Police Brakes on BV 12 Bolt - Page 2 - Team Camaro Tech
post #16 of 32 (permalink) Old Feb 3rd, 13, 07:56 PM Thread Starter
Niclas
Nikke's Avatar
Re: Police Brakes on BV 12 Bolt
Originally Posted by bcm66 View Post
It could be a real BV rear. I can't say one way or the other. The pics I wanted to see were of the END of the axle tube, right next to the backing plate. Is the tube full size in that area or does it get smaller toward the end?
It is possible that the bigger brakes were put on, but I would think they would have put on rear disc brakes if they were going to swap things out.
Its a Project Car, Old Drag Racer and I dont think that the racers cared about the stamps.
From Factory SS L78 4 Speed Le Mans Blue no PS.
The question was if you could Order Police Brakes on first gen Camaro from Fabric as they say in the Classic Ind Catalog.
I have never heard or read about that you could so thats why I asked.
Nikke is offline
post #17 of 32 (permalink) Old Feb 3rd, 13, 08:37 PM
Bryon
bcm66's Avatar
Originally Posted by Nikke View Post
The question was if you could Order Police Brakes on first gen Camaro.
Not as far as I know. Nothing in the RPOs.
Doesn't make a lot of sense to me why they would add them on race car. The front brakes do most of the stopping, and bigger brakes would just add weight.
68 Camaro SS 396 - 468 BBC now, Air Gap Intake, 781 heads, M21, 12 bolt. / 67 Chevelle SS 396.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #18 of 32 (permalink) Old Feb 4th, 13, 04:51 PM Thread Starter
Niclas
Nikke's Avatar
More weight in the rear is good in Drag Racing.
But probably for better Brakes.
Short Strip?
My outher Old Drag Race Camaro was full of sand in the rear Wheelhouse.
Police Brakes
Nikke is offline
post #19 of 32 (permalink) Old Feb 4th, 13, 05:26 PM
keith
Looks like someone has done some axel tube work. I believe the tube should choke down at the backing plate mount. Drums are not from a first gen Camaro. I could be wrong. Once I thought I was wrong, but I was mistaken. Just kidding. I put big drums on my car , they work great.
X-77 keith is offline
post #20 of 32 (permalink) Old Feb 4th, 13, 05:48 PM Thread Starter
Niclas
Nikke's Avatar
Yes they have.
Nikke is offline
post #21 of 32 (permalink) Old Feb 4th, 13, 09:01 PM
the bigger brakes will hold better when holding the rpm's up against the torque converter at the line. i know the GN guys like to do things like use 2 sets of the "long" shoes and wheel cylinders with a bigger bore to help them hold more boost on the line for a harder launch.
you don't plan sincerity.
novaderrik is offline
post #22 of 32 (permalink) Old Feb 4th, 13, 09:04 PM
Short Strip?
Police Brakes
those ends look kinda goofy to me, and the shape of the drums look more like what was on the rear of my 78 Ford LTD II- what is the wheel bolt pattern and does it have 1/2" studs?
post #23 of 32 (permalink) Old Feb 4th, 13, 09:19 PM
James
Looks like a Ford 9" style bearing end was welded on. That would eliminate the C-clip design as required at many race tracks.
What's it look like under the drum?
68 Ragtop is offline
post #24 of 32 (permalink) Old Feb 5th, 13, 03:38 PM
Bryon
bcm66's Avatar
Niclas,
Now do you know why earlier I asked to see a picture of the end of the axle tube?
Was this car originally assembled in the USA or at one of the foreign vehicle plants?
CRG -
bcm66 is offline
post #25 of 32 (permalink) Old Feb 5th, 13, 03:54 PM Thread Starter
Niclas
Nikke's Avatar
Niclas,
Its a LOS plant built Camaro.
Nikke is offline
post #26 of 32 (permalink) Old Feb 5th, 13, 03:58 PM
Bryon
bcm66's Avatar
OK, cool.
I still don't quite understand why they did what they did. Any idea if these modifications were done while in the USA or when in was in your area? And this was a drag race car?
CRG -
bcm66 is offline
post #27 of 32 (permalink) Old Feb 5th, 13, 04:02 PM
Vintage 68's Avatar
Wink Re: Police Brakes on BV 12 Bolt
Originally Posted by novaderrik View Post
those ends look kinda goofy to me, and the shape of the drums look more like what was on the rear of my 78 Ford ...
Those are 9" Ford "Big" hosing ends.
Most likely installed as stated to eliminate 'C Clip' axles ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #28 of 32 (permalink) Old Feb 5th, 13, 04:06 PM Thread Starter
Niclas
Nikke's Avatar
This was done in the States.
Car came from Idaho.
Nikke is offline
post #29 of 32 (permalink) Old Feb 5th, 13, 04:28 PM
Bryon
bcm66's Avatar
I understand the reason why they went to the c clip eliminator ends if this was a race car. No problem there.
The person that hacked up that BV rear must not have been thinking.
If they could do all of the modifications that they did to this 12 bolt, they should have just started with a 9 inch and modified it to fit under the Camaro.
CRG -
bcm66 is offline
post #30 of 32 (permalink) Old Feb 6th, 13, 05:44 PM
welding the "Torino" ends on GM axle housings isn't anything new- you can even get the ends and retainers with the GM pattern to allow you to keep your stock brakes these days. it's a common thing to do on the 8.5's they put in 80's GN's to help them hold up to insane amounts of power, and those housings are a pretty rare part to begin with.
Human Verification
