Replacement Part Numbers for Steering/Suspension - LONG - Team Camaro Tech
post #1 of 15 (permalink) Old Aug 8th, 02, 05:47 AM Thread Starter
Guess
HwyStarJoe's Avatar
Hey all,
This is very long. It lists the Federated Chassis, MOOG and TRW part numbers for a lot of the front/rear suspension and steering parts. I took them off of the Federal Mogul web site and put them in a list by 1969 Camaro model - Z28, small and then big block. I'll do a 1967 and 1968 by engine size listing if anyone wants.
It doesn't format exactly like I created it but it's readable:
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro Z28
Lower Ball Joint: K5103 Federated Chassis
10197 TRW
Upper Ball Joint: K5108 Federated
10195 TRW
A-Arm Adjustment Shims: 1/32" MOOG K961
1/16" MOOG K962
1/8" MOOG K963
Front Coil Springs: TRW CS6312 Constant rate, regular without A/C, Sport Coupe
TRW CS638 With A/C
Same TRW part numbers for High Perf. springs
Control Arm Bushings/Shafts: Upper - K5196 Federated Chassis / MOOG
Lower - K6076 Federated / MOOG
MOOG K5250 [Upper Control Arm Offset Shaft Kit] Problem Solver Kit; Provides Additional Positive Camb er Adjustment; Front Suspension
Idler Arm: K6099 Federated / MOOG
18718 TRW
Chassis Illustration Reference: 01008407MOO Steering Linkage - MOOG
01008301MOO Front Suspension - MOOG
02004601TRW Steering Linkage - TRW
02004701TRW Front Suspension - TRW
Pitman Arm: 18770 TRW w/special steering, w/power steering
Rear Suspension Bushings: B298 TRW Front spring bushing
HB1003 TRW Rear spring bushing - 8 used
Gear Kit, Steering: 2757 Omega - Master Gear Kit, Camaro
2779 Omega - [Gear Kit] Adj. Plug; Camaro List.; Supersedes {2774}
Power Steering Pressure Hose: 564 Omega - [Power Steering Hose] Pres.; OE; Camaro List.
852 Omega - [Power Steering Hose] Pres.; Mod.; Camaro List.
Pwr Steer. Return Hose: 30903 OMEGA [Power Steering Hose] Return; Mod.; Bulk Hose; 25 in. ; Camaro List.
675 OMEGA [Power Steering Hose] Return; OE; Camaro List.
950 OMEGA [Power Steering Hose] Return; Mod.; Bulk Hose; 25 in.; Or {30903}; Camaro List.
Power Steering Pump Kit: 2759 Omega - [Seal Kit] Pump; Camaro List.
Sway Bar Bushing: K5227 FEDERATED CHASSIS [Sway Bar Bushing Kit]
K5227 MOOG [Sway Bar Bushing Kit]
Sway Bar End Links: K6217 MOOG [Sway Bar Link Kit]
Tie-Rod End Adjusting Sleeve: FEDERATED CHASSIS ES350S [Sleeve] Right & Left
MOOG ES350S [Sleeve] Right & Left
Tie-Rod End - Driver Inner: FEDERATED CHASSIS ES681N [Tie Rod End] Driver Side; Inner
MOOG ES681N [Tie Rod End] Driver Side; Inner
TRW ES681N Driver Inner, 1968-70
Tie-Rod End - Driver Outer: FEDERATED CHASSIS ES381RL [Tie Rod End] Driver Side; Outer
MOOG ES381RL [Tie Rod End] Driver Side; Outer
Tie-Rod End - Passenger Inner: FEDERATED CHASSIS ES681N [Tie Rod End] Pass. Side; Inner
MOOG ES681N [Tie Rod End] Pass. Side; Inner
TRW ES681N Passenger Inner, 1968-70
Tie-Rod End - Passenger Outer: FEDERATED CHASSIS ES381RL [Tie Rod End] Pass. Side; Outer
MOOG ES381RL [Tie Rod End] Pass. Side; Outer
Tie-Rod End/Drag Link (at Pitman Arm): TRW ES350S [Tie Rod Adjusting Sleeve] Passenger
TRW ES350S [Tie Rod Adjusting Sleeve] Driver
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro 350ci
Allignment Front Kit: MOOG K5250 [Offset Shaft Kit] Frt.; Problem Solver; Upper Control Arm Kit w/Bushings; Provides Add. P os. Camber; 2 Req.
MOOG K961 [Custom Shims] Frt.; 1/32 in. Thick
MOOG K962 [Custom Shims] Frt.; 1/16 in. Thick
MOOG K963 [Custom Shims] Frt.; 1/8 in. Thick
Lower Ball Joint: FEDERATED CHASSIS K5103 [Lower Ball Joint]
MOOG K5103 [Lower Ball Joint] Front Suspension; 2 Required
TRW 10197 use two per vehicle; Incl. CUSTOM
Upper Ball Joint: FEDERATED CHASSIS K5108 [Upper Ball Joint]
MOOG K5108 [Upper Ball Joint] Front Suspension; 2 Required
TRW 10195 use two per vehicle; Incl. CUSTOM
Front Coil Springs: MOOG 6312 [Coil Spring] Frt.; HD; w/o A/C; Sport Cpe.
