68 l78 - Team Camaro Tech
post #1 of 15 (permalink) Old Mar 19th, 17, 04:31 PM Thread Starter
Stephen
Stephen's Avatar
68 l78
Hi All
I am trying to find out what are the correct wheels for my car
I understand that an L78 came with front (only) disc brakes
I also understand from CRG that unlike 67, where disc brakes would obligate rallye wheels, that was not the case in 68:
"For 1967, rally wheels were required when disc brakes were ordered. This restriction was removed in 1968 (despite some 1968 dealer literature that indicates that disc brakes were required with rally wheels). Which means that in 1968-69, disc brake cars came with plain steel wheels, unless the ZJ7 rally wheel option was added (except for Z28 which included rally wheels)." Camaro Chassis - Suspension, Axle, Brakes, & Wheels
so, according to the chart on the same page, my wheels would be XF:
Year Type Brakes Code Size Application
1968 Steel Disc XF 14x6 Base, SS
do you agree?
if the disc brakes are only on the front, does that mean that just the fronts would be XF and the rears would be FC?
Lastly, if my car was a June 68 build, what would be the correct date range for wheels that would have come with my car?
Thanks!
Stephen is offline
post #2 of 15 (permalink) Old Mar 19th, 17, 08:27 PM
Garth
Re: 68 l78
Power brakes (not disc) were required on big block cars starting in April 68. See foot note #8...
CRG Visual ID 1968 Model HyperTable
So your car being a June build, definitely had power brakes. Is there any other evidence suggesting disc or drum brakes ? Do you have the booster and any chance it's original ?
Garfields Maro is offline
post #3 of 15 (permalink) Old Mar 19th, 17, 10:06 PM
Garth
Re: 68 l78
OK, I seen your car in the "Welcome Wagon" forum, nice find ! ...and welcome back !
So it most likely had PDB originally. You can investigate that further if you wish, to confirm. You could check the code on the booster to start with. The master cylinder is an aftermarket replacement, I believe, but that can be expected.
You're correct, original wheels would've been XF coded if they were standard wheels or XG coded if optional rally wheels were ordered. All 5 (including the spare) would be the same.
I'm not sure on acceptable dates. 3wks -3months prior to the car build date is my best guess ?
post #4 of 15 (permalink) Old Mar 20th, 17, 10:14 AM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
Thanks Garth
on the booster, what am i looking for and where is it located?
yes, the MB cylinder is after market
thanks for your assistance!
anyone else have a thought on an acceptable date range?
thanks
Stephen is offline
post #5 of 15 (permalink) Old Mar 20th, 17, 02:14 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
PS: to be clear, a 14" x 6" wheel (i.e., the XF) will fit over the 4 piston caliper of the front brakes? (and yes, I have power brakes and disc brakes in the front; drums in the rear)
thanks,
Stephen is offline
post #6 of 15 (permalink) Old Mar 20th, 17, 02:18 PM
Garth
Re: 68 l78
Yep, you're welcome.
The booster code is on the tab at the top. 9079 is drum, 9078 is disc. There's a date code on the back as well.
post #7 of 15 (permalink) Old Mar 20th, 17, 02:23 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
Thanks Garth
I'll check (for some reason, from memory, i want to say it is 441...but that doesn't match up with what you wrote...we'll see)
Stephen is offline
post #8 of 15 (permalink) Old Mar 20th, 17, 02:28 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
have checked - it is "144" - aftermarket?
Stephen is offline
post #9 of 15 (permalink) Old Mar 20th, 17, 02:35 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
the break pedal is stamped "disc brake"...which is consistent with a 68:
CRG: "1968 - Manual drum brakes on all four wheels remained standard for all models except Z28 and mid-year SS396. RPO J50 power assist remained a separate option for drum brakes, but RPO J52 front disc brakes now included RPO J50, and thus all 1968 disc brakes were also power disc brakes. This was the last year for the 4-piston disc brake calipers. The disc brake emblem appeared on the brake pedal of disc brake equipped cars in the January / February 68 timeframe."
Stephen is offline
post #10 of 15 (permalink) Old Mar 20th, 17, 02:39 PM
Garth
Re: 68 l78
I think 144 might be the Julian date. That's on the rear side ? Check the other side of the tab for the 907X code.
Camaro VIN, Cowl Tag, and other Numbers Decoding
post #11 of 15 (permalink) Old Mar 20th, 17, 04:05 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
That was on the front
Will have to look at back tomorrow
Sent from my SM-G935V using Tapatalk
Stephen is offline
post #12 of 15 (permalink) Old Mar 20th, 17, 04:42 PM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
By the way, 144 if it stands for the 144th day of 1968 would fit nicely for a June build.....
Stephen is offline
post #13 of 15 (permalink) Old Mar 20th, 17, 07:59 PM
Garth
Re: 68 l78
Yep, it was a Thursday, May 23, 1968.
post #14 of 15 (permalink) Old Mar 23rd, 17, 01:34 AM
Garth
Re: 68 l78
Originally Posted by Stephen View Post
Thanks Garth
...anyone else have a thought on an acceptable date range?
thanks
Maybe try the Restoration or Tag Team forums for wheel dates. Some of the guys "in the know" may not take time to check wheels and tires.
Any luck on the booster code ?
post #15 of 15 (permalink) Old Mar 23rd, 17, 04:48 AM Thread Starter
Stephen
Stephen's Avatar
Re: 68 l78
Garth thanks for the follow up and the suggestion
I have not had a chance to get to the car to look for the code but I plan to
Will come back then
Stephen is offline
Human Verification
