Steering arm length - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 9th, 08, 12:27 PM Thread Starter
Joe
Send a message via Yahoo to Joes_68
Steering arm length
Doing the drum to disc on front conversion. 1968 Convertible......Dropped the control arms, and installed new bushings and ball joints, also installed new BB springs and working on installing power steering. My part numbers on the steering arms are 3917193 for lh and 3917194 for rh. Can anyone tell me if these are considered the long short or medium steering arms??? Dave Pozzi's site did not have these part numbers. I have done a search on here and read most of what I can find on these swaps. I realize I need a new rag joint (no problem, Advance Auto) and a longer pittman arm. anything else I may be missing???? And will the swap work no matter which length steering arm I use??? Thank you for your help. Joe
Joes_68 is offline
post #2 of 5 (permalink) Old Apr 9th, 08, 02:17 PM
Fred
Re: Steering arm length
First thing that comes to mind is the idler arm. It has to be the same lenght as the pitman arm or you'll have 'bump-steer' problems. Not sure of the rest of your stuff????
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 5 (permalink) Old Apr 9th, 08, 06:07 PM Thread Starter
Joe
I have not seen in any of the write ups that the idler arm must be changed too..........Thanks for giving me the heads up. Still waiting if anyone knows the answer to the steering arm question. Joe
Joes_68 is offline
post #4 of 5 (permalink) Old Apr 9th, 08, 09:35 PM
David Pozzi
davidpozzi's Avatar
Code:
MAXIMUM TOE CHANGE IN INCHES
TEST 1 - Long idler/short pitman:
Passenger -  Driver       Passenger -  Driver
 31/2" susp. travel         2" susp. travel
  0.075      0.150          0.050      0.085
TEST 2  -  Long idler/long pitman:
   0.160    0.235          0.100      0.135
TEST 3  -  Short idler/long pitman:
   0.165    0.225          0.100      0.140
TEST 4  -  Short idler/short pitman:
   0.125    0.140          0.090      0.090
The sidebar says the best combination is the long idler arm
and the short pitman, with the short pitman being the best
regardless of which idler arm is used.  It also states that
bumpsteer of more than 0.125" over 3" of suspension travel
is considered excessive, and that the early Camaro exceeds
this amount.
numbers on the left are for 3.5" travel, on the right is for 2" travel
Above shows how bumpsteer varies with different combos of Pitman and idler arms. Currently, only one idler arm is available and it's in-between the long and short.
davidpozzi is offline
post #5 of 5 (permalink) Old Apr 18th, 08, 03:20 PM
David Pozzi
davidpozzi's Avatar
Joe,
I do have those numbers on my page: LONG 6" manual, - LH-3902517 RH-3902518 (67, early long measured at 6") LH-3917193 RH-3917194 slow ratio manual steering.
They are the long arms. You can still use them, your resulting ratio will be a bit slower though.
Human Verification
