Decode Ring Gear Numbers - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 6 (permalink) Old Jun 7th, 11, 08:08 PM Thread Starter
BJ
I pulled the rear end cover today to replace the gear oil and add fresh posi additive and the stamping numbers on my 69 ring gear are as follows RICHMOND 80-0550-1 L 9 8620 Can anyone make any sense from this and determine the gear ratio ? It seems to be a little over 3 to 3 1/2 turns of the drive shaft , to one full turn of the ring gear.
Man In Black is offline
post #2 of 6 (permalink) Old Jun 7th, 11, 08:17 PM
Ed
Re: Decode Ring Gear Numbers
That's the ring gear part number for a RICHMOND 10 bolt (8.2") 3.55 gear set. The complete set P/N is 49-0015-1.
Ed
bertfam is offline
post #3 of 6 (permalink) Old Jun 7th, 11, 08:21 PM Thread Starter
BJ
Originally Posted by bertfam View Post
That's the ring gear part number for a RICHMOND 10 bolt (8.2") 3.55 gear set. The set it P/N 49-0015-1.
Ed
Thanks for the quick response Ed.
post #4 of 6 (permalink) Old Jun 7th, 11, 09:02 PM
For future reference, since you've got the cover off, divide the nember of teeth on the ring gear by the number of teeth on the pinion gear, and Viola... you've got your ratio.
buenymayor is offline
post #5 of 6 (permalink) Old Jun 13th, 11, 07:58 AM
Joe
I had to look up a Richmond gear number last weekend and found a handy online look up tool at their website.
http://www.richmondgear.com/cfide/sc...partsearch.cfm
Follow the link and input the part number: 80-0550-1
It states that you have a 8.2 inch 10 bolt 3:55 gear. Pretty nice look up tool for Richmond part numbers.
NHRA 3168 is offline
post #6 of 6 (permalink) Old Jun 13th, 11, 10:08 AM Thread Starter
BJ
Thanks Joe. Thats good to know. I will keep it for future reference.
Human Verification
