FAQ's, look here before you post -Warnings/Answers to common questions - Team Camaro Tech
 1Likes
  • 1 Post By davidpozzi
post #1 of 1 (permalink) Old Feb 26th, 08, 10:59 PM Thread Starter
David Pozzi
davidpozzi's Avatar
Exclamation FAQ's, look here before you post -Warnings/Answers to common questions
BRAKES
No Brakes, brake bleeding issues
LS1 Rear Disc Install Lots of Pictures
Drums to factory type Single Piston Discs
Disc brake conversion info
Power brake booster has no boost, what do I check?
Brake Valves ID - Function
Brake Valves ID - Function 2
Hydroboost conversion bracket
3rd-gen-manual-brake-conversion-pictures
SUSPENSION
Proforged tall ball joint test
Sway bar end link length
Subframe mounts, solid, rubber, or Poly?
R&R your manual steering box
STEERING
steering wheel position changed
3rd Gen Steering Box - Awesome
my-steering-upgrade-experience-list-parts-i-used
Replacement Part Numbers for Steering/Suspension - LONG
Unisteer Type 2 Power Steering Pump Install
SPRINGS
What coil springs work? Post your combo's here!
David Pozzi or ? Which Moog spring 6308, 6320 or ?
Remove/Install front coils with no engine, or subframe not in car
Leaf isolator pads or not?
Don't wait - swap mono leaf for JCW three leaf springs
Looking for a good lowering Big Block coil spring number
How I installed my front coil springs
SAFETY / WARNINGS
Please Read. Sub-Standard leaf spring clip nuts
IMPORTANT, spindle cracking discussion
Drop Spindle Warning - Tie rod hits tire
Tubular Upper and Lower Control Arms, - Imitation DSE made by SPC.
Warning! Ebay "High Tech" control arm failures
OTHER
Subframe connectors;liked, didn't like...
Guldstrand mod, modified
Global West Stage 3 Suspension install
Suspension Geometry Measurements
RideTech_Ryan likes this.
davidpozzi is offline
Closed Thread
Human Verification