MOOG 638 [Coil Spring] Frt.; Conv.; Sport Cpe. (A/C)
MOOG 638 [Coil Spring] Frt.; HD; A/C; Sport Cpe.
MOOG 6312 [Coil Spring] Frt.; w/o A/C; Sport Cpe.
TRW CS6312 [Coil Springs] Front; Constant Rate; Regular; w/o A.C.; Sport Coupe
TRW CS638 [Coil Springs] Front; Constant Rate; Regular; w/A.C.; Sport Coupe
Front Heavy Duty/Perf. Coil Springs: TRW CS6312 [Coil Springs] Front; Constant Rate; Heavy Duty; w/o A.C.; Sport Coupe
TRW CS638 [Coil Springs] Front; Constant Rate; Heavy Duty; w/o A.C.; Sport Coupe
Connecting Tie-Rods: MOOG ES381RL [Outer Tie Rod End] Front Suspension; 2 Required
MOOG ES681N [Inner Tie Rod End] Front Suspension; 2 Required
Control Arm Bushings/Shafts: SAME AS Z28
Idler Arm: MOOG K6099 [Idler Arm] Front Suspension; 1 Required
TRW 18718 [Idler Arm]
Chassis Illustration Reference: SAME AS Z28
Leaf Springs: MOOG K6559 [Leaf Spring Bushings] Rear Suspension; Bushing Location Shackle
MOOG SB298 [Leaf Spring Bushings] Rear Suspension; Bushing Location Front
Pitman Arm: MOOG K6150 [Pitman Arm] Front Suspension; Manual Steering; 1 Required
MOOG K6582 [Pitman Arm] Front Suspension; Power Steering; 1 Required; 5.78" Between Center of Stud & Center of Spine.
TRW 18768 Manual Steering Exc. 302 Engine
TRW 18770 Power Steering (w/ 5.78" Stud Center to Spline Center) 1968-69, All 1967
Rear Suspension Bushings: SAME AS Z28
Steering Gear Kit: BCA/NATIONAL PSK-1 [Oil Seal Kit] RWD Power Steering; (Kit)
OMEGA 2757 [Gear Kit] Mstr.
OMEGA 2779 [Gear Kit] Adj. Plug; Supersedes {2774}
PART NUMBERS FOR FRONT SUSPENSION/STEERING: 1969 Camaro 396ci - Only Changes from Z28 and SmallBlock
Front Coil Springs: MOOG 638 [Coil Spring] Frt.; w/o A/C; Sport Cpe.
TRW CS638 [Coil Springs] Front; Constant Rate; Regular; w/o A.C.; Sport Coupe
Control Arm Bushing Kit: FEDERATED CHASSIS K5196 [Control Arm Bushing Kit] Upper; 2 Required *
FEDERATED CHASSIS K6076 [Lower Control Arm Bushing Kit] Lower; 2 Required *
MOOG K5196 [Upper Control Arm Bushing Kit] Front Suspension; 2 Required *
MOOG K5250 [Upper Control Arm Offset Shaft Kit] Problem Solver Kit; Provides Additional Positive Camb er Adjustment; Front Suspension; 2 Required *
MOOG K6076 [Lower Control Arm Bushing Kit] Front Suspension; 2 Required *
TRW 12162 4 Used, Upper Arm *
TRW 12237 Front, Lower Arm *
TRW 12258 Rear, Lower Arm
Control Arm Shaft Kit: TRW 13158A Upper Shaft Kit, use two per vehicle
Pitman Arm: MOOG K6150 [Pitman Arm] Front Suspension; Manual Steering; 1 Required *
MOOG K6582 [Pitman Arm] Front Suspension; Power Steering; 1 Required; 5.78" Between Center of Stud & Center of Spine. *
TRW 18768 Manual Steering Exc. 302 Engine *
Sway Bar Link Kit: MOOG K6217 [Sway Bar Link Kit] Front Suspension; 2 Required *
TRW 18060 [Sway Bar Link Kit] Standard, use two per vehicle *
TRW 18203 [Sway Bar Link Kit] Heavy Duty, use two per vehicle
[This message has been edited by HwyStarJoe (edited 08-08-2002).]
HwyStarJoe is offline
post #2 of 15 (permalink) Old Aug 8th, 02, 09:29 AM
David Pozzi
davidpozzi's Avatar
WOW!
I'm impressed! Thanks for the info!
1968 should be the same as 69 and 67 should be the same except for outer tie rod is 1" shorter and toe in adjuster sleeve is a half inch longer.
Here's a short list from my web page:
MOOG#
Both sides outer tie rod 67 ES348R (4.62" long)these are shorter than 68-69, don't know why, is adjuster sleeve longer on a 67?
Both sides outer tie rod 68-69 ES381RL (5.75" long)
Both sides Inner tie rod 67-69 ES681N
Toe in adjuster sleeve 68-69 ES350S
Upper ball joint K5108 67-69
Lower ball joint K5103 67-69
Upper control arm Shaft kit K5250
Idler arm + bracket K6099 all 68-69 5.375" long - cast iron, not forged steel.
