68 Camaro control arm bushing install Qs - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 16th, 06, 07:07 AM Thread Starter
My friend just recieved his control arms back from the powder coaters. I realize it is a 68 but I believe it will be roughly the same procedure as a second gen to install control arm bushings.(Energy Suspension BTW) I still have a couple of questions that maybe you guys can help me with:
1. Will the powder coating pose a problem for installing the control arm bushings?
2. Is there a lubricant I should use for installing these bushings?
3. How will I know when the bushings are pressed far enough?
4. For the upper control arms, I realize the shaft will have to be installed at this time, is there any tips for installing the shaft or any specific procedures?
Thanks guys!
DirtyScotty is offline
post #2 of 2 (permalink) Old Oct 16th, 06, 07:19 AM
Re: 68 Camaro control arm bushing install Qs
1) Depends on if the powder coater corked the openings or not, you can't have any powdercoating where the bushing sleeves (metal) slide into the control arms. If you do, use a dremel tool with stone attachment and clean off that stuff in those areas.
2) Control Arm bushings (poly at least) come with a grease, you remove the poly bushings from the metal sleeves, grease them up, and slide them back in.
No grease for the metal to metal contact areas but a little PB Blast might help install
3) The shaft that sits between the control arm and the subframe will be snug between the front and rear bushings
4) Install one bushing, install the shaft, start installing the other bushing.
69 Camaro and 63 Nova
Brian Lewis is offline
Human Verification
68 Camaro upper Control Arm bushing removal DirtyScotty Brakes, Suspension & Steering 2 Oct 3rd, 06 08:23 PM
68 Camaro Paint list tronic72 Body Shop 1 Jan 21st, 06 03:20 AM
96 Camaro has backwards wiper arm? spriggan72 Troubleshooting 0 Jan 8th, 06 02:55 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
