69 DZ engine on Corvette Forum - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 116 (permalink) Old Mar 11th, 13, 01:49 PM Thread Starter
Ed
A 1969 302 DZ engine has surfaced on Corvette forum.
The numbers on the engine pad are 19L554125 and V0207DZ .
Here is a link to the thread on Corvette Forum
http://forums.corvetteforum.com/c1-a...a-midyear.html
Not sure where to post this info for Camaro - Z/28 people, so I put it here.
emccomas is offline
post #2 of 116 (permalink) Old Mar 11th, 13, 02:00 PM
Tim
Re: 69 DZ engine on Ciorvette Firum
Here's the pad stamp picture from the above link:
Anyone else see a problem with 19L55xxxx??
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
post #3 of 116 (permalink) Old Mar 11th, 13, 02:07 PM
Moderator .. Jim
click's Avatar
*** deleted wrong info. ***
oops I forgot to double check my post before hitting 'save'... I was in error. Thanks Tim for the heads up.
click is offline
post #4 of 116 (permalink) Old Mar 11th, 13, 02:46 PM
Alan
Any possibility it is a good factory stamp that was just mis-stamped in the factory? Did they even put the VIN on the engine pad?
alanrw is offline
post #5 of 116 (permalink) Old Mar 11th, 13, 02:52 PM
Tim
*** removed wrong info. from Mod's post ***
19L is correct for Camaro partial, but the second digit of the VIN sequence (55) is what I was referring to.
And I should have added that regardless of the stamp, I think it's great that the Corvette guys are trying to help reunite car and engine block
ZLP955 is offline
post #6 of 116 (permalink) Old Mar 11th, 13, 02:56 PM
Niclas
Nikke's Avatar
http://www.camaros.org/geninfo.shtml
Nikke is offline
post #7 of 116 (permalink) Old Mar 11th, 13, 03:01 PM
Kevin
KevinW's Avatar
Yes, that is strange. The last VIN from the LA plant is 9L531163 http://www.camaros.org/geninfo.shtml#HowMany
And yes, VN stamped the VIN on the engine pad until they shutdown around July of 69.
Kevin
KevinW is offline
post #8 of 116 (permalink) Old Mar 11th, 13, 03:11 PM
Moderator .. Jim
click's Avatar
Just to blend in with Kevin...some LA partial VINs were on the rough boss by the oil filter too. Mine was
click is offline
post #9 of 116 (permalink) Old Mar 11th, 13, 04:26 PM
Mr. Tibbs
Send a message via AIM to ChevyThunder
Re: 69 DZ engine on Corvette Forum
I think by April Van Nuys was also putting the VIN on the rough casting. My 03D Van Nuys Z has it on the deck .
" Burn rubber not your Soul "
Camaro,Camaro,Camaro,Camaro
ChevyThunder is offline
post #10 of 116 (permalink) Old Mar 11th, 13, 04:45 PM
Kevin
KevinW's Avatar
Interesting. I though I had save a pic of a later one. I have to look for that now
Kevin
KevinW is offline
post #11 of 116 (permalink) Old Mar 11th, 13, 05:14 PM
William's Avatar
The VIN is a restamp.
L554125 never existed; N554125 was final-assembled on or about Dec 4, 1968 and would not have had an engine dated Feb 7, 1969.
William
CRG
William is offline
post #12 of 116 (permalink) Old Mar 11th, 13, 05:42 PM
Tim
This is one of the recent VN pad stamps that I've come across, although the photo doesn't show the whole partial, it is 19L53xxxx so would be late April (or later) car.
ZLP955 is offline
post #13 of 116 (permalink) Old Mar 11th, 13, 07:24 PM Thread Starter
Ed
I don't have a dog in this fight, but we (the Corvette people) have documented MANY examples of mistakes in engine, transmission, frame stampings over the years.
I would not automatically jump to the conclusion that this is a restamp. It may be a factory mistake. What if 19L554125 was supposed to be 19L524125.
Honestly, I don't know what the real story is here, but I do know that making assumptions isn't the way to find out.
In any event, I hope this "find" is of some interest to some you you.
emccomas is offline
post #14 of 116 (permalink) Old Mar 11th, 13, 08:44 PM
This is my engine; I am the OP on the Corvette Forum. Thanks to emccomas for posting the info and your interesting feedback.
This engine has been in my dad's garage unmolested for at least 25 years, probably longer. It was in his '63 Vette but it blew a piston and he replaced it with the '73 350 crate engine that is currently in the car. How long have people been re-stamping engines and why would somebody re-stamp a VIN that never existed? The engine still has the pistons but not the heads. Anything else I could use to identify the engine?
Thanks for the help!
63VetteConv is offline
post #15 of 116 (permalink) Old Mar 11th, 13, 09:28 PM
Chick
68camaroz28's Avatar
Welcome to team camaro Tom! Clean the pad off with some lacquer thinner and post another close up picture of the unpainted pad.
Back in 2008 I found the 69Z owner of the DZ short-block that had been in our 67 Corvette since 1979.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
Human Verification
