'88 IROC 305 TPI Engine Torque Specifications - Team Camaro Tech
post #1 of 1 (permalink) Old May 15th, 10, 04:53 PM Thread Starter
Bruce
Does anyone have the engine torque spec's for a 1988 IROC 305 TPI engine?
The bottem end (rods/mains/oil pump) is stock, but I replaced the stock cast iron heads with the aluminium L98 350 Corvette heads, so I would like to get some confirmation on what the aluminium head bolts should be torqued to?
Also, what is the torque spec's on the rods, mains, and oil pump? Just checking as I do not have a reference guide on the '88 305.
Bruce
'68 el Camino SS 396/325 hp, 4 Spd, 3.31, Buckets, AC
'72 el Camino SS, 454 LS5, 4 Spd, 3.73 LSD, Buckets, AC
'75 el Camino SS, 400 SB, Turbo 350, AC, Swivel Buckets, PW, PDL
'87 el Camino Choo Choo SS (305 TPI, 200R4, 3.73 LSD)
'87 Buick GN Hardtop
PaceCarNut is offline
Human Verification
