Timing for the GM ZZ383 - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 1st, 07, 02:41 PM Thread Starter
I just installed the ZZ383 in my 68 camaro and am still trying to get the timing set just right. Every time I call GM for advice I get a different answer as to what to set the timing at. Can someone shed some advice on what they have their ZZ383 set at.
xtratuff is offline
post #2 of 6 (permalink) Old Jul 1st, 07, 06:16 PM
Marc
mnm99's Avatar
Re: Timing for the GM ZZ383
I believe it stated 32* total with vac advance disconnect. Initial around 15*Here's what I found.http://www.gmperformanceparts.com/En...8772&engCat=sb
As for calling GM...They suck. I emailed them 3 times and never got a response. I tried calling GM performance, GM goodwrench and the headquarters..Nobody could tell me anything. The only awnser I got was to call the dealer I got it at. They also were good for nothing.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] .....FOR SALE.....
mnm99 is offline
post #3 of 6 (permalink) Old Jul 1st, 07, 08:48 PM
What does GM do to their motors that would require anything but 36 degrees all in by 2800? This figuring 12 initial with 24 in the dist and full vac advance on top of that. Isn't this setup pretty much standard these days for performance motors running on quality gas?
Just wondering why it would be different. Warranty issues?
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #4 of 6 (permalink) Old Jul 1st, 07, 09:16 PM
DjD
DjD's Avatar
Fred from the postings here and my personal experiences with my 383 stroker 34 total seems to be the median total all in between 2800-3000rpm. A shorter stroke sbc seems to run 36 - 38 total. Of course this really depends on cam timing and to some degree gear ratio...
...Dennis
DjD is offline
post #5 of 6 (permalink) Old Jul 1st, 07, 10:19 PM
Nope - it's the combustion chamber design. It promotes faster burning of the mixture, hence the term "Fast burn". The Fastburn heads like 32 total - you might be able to sneak it up to 34. Mine runs best at 32.
BPOS is offline
post #6 of 6 (permalink) Old Jul 2nd, 07, 04:08 AM
Silver Bullet
The 2007 GMPP catalogue says the ZZ 383 timing specs are 10° initial and 32° total.
Silver Bullet
1977 Z-28
*New 408 - no ET's yet.
*413 Phase 6 heads Comp 306S Vic Jr 3310 Holley 11.73@115.10 on drag radials @ 3725 lbs.
*Vortecs 234/244 Crane RPM intake 3310 Holley 12.15@110.52 @ 3760+ lbs
Dirt Reynolds is offline
Human Verification
Unilite Mallory Dist. freshen up FYI click Engine 54 Aug 5th, 07 09:04 PM
Wise to detune for lower octane fuel?? VI009DZ Engine 17 Jun 5th, 07 05:15 AM
Initial timing setting? RRatchet Performance 4 Feb 6th, 06 10:13 AM
Vacuum advance questions..? PairOf69's Engine 6 Dec 28th, 05 10:29 AM
Vacuum advance or not??? Ethan67 Performance 55 Apr 9th, 04 06:50 PM
