eBay X33 Car - Page 2 - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #16 of 38 (permalink) Old Dec 31st, 12, 04:07 PM
Bob
Re: eBay X33 Car
You are correct, the 4 speed is listed as an option. I do not however have a console and gauge package and if I am not mistaken I have heard of late built X cars that did not have a tach from the factory although I am not certain of this. Yes my Z is real and therefore I can guarantee that at least the console and gauge package was not standard equipment on late built cars.
302z28camaro is offline
post #17 of 38 (permalink) Old Dec 31st, 12, 04:50 PM
William's Avatar
Re: eBay X33 Car
Body tag is probably real, just wasn't originally installed on this car. Tag is 2nd week January 1969, VIN was issued 4th week October 1968.
Tach was technically required as of January 1969 ordereing info but many cars were built without one. By around late May 1969 Z/28s all had U16 or U17.
William
CRG
William is offline
post #18 of 38 (permalink) Old Jan 1st, 13, 07:35 AM
Re: eBay X33 Car
I owned an x33 Camaro brand new in 69. It was also a low option car with no tach or gauges. It was also a radio delete car. The fuel gauge was where the tach was supposed to be.
The valve covers are on the wrong sides and it has a cowl hood with a flat hood breather, that is not hooked up properly. Just one of a few things I saw.
I have owned three zs and all of them had a different gauge set up. One had none, one had the center fuel gauge with console and no guage cluster, and the third had the console and gauge package so you could get a few configurations. Two of them were Canadian documented cars.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #19 of 38 (permalink) Old Jan 1st, 13, 09:45 AM
"Tri-Tip"
Gary L's Avatar
Re: eBay X33 Car
Originally Posted by 302z28camaro View Post
Tach and console gauge package were always an option to my knowledge, contrary to popular belief. My original late '69 build has a tach and it is listed as an option on the window sticker, but no console.
There were mandatory options along the way. Power disk brakes is an example. Then there were "options" that became part of the "special performance" package (Z28). it was June that console became part of the package and April the spoilers became part of the package as I remember.
Gary L is offline
post #20 of 38 (permalink) Old Jan 1st, 13, 10:01 AM
Rob
satz28's Avatar
Originally Posted by rhcdmd View Post
The VIN on that car would indicate that the car was built before X codes were in use. I don't think that cowl tag matches the info in the VIN. My 69 was built in Nov 68 and has a higher (and later) VIN number than this car. This car would have been built before mine. X codes started in Dec 68. My VIN is 124379N544XXX. You can check VINs and production dates on the CRG site. It would seem that this car was built well before Jan 69 as the cowl tag shows.
I have an 11A, 535 VIN Z.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/242@.050 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is online now
post #21 of 38 (permalink) Old Jan 1st, 13, 10:03 AM
Bob
Re: eBay X33 Car
My car is a late September built X33 and does not have the console/guage package. I don't believe the console ever was part of the package. Anybody else with a late build X car without a console? I know mine to be original this way from the factory as I have contacted the previous owners.
post #22 of 38 (permalink) Old Jan 1st, 13, 10:03 AM
norm
Re: eBay X33 Car
I recall reading in John Delorean's book that there were something like 2800 different possible dash combinations available in the Camaro at one time.
Apex is offline
post #23 of 38 (permalink) Old Jan 1st, 13, 11:04 AM
William's Avatar
Re: eBay X33 Car
The number De Lorean quotes is 2,720; it is on page 144 of the paperback edition.
I have been able to duplicate the number but incorrect assumptions were used to arrive there. For example while there were 4 speedometers used in '69 the 140 was COPO only and should not be included for all applications. Also later Z/28s had a unique tach but a Z/28 could not have a power top switch.
I believe the correct total is 1,940. 5 colors, 388 trim/equipment possibilities.
William
CRG
William is offline
post #24 of 38 (permalink) Old Jan 1st, 13, 11:24 AM
norm
Re: eBay X33 Car
Wow That was quick! I was hoping for an informed response as I have always wondered about this. Thanks
Apex is offline
post #25 of 38 (permalink) Old Jan 1st, 13, 01:57 PM
Re: eBay X33 Car
I pointed this out to the seller a couple of days ago and they said they would look into it. If it's not a VIN typo then something ain't right.
For what it's worth, this car has been on Ebay periodically over the past year. Back when it first appeared on Ebay I sent the owner an email questioning the conflict between the VIN and the TT. If memory serves me correctly, I believe I included a link to the CRG site so he could see what I was questioning. I never received a response and he has continued to advertise it the same way. I'm just an enthusiast, not an expert, but this discrepancy stuck out like a turd in a punch bowl.
At this point in time I would have to assume that Mr. Brannon is aware he has a problem but chooses to ignore it.
baldeaglemtnman is offline
post #26 of 38 (permalink) Old Jan 1st, 13, 04:42 PM
Daniel
Re: eBay X33 Car
It must have had a center fuel gauge then.
TModel66 is offline
post #27 of 38 (permalink) Old Jan 1st, 13, 07:48 PM
frank
Re: eBay X33 Car
Originally Posted by 68 Ragtop View Post
Also contrary to popular belief, 4 speed transmission was also an option.
If your car is a real Z/28 the window sticker will also list it as an option.
The only difference is the 4 speed was always required and the tach only required later.
Just to add to what you have said..... the 4 speed trans was a mandatory option for the RPO Z/28
wot
frankk is offline
post #28 of 38 (permalink) Old Jan 1st, 13, 07:50 PM
Bob
Re: eBay X33 Car
Yes it does have the center fuel guage.
post #29 of 38 (permalink) Old Jan 3rd, 13, 10:02 AM
James
Re: eBay X33 Car
Originally Posted by frankk View Post
I do not like the TT. My COPO car has the center fuel guage like this one but had a factory console and guages. I am not sure how that all fit together......hopefully William will chime in and let us know.
I don't understand what you are saying here because it does not make any sense.
The car in the OP does not have a center fuel gauge and your COPO should not have 2 fuel gauges. Which fuel gauge works? the one in the dash or the one in the console?
68 Ragtop is offline
post #30 of 38 (permalink) Old Jan 3rd, 13, 12:42 PM
Re: eBay X33 Car
This is a non RS Z shown, shouldn't it be X coded X77? IF it was a true car. Agree on the other stuff. Correct me,
TC # 349
zdld17 is offline
Human Verification
