2" Drop Spindles - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 28th, 12, 03:59 PM Thread Starter
2" Drop Spindles
Started the restore in ernest. Body is completely striped (interior, glass, wiring, doors, etc) media blasted and now starting to weld in sheet metal. Replaced left plenum and cowl, now putting new floor pans in.
Have the front subframe off, decided to convert to front disc (now all drum) before I start putting it back together. I need advice on two questions...
Who sells the best bang for the buck conversion kit? The car will be a driver, no shows, no racing.
Should I concider 2" drop spindles for the "look"?
The car has new booster, how can I tell if it is compatable with disc brakes? (Sorry I added the 3rd question late)
tswillow is offline
post #2 of 11 (permalink) Old Nov 28th, 12, 04:08 PM
Re: 2" Drop Spindles
I don't like them at all. They put the tie rod pretty close to the wheel.
As for brakes there are some decent GM based conversion kits out there from getdiscbrakes and speedway. I've installed both and it went pretty smooth.
67 With a few things bolted to it
98 Z28 That needs love
12 SS With a few things bolted to it
50 Chevy With a few things unbolted from it
RJ USAF
AintQik is offline
post #3 of 11 (permalink) Old Nov 28th, 12, 04:23 PM
67 Camaros Rock
Joe Harrison's Avatar
The stock GM style brakes and go with a hotchkiss springs in front. If your on a budget you can use blocks to lower the rear or go with new hotchkiss rear springs.
That would be my best bang for the buck. You can also mill down your stock spindles to convert to disc brakes but some of the kits sold from vendors here, Summit or E-bay are so cheap I don't think it's worth the time.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #4 of 11 (permalink) Old Nov 28th, 12, 04:27 PM
Shane
The booster doesn't care if the brakes are drum or disk. You need the correct MC and proportioning valve for disc/drum or disc/disc.
stea is offline
post #5 of 11 (permalink) Old Nov 28th, 12, 04:41 PM
Bob
As said above, drop spindles put the tie rod end very close to the rim, especially if your running 14" or 15" rims with deep back spacing. Much better to use drop springs or coil overs. If the springs are original, they likely need replacement anyway, so just put drop springs in.
For the brakes, I went with the Right Stuff kit, which I bought through Matt's Classic Bowties. They had better pricing than buying direct from Right Stuff.
BobKovacs is offline
post #6 of 11 (permalink) Old Nov 29th, 12, 09:12 PM
67 Camaros Rock
This is true but you need to match the master to the booster in regard to pushrod lenght or the rod the sticks out of the booster and pushes on the master to apply the brakes.
Many people mess this up and have heck of time figuring out why the peddle is very low or very high.
-Mark Donahue
post #7 of 11 (permalink) Old Nov 30th, 12, 08:38 AM
Carl
X2 on the Right Stuff kit though Matt's.
Right Stuff kit seems to be highly regarded from all my reading on this great site.
Matt's has great pricing to begin with and gave me a great Black Friday deal. My 4 wheel kit is in transit right now - can't wait!!
69RSRAG is offline
post #8 of 11 (permalink) Old Nov 30th, 12, 09:00 AM
Bob
Everything in the kit fit great, and their customer service is great as well. I had a problem with one of the rotors having a hole in it, so I called Right Stuff, and they shipped a new one out the same day. Gotta swap it out this weekend and get the old one sent back to them.
post #9 of 11 (permalink) Old Nov 30th, 12, 09:13 AM
Oh and for what its worth I run an adustable push rod on my system so I really don't have an issue with length. I can put the pedal where I want it.
RJ USAF
AintQik is offline
post #10 of 11 (permalink) Old Nov 30th, 12, 11:27 AM
Greg
I got the Right Stuff brakes through Summit racing. Great kit, and their customer service at The Right Stuff is great.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #11 of 11 (permalink) Old Nov 30th, 12, 12:41 PM
67 Camaros Rock
Adjustable from the booster to the master or from the booster to the peddle? Not that I am any type of an expert but I have not seen an adjustable rod from the booster to the master. Please provide a part number or where to get one, this could help some people since all you would have to do is replace the rod and not the booster.
-Mark Donahue
Human Verification
