12 bolt decode help - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 12 (permalink) Old May 16th, 12, 06:11 PM Thread Starter
Jay
12 bolt decode help
Just found a 12 bolt with a casting number of 3894939. I also found Cf 0901. Not sure what it's from but it looks like chevelle by the spring mounts.. Anybody have any ideas?
purecam is offline
post #2 of 12 (permalink) Old May 16th, 12, 06:24 PM
Bryon
bcm66's Avatar
Re: 12 bolt decode help
That is for a 67 Chevelle, one year only casting number. Should have to "ears" on upper part of center section for control arms. CF is 3.31 posi.
3.31 was the standard ratio for the 1967 Chevelle with 396/325hp engine and manual transmission without AC.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #3 of 12 (permalink) Old May 16th, 12, 06:24 PM
Mickey
Rear axle code CF was used in 1965-1969 Chevelles and is a 3.73 posi traction.
Mickeystoys69RSSS is offline
post #4 of 12 (permalink) Old May 16th, 12, 06:31 PM
Bryon
bcm66's Avatar
Nope. CF is 3.31 posi in all of those years. Trust me. I have one in my Chevelle.
CRG -
bcm66 is offline
post #5 of 12 (permalink) Old May 16th, 12, 06:32 PM Thread Starter
Jay
Ok, I may try to sell it over on the chevelle site... Thanks!
purecam is offline
post #6 of 12 (permalink) Old May 16th, 12, 06:35 PM Thread Starter
Jay
Originally Posted by bcm66 View Post
Do you mean 3994938? If so that is for a 67 Chevelle, one year only casting number. Should have to "ears" on upper part of center section for control arms. CF is 3.31 posi.
Double checked casting no... It is 3894939 with an n above it..
purecam is offline
post #7 of 12 (permalink) Old May 16th, 12, 06:40 PM
Bryon
bcm66's Avatar
You are right. I had a typo.
3894938 is the 10 bolt center section casting number.
3894939 is the 12 bolt center section casting number used for most of the 1967 model year.
CRG -
bcm66 is offline
post #8 of 12 (permalink) Old May 16th, 12, 06:42 PM Thread Starter
Jay
Any idea of an asking price? Looks like it has strange brand axles.
purecam is offline
post #9 of 12 (permalink) Old May 16th, 12, 06:47 PM
Mickey
That depends on the condition. Does it need to be rebuilt, or is restored?
post #10 of 12 (permalink) Old May 16th, 12, 07:02 PM Thread Starter
Jay
Looks good.. Definitely needs a cleaning... I pulled the cover and everything looks great inside...
purecam is offline
post #11 of 12 (permalink) Old May 16th, 12, 07:18 PM
Mickey
I would guess $800-$1000 once it is cleaned up and painted.
post #12 of 12 (permalink) Old May 17th, 12, 07:08 AM
Bryon
bcm66's Avatar
Original GM gears inside? If so, check the numbers on the ring gear.
CRG -
bcm66 is offline
Human Verification
