454 Cooling Fan electric vs flex fan help - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 3rd, 09, 07:14 PM Thread Starter
Jeff
I have a 454 (aprox 400hp) in my 68 and it came to me with a flex fan on it and a makeshift radiator shroud.. It had the wrong engine stands/mounts installed and once i put the right ones in, the makeshift shroud will no longer fit.
Running a flex fan with no shroud makes me nervous. Doesnt seem like a good idea, seems like an accident waiting to happen. Opinions? Id rather not buy a repro shroud.
Can a BB be cooled with only an electric fan?? I happen to have the pusher model of this fan sitting in my garage http://www.spalusa.com/pdf/30100400_SPEC.PDF#view=FitH
Would this be sufficient?? I dont really understand the spec chart. How would it compare with the flex fan on there now?
edit: i found a conversion calc that shows the 2200 m3h=1294 cfm
jeffs68camaro is offline
post #2 of 9 (permalink) Old Oct 3rd, 09, 08:13 PM
Skip
Skeeter55's Avatar
Re: 454 Cooling Fan electric vs flex fan help
Jeff you can do either or... If you already have an electric setting there then it wouldnt hurt to try it. I personaly am using a stock 4-core and 7-blade clutch fan non-thermal with a shroud and love it.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 9 (permalink) Old Oct 3rd, 09, 08:20 PM
Jeff, I'm using a flex fan with factory style shroud plus an electric pusher fan as a back up.
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #4 of 9 (permalink) Old Oct 3rd, 09, 10:11 PM
GM clutch fan is the go. Flex fans are junk.
Instead if pushing air.. they flex! Go figure.
BlackoutSteve is offline
post #5 of 9 (permalink) Old Oct 4th, 09, 08:14 AM Thread Starter
Jeff
They flatten out only at high rpm which is when the fan doesnt do anything anyways....
post #6 of 9 (permalink) Old Oct 4th, 09, 08:33 AM
Leonard
I have a 67 with a 454 repo shroud flex fan with spacer and a 4 core .It never overheats,aiso running 4:11 gears
big block rsss is offline
post #7 of 9 (permalink) Old Oct 4th, 09, 09:10 AM
Matt
Almost exact issue recently discussed...
454 warming up while idling help!
Matt
zlek131 is offline
post #8 of 9 (permalink) Old Oct 4th, 09, 12:09 PM
..and when you do need air at high rpm, too bad.
So when you're on the chassis dyno or doing a nice burnout (car not moving) you don't need air flow?
I had a car that would only lock up the clutch in traffic and on the freeway. The clutch knew what it was doing. A flex would have allowed that car to overheat at speed. No idea why airflow at speed was bad on that car, but who cares? It ran cool.
post #9 of 9 (permalink) Old Oct 4th, 09, 01:16 PM
If you go with a clutch fan make sure you spend the money on a good one. I had a used one come apart and it wasted my radiator. Now I run a 4 core bb radiator, stock type shroud, and this fan...http://www.flex-a-lite.com/auto/html/7-blade-flex.html It works great with 4 core radiators.
markw is offline
Human Verification
