454 or 383 stroker, what to buy? - Team Camaro Tech
post #1 of 21 (permalink) Old Dec 27th, 09, 05:16 PM Thread Starter
Happy Holidays to everyone.....
I am ready to purchase a new engine and I'm looking for opinions on which way to go. My car is currently set up for a sbc. I realize the cost will be about $1,500 - $2,000 more if I go with the 454. I have a list of all the parts I need to convert to a bbc (frame mounts, headers etc...). Both engines will be build to about 450HP, however the 383 will have a little less tq @450. I just want a nice street motor, not looking to race.
What are the pro's and con's of each? I always thought I would get a bbc however, after doing quite a bit of research the 383 makes a lot of sense.
Any and all opinions are welcome.
Thx,
JB's68toy is offline
post #2 of 21 (permalink) Old Dec 27th, 09, 05:59 PM
Smile Re: 454 or 383 stroker, what to buy?
If you want The BIGGEST go with a Big Block. I personally would go with a 383 or larger Small block. I think the 383 will handle better due to less front end weight. Some guy's will say a big block weighs the same if you use aluminum heads, intake etc. Well what happens if you go all aluminum on the small block ? Many people like the WOW factor of having a big block. Big Block stuff is expensive ! The choice is yours !
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
post #3 of 21 (permalink) Old Dec 27th, 09, 06:28 PM
Keith
I've got a 383...awesome all around...stick w/ the small block and save some cash...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #4 of 21 (permalink) Old Dec 27th, 09, 06:38 PM
kt
kelly
big block with alum. heads....always go big, small blocks cant compete with big block torque...engine for engine that is...
kt is offline
post #5 of 21 (permalink) Old Dec 28th, 09, 04:09 AM
BILL
SPARKY69's Avatar
383..pros/..light weight fast....cons/..to much room under the hood when you open it!!/no thread for small blocks........................454 ..pros/...gobs of power, looks great under the hood and you wont be sorry you went with a 383, you will be cool and you can post a pic in the big block sign up thread..cons/...none!!!!!!!!!!
SPARKY69 is offline
post #6 of 21 (permalink) Old Dec 28th, 09, 08:04 AM
Paul
Talking Re: 454 or 383 stroker, what to buy?
383ci all the way!!, Nice reving engines with good torque. Save the bigblocks/boat anchors for the dump trucks.
1969 RS/SS DROPTOP is offline
post #7 of 21 (permalink) Old Dec 28th, 09, 08:20 AM
when I was figuring this out on my '68 I calculated that a small block with alum. heads is something like 175 lbs lighter than an iron b.b. so, when I drop 25 lbs after the holidays it wil be an even 200 lbs! use the money you save to get a KICK A** exhaust to go with it.
okiemark is offline
post #8 of 21 (permalink) Old Dec 28th, 09, 08:28 AM
Lifetime Gold Member
Drew
ddx77's Avatar
Go with the 383 if you have the car setup for it already. JMO
Have to agree with Bill though, there is no sound like a BB starting and idling, and they fill the engine compartment very nicely!
FYI - I wouldn't give up my 468 for anything, accept of course a 572!
________________________________
for now...
ddx77 is offline
post #9 of 21 (permalink) Old Dec 28th, 09, 08:34 AM
Bill
Seems like you can build just about any engine these days to obtain your desired hp & tq that you want for the street. I think there was a time a decade or so ago when the big block had the obvious advantage but technology advancements have really elevated the potential a small block can achieve. So would not say is so cut and dry as it used to be. Yes, the small blocks can be built lighter and that will likely translate into a handling advantage and more mpgs. One advantage of the big-block would have to be that it sounds better to my ears - fuller, lower tone to the exhaust note. Not to say a small block sounds bad by any means but simply hard to beat the sound of more cubes pumpin. I suppose my ideal setup would be a supercharged, stroked small block. To me the sound of the supercharger whistling surpasses the big block throaty growl any day and then you have all the power on demand you want and also better mpgs when you're coastin down the hiway. I realize turbo's have their advantage as well since don't require engine power to operate like the supercharger but then you sacrifice ultimate sound which to me is important. Maybe supercharging is more then you want to spend or deal with though but just thought I'd throw it out there.
68RS-SS is offline
post #10 of 21 (permalink) Old Dec 28th, 09, 09:47 AM
You could also go with an LS7 !
TJS69 is offline
post #11 of 21 (permalink) Old Dec 28th, 09, 11:08 AM
Neither, go with a 434 like mine.
camaro434 is offline
post #12 of 21 (permalink) Old Dec 28th, 09, 12:11 PM
Eric
small block pros-lighter ,cheaper cons-thats all i can say good about a small block big block cons- heavier than a small block,PROs- more power with a milder disposition compared to getting the same power out of a small block,a big block camaro will always draw more attention,appraise for more and sell for more(excluding originalZ28 or some exotic race smallblock)
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
post #13 of 21 (permalink) Old Dec 28th, 09, 12:42 PM
Rat motor all the way. Then again I'm biased (see sig)...
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #14 of 21 (permalink) Old Dec 28th, 09, 12:58 PM
I guess I'm biased too......see my signature as well !!!!!!!
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #15 of 21 (permalink) Old Dec 28th, 09, 09:17 PM
Paul
Once you go big you wont go back...Massive torque is what you want in a street rod and the bbc is the way too go.
Price is almost as cheap as building a strong small block these days and you can sell all your old small block stuff to some small block guy...
Find a good 70's 454 with 049 or 781 heads and you have the beginning of a budget street monster. Get some bigger valves, small dome pistons and a hydroroller cam kit and away you go!!
Or ask Mark (VORTECPRO) about his bbc combo's. Seen him post here before and heard nothing but great reviews of his work.
Paul
Paul-ish is offline
Human Verification