Idler arm, K6093 all 67 5 3/4" long (no longer available)
Pitman, manual K6150 68-69 (short)
Pitman K6151 PS, short 5.25"
Pitman, PS K6154, 67-69 5.78" long (probably 5 3/4") 32 splines 1.1-1.18 diam. Not longer available from Moog.
Pitman, PS , long, Moog# 6582 New production run, no grease fitting - Currently available at any auto parts store that sells Moog parts.
Pitman, PS long, TRW # 18770 Same as above. Probably a Moog part in a TRW box.
NOTE: There are two length pitman arms for power and two lengths for manual. Std 17 to 1 ratio power steering uses 5.25"
Optional fast ratio PS, uses 5.7" long Pitman arm.
http://www.PozziRacing.com
davidpozzi is offline
post #3 of 15 (permalink) Old Aug 8th, 02, 09:57 AM Thread Starter
Guess
HwyStarJoe's Avatar
My pleasure....
I have to do SOMETHING while on these darn conference calls.
I already noticed some part number differences with respect to tie-rod ends that I've found here in other threads. I guess we can only assume that they are up-to-date on their web site. And someone asked about their new ball-joints... it's one of the first things you see when you open the site. http://www.federal-mogul.com/moog/st...uspension.html
(OR USE: http://www.federal-mogul.com/cda/cha...691923,00.html
added by David)
The power of Google!
[ 07-21-2004, 01:51 PM: Message edited by: davidpozzi ]
post #4 of 15 (permalink) Old Aug 8th, 02, 03:18 PM
Bruno
David, knowing that I have to order a new pitman for my new steering box. Is the part number for the one I need, mentioned here? Pitman Arm:
TRW 18770 Power Steering (w/ 5.78" Stud Center to Spline Center) 1968-69, All 1967[/B]
ORENCH is offline
post #5 of 15 (permalink) Old Mar 8th, 06, 05:39 PM Thread Starter
Guess
HwyStarJoe's Avatar
Exclamation Re: Replacement Part Numbers for Steering/Suspension - LONG
Here are some updated links. The original links noted above do not work:
Federal-Mogul's EConnect Web Catalog - searchable by year. Go to Catalogs, then pick which catalog you want to search:
Federal-Mogul site
Federal-Mogul Products and Brands
TRW seems to have sold off their steering and suspension product lines to other vendors in North America, and concentrate on commercial products instead.
post #6 of 15 (permalink) Old Mar 8th, 06, 09:17 PM
David Pozzi
davidpozzi's Avatar
Joe,
Try "Edit" and fix your prev post.
I finally found this after losing it a time or two.
Recient forum updates unstuck a couple of stickey posts I had.
post #7 of 15 (permalink) Old Mar 9th, 06, 04:13 AM Thread Starter
Guess
HwyStarJoe's Avatar
Fix which post David? The original at the top, or yesterdays?
post #8 of 15 (permalink) Old Aug 20th, 06, 02:55 PM
You guys sure know your stuff, I refer to your threads often and always am amazed with the amount of information.
I do have a question though.
In reading I have found the part # 6312 for the Moog front springs, I pulled the coil springs off my 68 Camaro RS 350 for rebuild and found the part # 6312DV can you help me identify these?
1968 RS 350/350TH
MI68 is offline
post #9 of 15 (permalink) Old Aug 26th, 06, 07:12 PM Thread Starter
Guess
HwyStarJoe's Avatar
Maybe they're replacement Moog springs in your car?
post #10 of 15 (permalink) Old Sep 1st, 06, 07:11 PM
Barry J
Barry J's Avatar
Yeah, if you could do this out for a 67 350 or 327 camaro, that would help me greatly . I'm looking on doing manual steering to power steering conversion.
Barry
"Kids in backseats dont cause accidents.
..accidents in backseats cause kids!!"
Barry J is offline
post #11 of 15 (permalink) Old Sep 22nd, 06, 10:00 PM
David Pozzi
davidpozzi's Avatar
6312 is a moog or TRW replacement coil It's slightly taller than some of the other Moog coils, would yield a slightly higher ride height or is for a heavier Camaro like a big block. It's not stiffer at 337 lbs/inch.
post #12 of 15 (permalink) Old Jun 23rd, 07, 12:49 PM
Paul
I just got control arm bushings on e-bay. They were listed as "67 1968 1969 Camaro Nova RS/SS Z28 Front Poly Bushings". I have found that one of the lower bushings is way too large. Is what he sold me for a big block car?
bigproj69 is offline
post #13 of 15 (permalink) Old Jun 28th, 07, 03:39 PM
David Pozzi
davidpozzi's Avatar
No, all first gen bushings interchange, even 6 cylinder.
post #14 of 15 (permalink) Old Feb 4th, 08, 08:01 PM
Gary
Joe...
excellent post and thanks for taking the time to gather it up....
cheers
Gary
Gary 9t4Z
69,70,91,91,94
9T4Z is offline
post #15 of 15 (permalink) Old Sep 16th, 12, 10:50 AM
Brock
Where exactly do you find the part number on a steering column?
Brock_Baker is offline
Human Verification
