Rally Wheel Codes - Team Camaro Tech
Tag Team De-coding tags and numbers.
post #1 of 9 (permalink) Old Apr 2nd, 04, 08:14 AM Thread Starter
I have the following rally wheels that I need decoded. What car and year are they for and value if possible? Thanks.
2-15"x8" AZ
2-14"x7" YJ
4-14"x6" YW
I'm deciding what to put on my 68 RS. I might sell them all and go with 15"x7"s.
LP-68RS
Larry Pfeil is offline
post #2 of 9 (permalink) Old Apr 2nd, 04, 08:30 AM
2-15"x8" AZ 1969 Corvette Rally
2-14"x7" YJ 1969 Chevy II RPO Rally SS Camaro SS
4-14"x6" YW 1969 Chevelle pass, Raly. Replaced "XB"
According to chevy by the numbers book.
[ 04-02-2004, 11:07 AM: Message edited by: Johnny in AZ ]
<a href="http://pg.photos.yahoo.com/ph/johnotis/album?.dir=/31de&.src=ph&.tok=phBEazBBTa1v1kvG" target="_blank">http://pg.photos.yahoo.com/ph/johnotis/album?.dir=/31de&.src=ph&.tok=phBEazBBTa1v1kvG</a>
Johnny in AZ is offline
post #3 of 9 (permalink) Old Apr 2nd, 04, 08:30 AM
Vintage 68's Avatar
Corvette
Chevy II
Chevelle
(edit: Tie John [img]graemlins/beers.gif[/img] )
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 9 (permalink) Old Apr 3rd, 04, 08:09 AM
Jonesy's Avatar
In edition to the above:
AZ = 1971-77 Corvette 15x8 ralley wheel
YJ = 1970 Nova 14x7 ralley wheel
YW = 1970 Chevelle (exc. SS) and Wagon ralley wheel.
There will be a K 1 9 or simular code on the wheel that will tell you what year they are.
For example K 1 2 =
k= kelsey hayes (wheel manufacturer)
1= Plant - Romulus, MI
2= year - 1972
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
1984 Camaro z/28 LG4 auto
Jonesy is offline
post #5 of 9 (permalink) Old Aug 19th, 11, 01:21 PM
Bob
Re: Rally Wheel Codes
mine are k-1-9 29W ????
Barettabob is offline
post #6 of 9 (permalink) Old Aug 19th, 11, 01:33 PM
Kevin
KevinW's Avatar
Wow! Bob, you did notice that this thread was started 6 years ago
Kevin
KevinW is online now
post #7 of 9 (permalink) Old Aug 19th, 11, 03:32 PM
Vintage 68's Avatar
Talking Re: Rally Wheel Codes
Which just adds to the fun of this site
which decodes as;
K = Kelsey-Hayes Rim and Wheel manufacturing
1 = built at the Romulus MI plant
9 = 1969
29W = ... you sure it's not a '2' and then 'YW' ???
The area you're seeing this is most likely to the right of the valve stem/hole and gives the day of the month built and then the 'application-code' as a two 'Alpha' (letters) code ...
Maybe you can recheck and start your own thread if more info needed
1968 Convertible
Some trucks
post #8 of 9 (permalink) Old Aug 24th, 11, 06:36 PM
Todd
6781camaro's Avatar
For the future searches:
Here's a master list that I received from a reputable source:
GM Rally Wheels
XA 14X5 BS-3 1/2 67 Chevy II with drum brakes
DA 14X5 BS-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camaro & Chevelle with discs brakes
XB 14X6BS -4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 BS-3 3/4 68-69 Camaro & Nova with drum brakes. Different shaped outer
AE 14X6 BS-4 3/8 70 Chevelle Station Wagon
XG 14X6 BS-3 7/8 68-69 Camaro with discs brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 BS-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 BS-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 BS-4 3/8 69 Camaro/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camaro, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 BS-4 3/8 69 Chevelle SS Wheel
AO 14X7 BS-4 3/8 70 Camaro &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 BS-4 1/16 67-68 Camaro Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 BS-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Riveted instead of welded together
YS 15X6 BS-3 1/2 68-70 El Camino
FW 15X7 BS-4 1/4 71-up most any GM
AG 15X7 BS-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 BS-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 BS-4 69-82 Corvette
Here are a few extra notes:
*BS-Backspacing
* All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center.
* The 15x7 beauty ring will go on all the 15x6 wheels.
* All the hubcaps interchange with each other.
'69 Frst Grn V8 Cpe-Building now!
'68 Sequoia Grn V8 Cpe--Building now!(too)
, '68 Conv. V8 4-spd Builder
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
My build thread:
6781camaro is offline
post #9 of 9 (permalink) Old Aug 24th, 11, 08:25 PM
Jonesy's Avatar
I see errors in your reputable list above.
AO wheel was not a 70 Camaro wheel just to name one.
Jonesy is offline
Human Verification
