'69 Camaro Weights - Team Camaro Tech
post #1 of 17 (permalink) Old Feb 3rd, 06, 06:15 PM Thread Starter
JohnZ's Avatar
'69 Camaro Weights
At David's request, here are '69 Camaro standard-equipment model weights, with the net add or subtract effect of each option:
6-cyl. Coupe: 3005
8-cyl. Coupe: 3135
6-cyl. 'Vert: 3255
8-cyl. 'Vert: 3385
A31 Power Windows +19
A67 Folding Rear Seat +38
C06 Power Top +8
C08 Vinyl Top +6
C60 Air Conditioning +97
D80 Spoiler Equipment +7
J50 Power Brakes +11
J52 Front Disc Brakes +26
JL8 4-Wheel Disc Brakes +97
L22 155hp L-6 Engine +17
LM1 350/255hp Engine +86
L48 350/300hp Engine +86
L35/34/78 396 Engine +249
U63 AM Radio +8
U69 AM-FM Radio +10
U79 Stereo Radio +17
M11 Floor Shift Control +9
M20 Saginaw 4-Speed +16
M20/21/22 Muncie 4-Speed +4
M35 Powerglide with V-8 -5
M35 Powerglide with L-6 -10
M38 THM-350 Transmission +23
M40 THM-400 Transmission +57
MB1 Torque-Drive Trans -17
MC1 H.D. 3-Speed Trans +31
N40 Power Steering +28
Z22 Rally Sport Package +27
Z28 Special Equip. Package +83
ZL2 Special Ducted Hood +8
JohnZ
CRG
'69 Z/28 Fathom Green
JohnZ is offline
post #2 of 17 (permalink) Old Feb 3rd, 06, 06:18 PM
Re: '69 Camaro Weights
Oooh, do you have the same for a 68???
: (0-60 in 5s, 1/4 in 13.22s) 350ci, th-350, open 2.73 8.2", 295/60 rears, QA1 12 way rear & front w/coil adjusters. In Garage: 415ci roller stroker, Tremec TKO-600, 1350 D-shaft and ...
SoCalFirstGen is offline
post #3 of 17 (permalink) Old Feb 3rd, 06, 10:16 PM
Sean
yes, do show the 68 please!
by the way, what added 83 #'s on the Z28 package? was that a sum of all parts included w/rpo Z28, or in addition to the parts/options listed above?
Sean
1968 rs, with an old school, antiquated "junkyard, never even had the valve covers off" 354" SB2.2 pump gas motor........
"I aint never seen talking win me nothin'" -Marshawn Lynch
68rs406 is offline
post #4 of 17 (permalink) Old Feb 3rd, 06, 10:40 PM
David Pozzi
davidpozzi's Avatar
Thanks John!
davidpozzi is offline
post #5 of 17 (permalink) Old Feb 4th, 06, 05:58 AM
Christropher
Sweet John! Thanks! Hopefully you can find a list for the 67 and 68s
Christropher
...in pieces still.
clwilcox33 is offline
post #6 of 17 (permalink) Old Feb 4th, 06, 10:49 AM
Rick
Wow - thanks!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #7 of 17 (permalink) Old Feb 4th, 06, 06:00 PM Thread Starter
JohnZ's Avatar
I think that includes the added weight of the mandatory power disc brakes, 12-bolt axle and multi-leaf springs, 3-row radiator and fan/clutch, dual exhaust system, Muncie 4-speed, and larger wheels and tires (all of which are additional over the weight of the base V-8 coupe).
I don't have the '67-'68 weights, but they're in the free restoration package you can get from Chevrolet at (800) 222-1020; I just have the '69 info.
JohnZ
CRG
JohnZ is offline
post #8 of 17 (permalink) Old Feb 4th, 06, 07:21 PM
67LSRS
Re: '67 Camaro Weights
Here they are for the 67 from the same resto doc's
6-cyl. Coupe: 2910
8-cyl. Coupe: 3070
6-cyl. 'Vert: 3165
8-cyl. 'Vert: 3325
A31 Power Windows +21
A67 Folding Rear Seat +20
C48 Less Heater -24
C60 Air Conditioning +86
J50 Power Brakes +9
J52 Front Disc Brakes +33
L22 155hp L-6 Engine +10
L30 327 Cu InEngine +39
L35 396 Cu In Engine +258
L48 350 Cu In Engine +72
M13 Heavy Duty 3-Spd. Trans. W L48 +22
M20 4-Speed Trans +7
M35 Powerglide with +14
M40 3 Spd Turbo Hydra-Matic Trans +56
N10 Dual Exhaust +38
N40 Power Steering +29
T60 Heavy Duty Battery +15
U63 Radio Push Button +8
U69 Radio AM/FM Push Button +9
Z22 Rally Sport Package +17
_____________________________________________
My 67 RS Project:
LS1, FAST XFI 2.0, Turbo 350, 12 Bolt 3.73's.
67LSRS is offline
post #9 of 17 (permalink) Old Feb 4th, 06, 09:07 PM
Banned
Question Re: '69 Camaro Weights
Good info but I woulda thought they woulda listed a console and gage package's weight too?
pdq67
post #10 of 17 (permalink) Old Feb 4th, 06, 09:25 PM
67LSRS
No the listing is kinda lean. But better then nothing I guess.
My 67 RS Project:
67LSRS is offline
post #11 of 17 (permalink) Old Feb 4th, 06, 10:22 PM
Thank you. This is a great starting point (67 is close enough for me) on figuring out how much the modifications I've made have altered the weight of hte car.
post #12 of 17 (permalink) Old Feb 4th, 06, 10:59 PM
Sean
thanks you guy's! excellent info. i should get myself one of those info packets, didn't know they included this type of information.
Sean
68rs406 is offline
post #13 of 17 (permalink) Old Dec 1st, 12, 02:48 PM
Pat
67restoproj's Avatar
Old thread, but interesting information...I would have thought a convertible is lighter. thanks John
1969 Camaro X77 Z/28 Lemans Blue
1991 Camaro Z28 1LE- R7u #33 Players Challenge
1991 Camaro z28 1LE-R7U #58 Players Challenge
67restoproj is offline
post #14 of 17 (permalink) Old Dec 1st, 12, 05:24 PM
Tim
The 'vert is heavier than the coupe/hardtop mainly because of all the extra stiffening and reinforcement that the body needs without the bracing effect of the roof. But even with all the extra bracing, the 'vert bodies lack the torsional rigidity of coupes/hardtops, which becomes far more noticeable when adding a lot more hp and torque than stock.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
post #15 of 17 (permalink) Old Dec 1st, 12, 07:14 PM
The cocktail shakers are about 25lbs/ea (x4) and the convert top frame is quite heavy also.
BPOS is offline
Human Verification
