3932388 block... - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 21 (permalink) Old Jan 26th, 04, 06:30 AM Thread Starter
Is the 3932388 block for 1969 only, or did it carry into the 70's like the 3970010 block?
Thanks.
69SSConvertible is offline
post #2 of 21 (permalink) Old Jan 26th, 04, 08:08 AM
Guess
HwyStarJoe's Avatar
3932388 350ci '68-'79 300hp car & Truck 4-Bolt
http://www.chevymania.com/partsid/
HwyStarJoe is offline
post #3 of 21 (permalink) Old Jan 26th, 04, 09:30 AM
Kurt S
Kurt S's Avatar
That list is ****.
386 and 388 were mid 69 only. Replaced by the 010 block.
Wrong, that's what I meant. Oh, that's 5 letters..... [img]smile.gif[/img]
Kurt S.
CRG -
Kurt S is offline
post #4 of 21 (permalink) Old Jan 26th, 04, 09:41 AM
Guess
HwyStarJoe's Avatar
4 asterisks are acceptable.
I sorta figured that since the 3 other sources I looked it up under all show it as only being a 1969 block.
Sorry.... disregard my reply.
post #5 of 21 (permalink) Old Jan 26th, 04, 01:40 PM
The 3932388 block came in both 2 bolt and 4 bolt main versions. The 4 bolt was used in a small number of the Z28 Cars and they were only found in early 69 production cars say till December of 68 Castings Dates.
From Chevy-Camaro.com
The casting number 3932388 was only used in 1969 and is rare because not many cars much less Camaro's got this block casting number that are known. The book Chevrolet By the Numbers 1965-69 says this engine was put in 1969 passenger cars and Camaro's. Their notes say this: "Very little is known about this block". It seems that most blocks were Tonawanda cast and built, but some Norwood assembled Z28's used this block with Flint-produced engines. From all indications the block is identical to #3932386. It has been found in Passenger cars with the 350/300hp engine suffix code stamping. At least four SS 350 and at least two Z28 Camaros were built with this block, with casting dates ranging from L 20 8 to C 11 9. At least one Camaro was built it September 1969 with this block. Other cars could have received this rare block, but it is unknown which or why. Most #3932388 blocks are dated from September to December 1968." We have apparently had all (and then some) of the Camaro owners, according to Chevrolet By the Numbers 1965-69, of this block casting to email us about it. The problem is there are no exact numbers as to how many cars had this block casting number. The block doesn't have any special features that sets it off from the rest that would make it any more desirable than other blocks from that time period though.
Most Z/28's had the #386 Block issued until late November when they started using the #618 Blocks. These were used until mid year when they started casting the 010 blocks sometime in April.
Hope this helps you.
hugger_sixty_nine is offline
post #6 of 21 (permalink) Old Jan 26th, 04, 05:27 PM
Kevin
KevinW's Avatar
Ugh, last I looked my 388 block T0425HA was cast in April 69. Most 388 blocks were for 4 bolt higher HP engines.
Kevin
KevinW is online now
post #7 of 21 (permalink) Old Jan 26th, 04, 09:28 PM
Kurt S
Kurt S's Avatar
Actually, it's a pretty common mid-year block. See it as much or more than the 386......
Kurt S.
CRG -
Kurt S is offline
post #8 of 21 (permalink) Old Jan 27th, 04, 05:39 AM
Gary
69Z28's Avatar
While we are on blocks, i went to look at a DZ block with V1008DZ with the last three in the cast number of 512, block was cast i288 if i remember correctly. Is this legit?
06A 1969 Camaro Z28
X33D80 69 B 711 Black Stripes
Console w/tach and gauges.
69Z28 is offline
post #9 of 21 (permalink) Old Jan 27th, 04, 05:47 AM
Paul
Except mine which is a two bolt!!! [img]graemlins/sad.gif[/img]
I wonder if there was an extra "grocery getter" option when ordering a camaro with the LM1 so you'd get the 2 bolt!
Best of 1.55 - 11.57@114.33
paulm is offline
post #10 of 21 (permalink) Old Jan 27th, 04, 06:39 AM
Wasn't there a few horsepower options in 69.
(i.e. 255 HP = 2 Bolt Main / 300 HP = 4 Bolt Main)
I remember there being low horsepower 2 bolt main blocks used with cast cranks for the 255HP version and the Forged Crank 4 Bolt Main for the 300HP Versions, etc etc. Corvettes and SS Cars getting the forged and coupes etc. getting the 2 bolts. Is this correct?
post #11 of 21 (permalink) Old Jan 27th, 04, 09:50 AM
Kurt S
Kurt S's Avatar
512 block is very rare SB. Don't know much about the block. Did the block have a VIN on it?
LM1's have been both 2 & 4 bolt (very limited data though).
SS350 is a cast crank. And I've seen L48's with 2 bolts (got one).
I know of no difference between a LM1 and L48 short block.
Kurt S.
CRG -
Kurt S is offline
post #12 of 21 (permalink) Old Jan 27th, 04, 03:18 PM
Gary
69Z28's Avatar
Kurt, yes it did. It was on the pad under the head and it was stamped 19n518336 and the corrected engine number is V1003DZ. I would have picked it up but didn't have the cash on hand for a deposit. It had one 291 and one 461 head on it with a newer GM aluminum intake and a service replacement 4053. but the rest was original as near as I could tell with my limited experience. A young kid had it and he told me it came out of a Burnish Brown Z that was crushed in a salvage yard. I'll have to give him a call to see if he sold it yet.
Kurt, I called and he still has it. If anyone is interested I can give them his number. He will be off for the next three days.
[ 01-27-2004, 05:35 PM: Message edited by: 69Z28 ]
06A 1969 Camaro Z28
69Z28 is offline
post #13 of 21 (permalink) Old Jan 27th, 04, 05:25 PM
Bill
KevinW-
You've got mail.
Bill
Classsic Performance & Restoration
69-Z11Pacer is offline
post #14 of 21 (permalink) Old Jan 28th, 04, 07:48 AM
click's Avatar
My ...388 block is 4 bolt, its an LM1 255HP so as Kurt said, the ..388 block is seen quite often, not as much rare as it is unknown why they cast it in the first place since its not different than the ...386 block.
The carbs were the difference in the higher HP as well as intake and heads I think, to get an extra 45 hp out of the same block.
Im in the process of moving my office in the house, doing taxes and soon will be attempting to start an LM1 club of sorts. Stay tuned.
[img]graemlins/thumbsup.gif[/img]
click is offline
post #15 of 21 (permalink) Old Jan 28th, 04, 01:00 PM
i pulled a 2388 block out of a 69 impala,it came from the factory in that car.it has 2 bolt mains.i noticed the harmonic balancer looks exactly like the 302 balancer but has a different part #.the timing mark is off-center from the keyway,its also 8 inches in diameter,just like the 302's.
i think its basicly the same motor that came in all the 69 350 pace cars.correct me if i'am wrong.
69 rs/z28 <br />711 72 72<br />12c x33
69z28rsbilly is offline
Human Verification
