68 Ragtop sane tire choice - Team Camaro Tech
post #1 of 11 (permalink) Old Aug 28th, 13, 05:07 PM Thread Starter
George
making a Day2 Cruiser, have 15x7 Rallys already powdercoated, ready to go.
Few choices in Raised White Letter tires and my car sure needs a little more zing like RWL can supply.
Seems the BFG 215/65/15 are backordered or worse
Looked at 225/60/15, shorter, wider....
Is anybody running these on all four corners? Have seen people where the 235/60 rubs in the front. Would like to rotate the tires. Eventually they will go on my 68 Corvette
Anybody with these tires on the car, post up a snapshot please!
George Kettler
US ARMY Retired
o 70 Elky SOLD 9/2016
o 68 Vette 427, 4 spd ac owner 25 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73
kettbo is offline
post #2 of 11 (permalink) Old Aug 29th, 13, 09:26 AM
Re: 68 Ragtop sane tire choice
I have the 215/65/15's on 15x7 rallys in a stock suspension 69 z/28. If you look at my photo album you can see them there.
Dave69Z is offline
post #3 of 11 (permalink) Old Aug 29th, 13, 04:22 PM Thread Starter
George
Dave,
THAT is the look....how much different would 225/60R15 look compared to the 215/65s? Do not want to add bulk. want LARGELY STOCK but sneak a bit more rubber in there
George Kettler
US ARMY Retired
kettbo is offline
post #4 of 11 (permalink) Old Aug 30th, 13, 04:31 AM
Im not sure how it would look from the side since they are shorter. I have seen themonthefront of cars and they look a little more agressive if viewed directly from the front since theyaare wider. Many people go the 235/60/15 route. good luck.
Dave69Z is offline
post #5 of 11 (permalink) Old Aug 30th, 13, 06:15 AM
Nate
I thought I had a better pic but 225/60/15 t/a on the front on a 15x7. 1" lowering spring.
nblehm is offline
post #6 of 11 (permalink) Old Aug 30th, 13, 09:10 PM Thread Starter
George
Thanks for the posts and the pics...hope we get a few other responses
I have always heard the 235/60 15 will rub to the inside. Also my pretty fiberglass on the 68 Vette when I swap on the TAs for driving vs bias ply redlines for show
George Kettler
US ARMY Retired
kettbo is offline
post #7 of 11 (permalink) Old Aug 31st, 13, 06:46 AM
Nick
Rarerat's Avatar
George,
here's a pic of my 68 with 7" rallys and 225 x 60's. They fit well with no rubbing. I did try a set of 235's up front but they rubbed the fender every time I hit a dip in the road. IMHO 225 60's on the rear will be way to small & look funny. I have a set of 235 60's on the rear of our 68 Vert and they even look a little small with the rounded the fender wells.
On my 69 I'm running 225 60's up front & 235 60's in the rear and they seem to fit the car pretty good, although when it's time for tires again I will probably go back to 215 65's..
I hope this helps & good luck...
Rarerat is offline
post #8 of 11 (permalink) Old Sep 1st, 13, 07:59 PM Thread Starter
George
Nick,
I sure helps!
Here is the Camaro years back with the FRONT stock off my 70 Elky. Elky was visiting the paint shop. 215/65s on Welds
275/60 DRs....way too big
lame 14" and 75 series 'may pop' tires....when I took the car apart, I saw how REALLY SCREWED UP the tires were.
hmmm, 225s do look good, serious look at 235 rears
George Kettler
US ARMY Retired
kettbo is offline
post #9 of 11 (permalink) Old Sep 2nd, 13, 07:01 AM
Brent
67Rally's Avatar
225/60's will have about 5mm or 3/16" less sidewall from edge of rim to outside of tire compared to the 215/65.
If you're going to stagger (and therefore not be able to rotate tires) I would go with a wider rear like a 255/60. As long as the backspacing is correct.
67Rally is offline
post #10 of 11 (permalink) Old Sep 3rd, 13, 10:19 AM Thread Starter
George
decisions, decisions.....
Met with pal Craig from Team Chevelle and local TCNWRacing site. He's a big fan of the Cooper Cobras. The 216/65R15 is available. Mickey Thompson does not make this size. oh hell
George Kettler
US ARMY Retired
kettbo is offline
post #11 of 11 (permalink) Old Sep 3rd, 13, 02:00 PM
Chad
cv2065's Avatar
If you want two BF Goodrich tires in 215/65/15's, I've got two brand new in the box that I was about to send back. I know that they are very hard to come by these days for whatever reason.
cv2065 is offline
Human Verification
