400 Crank in a 305 Block? - Team Camaro Tech
 4Likes
post #1 of 23 (permalink) Old Oct 1st, 07, 09:49 AM Thread Starter
Send a message via AIM to GCHARGER73 Send a message via MSN to GCHARGER73
just like the title says. I was asked today if you could put a crankshaft out of a 400 small block into a 305 small block, and if so, what would that make? i know a 400 crank in a 350 is a 383, and a 350 crank in a 305 is a 327. but my questions is can you put a 400 crank in a 305?
-ROADBLOCK-
1986 Camaro Z28
-400ci Small Block
-Straight Pipe Exhaust
-American Racing Wheels
GCHARGER73 is offline
post #2 of 23 (permalink) Old Oct 1st, 07, 10:12 AM
Re: 400 Crank in a 305 Block?
A 350 crank in a 305 is a 305. A 400 crank in a 305 would be a 329.
Brians40 likes this.
onovakind67 is offline
post #3 of 23 (permalink) Old Oct 1st, 07, 02:07 PM
Larry
It would be AFTER the main journals are turn down to the medium journal size.
Fathom Green 69 DZ x77 Done soon if the Mastercard holds out!
ldrisner is offline
post #4 of 23 (permalink) Old Oct 1st, 07, 02:11 PM
You'd also want to use some pistons and rods. The crank by itself doesn't create displacement.
post #5 of 23 (permalink) Old Oct 1st, 07, 02:33 PM
Turned down crank and a set of custom pistons to get a 329 makes for a real expensive 327. If you really want a 329 Pontiac made one you could find for a lot less money.
Larger Dave
Larger Dave is offline
post #6 of 23 (permalink) Old Oct 1st, 07, 02:45 PM
Why would you want to do this in the first place.
yellow69RS likes this.
sspecialk is offline
post #7 of 23 (permalink) Old Oct 1st, 07, 03:01 PM
for the same reason all those Mustang guys build 347's instead of just putting in a 351W.
if you've got a 400 crank, get yourself a 350 block and build a 383, or a 400 block and build a 400. they all bolt in and look the same.
you don't plan sincerity.
novaderrik is offline
post #8 of 23 (permalink) Old Oct 1st, 07, 03:52 PM
Banned
334" w/ .030" over pistons if I remember right??
Nice little torque motor, but right, why when there are so many 350's come 383's still out there...
As for the Indian! The 1st year 326" Pontiac was really a 336" engine and then GM made it 326" engine the next year!!
pdq67
post #9 of 23 (permalink) Old Oct 1st, 07, 05:35 PM
I understand the concept of stroking a motor but a 400 crank in a 305. Why not get some combination that is tried and true. Let someone else do all the experimenting and you reap the benefits. Strokin to 421 or 434 now that is the deal.
Of course a nice well thought out 350 works well to.
post #10 of 23 (permalink) Old Oct 1st, 07, 06:32 PM
Tim
77wolf10.85's Avatar
LMAO
Mike, roadblock, I remember you. You have a 400.
It is 4.125 bore and 3.75 stroke if it is stock.
A 350 is 4"bore and 3.48 stroke
305 is 3 3/4 bore and like onovakind told you 3.48 stroke
327 is 4 by 3 1/4
302 is 4 by 3
307 is 3 7/8 by 3 1/4
283 is 3 7/8 by 3
You can see there are definite bore and stroke groupings
and the 305 has the smallest bore of any of them and it is all alone in it's bore range. The only thing it has in common with any of the other groupings is the 350 crank. Of course the 400 has nothing in common with any of the others. But it has cubes.
A 400 crank in a 305 block is a waste of a good crank, whether you had the money to make it work or not. But yes you COULD MAKE IT GO. It's not smart money though. Dumber things have been done successfully?
Edit: all the chevy bores/strokes are on mortec.com. I got the 305 wrong it is 3.736 bore, unlike the 265 which is 3 3/4
Tim Smith
77wolf10.85 is offline
post #11 of 23 (permalink) Old Oct 1st, 07, 06:34 PM Thread Starter
i think im gonna throw a 350 in my car for now while i pull the 400 and build a 406ci street/strip motor
-ROADBLOCK-
1986 Camaro Z28
-400ci Small Block
post #12 of 23 (permalink) Old Oct 2nd, 07, 04:03 PM
Banned
No, the 267" motor does at 3.5" b x 3.48" s = 267"..
pdq67
PS., a 305 has a 3.735" bore!!
post #13 of 23 (permalink) Old Oct 11th, 16, 03:17 PM
Joe
Old post but fwiw your wrong the smallest v8 made by chevy was a 262.. Get it right
Urdeadwrong is offline
post #14 of 23 (permalink) Old Oct 11th, 16, 03:21 PM
Joe
Also a 305 with a 400 crank is not 327 its 334.
post #15 of 23 (permalink) Old Oct 11th, 16, 03:57 PM
Joe a lot of the members here have been building hot rods since model A's and flat head Fords were the hot rod of choice (because they were cheap used cars). Our eyesight isn't what it used to be; so a 7 could look like 2 at first glance which is why when I was taking drafting courses (aka mechanical drawing, since every drawing had to look like the next regardless of which student drafted the drawing) I was taught to bar my sevens and dash my zero's to avoid confusion.
By the way If I were to attempt this build my biggest concern wouldn't be the final displacement number, but it would be whether the rods cleared the piston skirts or the bottom edge of the cylinder bore. You learn that from building lots of engines not checking Google for the one and a half production year failure that was the 262 SBC V8. I worked on 265 SBC V8's in '55 Chevys when they were still brand new (my first car was a1 953 Chevy two door sedan that I took from a 235 six all the way to a 425 horse 409 before I sold it for my first '55 Chevy.
Big Dave
Human Verification
