of the car. That car went to Texas when I sold it.
Good luck with your search.
1967 Camaro in the works-406 AFR 210E Chassisworks subframe, 13" wilwood.
69 Camaro SS/RS, Orange/white, Ivory houndstooth/VE3.. sold
Jeremiah is offline
post #14 of 50 (permalink) Old Oct 4th, 09, 04:34 PM
click's Avatar
Brad, please keep the offers to sell or buy in our classifieds. Soliciting in these forums is against site policy.. thanks for understanding.
click is offline
post #15 of 50 (permalink) Old Oct 4th, 09, 05:39 PM
Banned
Brad, with the high volume of fakes and forgeries, it's worth your time to authenticate the stampings via photos thru some of the experts here to protect/enhance your investment. I personally know of fakes being made even in the 83-89 time frame. Best of luck on your hunt.
theChuckster is offline
Human Verification
